Hi YaweiZhang,
I looks like you need to send a 24-byte packet and receive a 4-byte response?
Is the output packet binary or hex ASCII characters?
Is the response binary or hex ASCII characters? Because you do not show any terminators on input or output I suspect it is binary, not hex.
Stream device may be able to construct the Check Code for you for with its "checksum" converter, but you need to see if your check code uses one of the algorithms that stream device supports.
I think you will need other software to create the timestamp bytes.
One way to do this is not to use stream device at all, but just use an asyn record. Your Python code would build the entire 24-byte array and write it to the BOUT field of the asyn record. The asyn record would then read the 4 byte response into the BINP field.
Alternatively you could write a little C++ driver based on asynPortDriver to build and send the string and parse the response.
Sent: Sunday, January 5, 2020 9:43 PM
To: Mark Rivers
Cc: [email protected]
Subject: Re:RE: help for streamDevice question
Sorry.
I want to send many socket packages to a device.
A single package consist of a 8 bytes time stamp(changeable), a 4 bytes protocol number, a 4 bytes determined number and a 8 bytes check code(changeable).
Time Stamp
Protocol
Vision
Command
Check Code
8 bytes
4 bytes
4 bytes
8 bytes
What I suppose is to use hex format to save the data.
So I write record like this:
record(waveform,"data")
field (DTVP, "stream")
field(INP, "@devTest.proto array_in L0")
field(FTVL, "LONG")
field(NELM, "256")
field(PINI, "YES")
field(SCAN, "Passive")
and proto file
data0 = 0x23;
array_in {
out "\${data0}";
in "%4x";
In this case, only determined data can be sent. I hope to sent some changeable data which produced by a python program in real-time.
Thank you very much.
YaweiZhang
At 2020-01-06 00:22:42, "Mark Rivers" <[email protected]> wrote:
I think you need to be more specific. What is the format of the strings you are trying to write and read?
From: Tech-talk <[email protected]> On Behalf Of ??? via Tech-talk
Sent: Sunday, January 5, 2020 8:22 AM
To: [email protected]
Subject: help for streamDevice question
hi,
I want to use streamDevice to communicate with a device just like https://epics.anl.gov/tech-talk/2016/msg01310.php does.
My problem is that I don't know how to write changeable data into record, which include time and a time-dependent encryption number.
Could someone give me a hand?
Thanks a lot.
YaweiZhang
- Re:Re: Re:RE: help for streamDevice question 张亚威 via Tech-talk
- help for streamDevice question 张亚威 via Tech-talk
- RE: help for streamDevice question Mark Rivers via Tech-talk
- Re:RE: help for streamDevice question 张亚威 via Tech-talk
RE: Ethernet to RS-232 Danfysik supply connection issues Kathryn Baker - UKRI STFC via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
