1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Subject: subArray record [SEC=UNOFFICIAL]
From: "STARRITT, Andrew via Tech-talk" <[email protected]>
To: "EPICS Tech Talk ([email protected])" <[email protected]>
Date: Tue, 24 Dec 2019 01:13:12 +0000
Happy Christmas Tech-Talkers,
The following is an extract from one of my IOCs.
record (waveform, "SR07BM01FPM01:FILL_PATTERN_ABS_WAVEFORM") {
    field (DESC, "FPM Abs Data")
    field (SCAN, "Passive")
    field (NELM, "360")
    field (FTVL, "DOUBLE")
    field (PREC, "5")
record (subArray, "SR07BM01FPM01:FILL_PATTERN_ELEMENT_030_EXTRACT") {
    field (DESC, "Extract element 30")
    field (INP,  "SR07BM01FPM01:FILL_PATTERN_ABS_WAVEFORM CP")
    field (MALM, "360")
    field (NELM, "1")
    field (INDX, "$(I)")
Using base-3-15-6, running cainfo SR07BM01FPM01:FILL_PATTERN_ELEMENT_030_EXTRACT
yields
    State:            connected
    Host:             CR01GW17-CTL:5064
    Access:           read, no write
    Native data type: DBF_DOUBLE
    Request type:     DBR_DOUBLE
    Element count:    360
However, previously with an IOC using 3.14.8.4 this yielded a single valued PV.
We only noticed this when examining the Archive Appliance statistics (which PVs are
archiving the most data)
The subArrayRecord.c cvt_dbaddr function has changed from
   if (!psa->udf && psa->nelm > psa->nord)
      paddr->no_elements = psa->nord;
   else
      paddr->no_elements = psa->nelm;
to
   paddr->no_elements = prec->malm;
My questions: Is this a bug or a feature?
Cheers
Andrew
Andrew C Starritt
Manager - Accelerator Controls and Support Systems
Australian Synchrotron
Tel
Email
Web
+61 3 8540 4164
[email protected]
www.ansto.gov.au
Important: This transmission is intended only for the use of the intended addressee. It is confidential to the intended addressee and may contain privileged information and or copyright material. If this email is not intended for your attention, any use, printing, storage, reproduction or further disclosure of this communication (including all attachments) is strictly forbidden. If you have received this transmission in error, please notify me by telephone or email and immediately delete all copies of this transmission as well as any attachments.
Re: subArray record [SEC=UNOFFICIAL] Michael Davidsaver via Tech-talk
Re: subArray record [SEC=UNOFFICIAL] Johnson, Andrew N. via Tech-talk
Prev: RE: pscdrv fftwrap compile error for the Debian/ x64 Ha, Kiman via Tech-talk
Next: Re: pscdrv fftwrap compile error for the Debian/ x64 Michael Davidsaver via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  <2019>  2020  2021  2022  2023  2024  2025  2026
Prev: Re: Ethernet to RS-232 Danfysik supply connection issues Mark Rivers via Tech-talk
Next: Re: subArray record [SEC=UNOFFICIAL] Michael Davidsaver via Tech-talk
ANJ, 24 Dec 2019 · Home · News · About · Talk · Base · Modules · Extensions ·
