1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: pscdrv fftwrap compile error for the Debian/ x64
From: "Ha, Kiman via Tech-talk" <[email protected]>
To: "[email protected]" <[email protected]>, Michael Davidsaver <[email protected]>
Date: Mon, 23 Dec 2019 18:13:35 +0000
Hi Michael,
The psdrv softIOC module is running stably since 2015 with Debian-7/32-bit for the NSLS-II BPMs.
Now it is time to update Debian9 and 64 bit OS.
https://github.com/mdavidsaver/pscdrv
http://irfu.cea.fr/Meetings/epics/presentations/Thursday/pscdrv-201410.pdf
I was trying to compile the pscdrv module for the Debian-9 x64 environment and found some errors from the fftwrap module.
Can you advice what happened?
Environment:
Debian GNU/Linux 9
gcc version 6.3.0 20170516 (Debian 6.3.0-18+deb9u1)
~/pscdrv/sigApp$ make
make -C ./src install
make[1]: Entering directory '/home/kha/pscdrv/sigApp/src'
make -C O.linux-x86_64 -f ../Makefile TOP=../../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/home/kha/pscdrv/sigApp/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE         -Wdate-time -D_FORTIFY_SOURCE=2    -D_X86_64_  -DUNIX  -Dlinux     -O3 -g   -Wall    -fdebug-prefix-map=/build/epics-base-3.15.6=. -fstack-protector-strong -Wformat -Werror=format-security   -mtune=generic     -m64 -fPIC -I. -I../O.Common -I. -I. -I.. -I../../../include/compiler/gcc -I../../../include/os/Linux -I../../../include -I/usr/lib/epics/include/compiler/gcc -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/compiler/gcc -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include -I/usr/lib/epics/include/compiler/gcc -I/usr/lib/epics/include/os/Linux -I/usr/lib/epics/include        -c ../fftwrap.cpp
../fftwrap.cpp: In member function ‘void PSDCalc::calculate()’:
../fftwrap.cpp:182:42: error: array must be initialized with a brace-enclosed initializer
                 fftw_complex temp = mid[j];
../fftwrap.cpp:184:39: error: cannot convert ‘double*’ to ‘__complex__ double’ for argument ‘1’ to ‘double creal(__complex__ double)’
                 out[j-1] += creal(temp)*creal(temp) + cimag(temp)*cimag(temp);
../fftwrap.cpp:184:51: error: cannot convert ‘double*’ to ‘__complex__ double’ for argument ‘1’ to ‘double creal(__complex__ double)’
../fftwrap.cpp:184:65: error: cannot convert ‘double*’ to ‘__complex__ double’ for argument ‘1’ to ‘double cimag(__complex__ double)’
../fftwrap.cpp:184:77: error: cannot convert ‘double*’ to ‘__complex__ double’ for argument ‘1’ to ‘double cimag(__complex__ double)’
In file included from ../fftwrap.cpp:17:0:
../fftwrap.h: In instantiation of ‘void FFTWAllocator<T>::destroy(FFTWAllocator<T>::pointer) [with T = double [2]; FFTWAllocator<T>::pointer = double (*)[2]]’:
/usr/include/c++/6/bits/alloc_traits.h:256:4:   required from ‘static decltype (__a.destroy(__p)) std::allocator_traits<_Alloc>::_S_destroy(_Alloc2&, _Tp*, int) [with _Alloc2 = FFTWAllocator<double [2]>; _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>; decltype (__a.destroy(__p)) = void]’
/usr/include/c++/6/bits/alloc_traits.h:356:14:   required from ‘static void std::allocator_traits<_Alloc>::destroy(_Alloc&, _Tp*) [with _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>]’
/usr/include/c++/6/bits/stl_construct.h:143:19:   required from ‘void std::_Destroy(_ForwardIterator, _ForwardIterator, _Allocator&) [with _ForwardIterator = double (*)[2]; _Allocator = FFTWAllocator<double [2]>]’
/usr/include/c++/6/bits/vector.tcc:571:18:   required from ‘void std::vector<_Tp, _Alloc>::_M_default_append(std::vector<_Tp, _Alloc>::size_type) [with _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>; std::vector<_Tp, _Alloc>::size_type = long unsigned int]’
