Subject: Re:RE: help for streamDevice question
To: "Mark Rivers" <[email protected]>
Date: Mon, 6 Jan 2020 11:43:39 +0800 (CST)
Sorry.
I want to send many socket packages to  a device.
A single package consist of a 8 bytes time stamp(changeable), a 4 bytes protocol number, a 4 bytes determined number and a 8 bytes check code(changeable).
Time Stamp
Protocol
Vision
Command
Check Code
8 bytes
4 bytes
4 bytes
8 bytes
What I suppose is to use hex format to save the data.
So I write record like this:
record(waveform,"data")
field (DTVP, "stream")
field(INP, "@devTest.proto array_in L0")
field(FTVL, "LONG")
field(NELM, "256")
field(PINI, "YES")
field(SCAN, "Passive")
and proto file
data0 = 0x23;
array_in {
out "\${data0}";
in "%4x";
In this case, only determined data can be sent. I hope to sent some changeable data which produced by a python program in real-time.
Thank you very much.
YaweiZhang
At 2020-01-06 00:22:42, "Mark Rivers" <[email protected]> wrote:
I think you need to be more specific.  What is the format of the strings you are trying to write and read?
From: Tech-talk <[email protected]> On Behalf Of ??? via Tech-talk
Sent: Sunday, January 5, 2020 8:22 AM
To: [email protected]
Subject: help for streamDevice question
hi,
    I want to use streamDevice to communicate with a device just like  https://epics.anl.gov/tech-talk/2016/msg01310.php does.
    My problem is that I don't know how to write changeable data into record, which include  time and a time-dependent encryption number.
    Could someone give me a hand?
    Thanks a lot.
YaweiZhang
Re: Re:RE: help for streamDevice question Mark Rivers via Tech-talk
help for streamDevice question 张亚威 via Tech-talk
Prev: Re: Ethernet question Mark Rivers via Tech-talk
Next: Re: Ethernet question Michael Davidsaver via Tech-talk
Prev: RE: help for streamDevice question Mark Rivers via Tech-talk
Next: Re: Re:RE: help for streamDevice question Mark Rivers via Tech-talk