/usr/include/c++/6/bits/stl_vector.h:677:21:   required from ‘void std::vector<_Tp, _Alloc>::resize(std::vector<_Tp, _Alloc>::size_type) [with _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>; std::vector<_Tp, _Alloc>::size_type = long unsigned int]’
../fftwrap.cpp:143:35:   required from here
../fftwrap.h:72:10: error: request for member ‘~double [2]’ in ‘* p’, which is of non-class type ‘double [2]’
     {p->~T();}
../fftwrap.h: In instantiation of ‘void FFTWAllocator<T>::construct(FFTWAllocator<T>::pointer, FFTWAllocator<T>::const_reference&) [with T = double [2]; FFTWAllocator<T>::pointer = double (*)[2]; FFTWAllocator<T>::const_reference = const double (&)[2]]’:
/usr/include/c++/6/bits/alloc_traits.h:243:4:   required from ‘static std::_Require<typename std::allocator_traits<_Alloc>::__construct_helper<_Tp, _Args>::type> std::allocator_traits<_Alloc>::_S_construct(_Alloc&, _Tp*, _Args&& ...) [with _Tp = double [2]; _Args = {double [2]}; _Alloc = FFTWAllocator<double [2]>; std::_Require<typename std::allocator_traits<_Alloc>::__construct_helper<_Tp, _Args>::type> = void]’
/usr/include/c++/6/bits/alloc_traits.h:344:16:   required from ‘static decltype (std::allocator_traits<_Alloc>::_S_construct(__a, __p, (forward<_Args>)(std::allocator_traits::construct::__args)...)) std::allocator_traits<_Alloc>::construct(_Alloc&, _Tp*, _Args&& ...) [with _Tp = double [2]; _Args = {double [2]}; _Alloc = FFTWAllocator<double [2]>; decltype (std::allocator_traits<_Alloc>::_S_construct(__a, __p, (forward<_Args>)(std::allocator_traits::construct::__args)...)) = void]’
/usr/include/c++/6/bits/stl_uninitialized.h:267:25:   required from ‘_ForwardIterator std::__uninitialized_copy_a(_InputIterator, _InputIterator, _ForwardIterator, _Allocator&) [with _InputIterator = std::move_iterator<double (*)[2]>; _ForwardIterator = double (*)[2]; _Allocator = FFTWAllocator<double [2]>]’
/usr/include/c++/6/bits/stl_uninitialized.h:303:2:   required from ‘_ForwardIterator std::__uninitialized_move_if_noexcept_a(_InputIterator, _InputIterator, _ForwardIterator, _Allocator&) [with _InputIterator = double (*)[2]; _ForwardIterator = double (*)[2]; _Allocator = FFTWAllocator<double [2]>]’
/usr/include/c++/6/bits/vector.tcc:563:7:   required from ‘void std::vector<_Tp, _Alloc>::_M_default_append(std::vector<_Tp, _Alloc>::size_type) [with _Tp = double [2]; _Alloc = FFTWAllocator<double [2]>; std::vector<_Tp, _Alloc>::size_type = long unsigned int]’
../fftwrap.h:69:6: error: parenthesized initializer in array new [-fpermissive]
     {::new((void*)p) T(val);}
/etc/epics/configure/RULES_BUILD:239: recipe for target 'fftwrap.o' failed
make[2]: *** [fftwrap.o] Error 1
make[2]: Leaving directory '/home/kha/pscdrv/sigApp/src/O.linux-x86_64'
/etc/epics/configure/RULES_ARCHS:58: recipe for target 'install.linux-x86_64' failed
make[1]: *** [install.linux-x86_64] Error 2
make[1]: Leaving directory '/home/kha/pscdrv/sigApp/src'
/etc/epics/configure/RULES_DIRS:84: recipe for target 'src.install' failed
make: *** [src.install] Error 2
Re: pscdrv fftwrap compile error for the Debian/ x64 Michael Davidsaver via Tech-talk
Prev: Re: Ring buffer overflow Mark Rivers via Tech-talk
Next: Re: Raspberry Pi camera David Vine via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Raspberry Pi camera David Vine via Tech-talk
Next: Re: pscdrv fftwrap compile error for the Debian/ x64 Michael Davidsaver via Tech-talk
ANJ, 23 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
