Subject: Re: EPICS R3.15 and menuScan.dbd
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
Date: Mon, 6 Jan 2020 21:33:00 +0000
On 1/6/20 3:25 PM, Johnson, Andrew N. via Tech-talk wrote:
On 1/6/20 2:55 PM, Michael Westfall via Tech-talk wrote:
In the past (using EPICS R3.14.12.x) when we wanted to use custom scan rates, we included a customized version of menuScan.dbd in the source code directory of the IOC project and added 'project_DBD += menuScan.dbd' to the Makefile.
Ah, don't do that last bit, see below. You probably didn't actually do that with 3.14 either...
On further thought you might have done that with 3.14 and it would have worked, but it won't in 3.15 or later versions. The 3.14 dbExpand program ignored any redefinitions of menus and just kept the first definition that it found. 3.15 uses a stricter dbdExpand.pl program, which annoyingly points out things like that and insists that you correct them (but the result is less likely to do something you weren't expecting to happen).
- Andrew
Complexity comes for free, Simplicity you have to work for.
Re: EPICS R3.15 and menuScan.dbd Michael Westfall via Tech-talk
Re: EPICS R3.15 and menuScan.dbd Johnson, Andrew N. via Tech-talk
Prev: Re: Finding the PV for a specific device? Mooney, Tim M. via Tech-talk
Next: Re: Finding the PV for a specific device? Mooney, Tim M. via Tech-talk
Prev: Re: EPICS R3.15 and menuScan.dbd Johnson, Andrew N. via Tech-talk
Next: Re: EPICS R3.15 and menuScan.dbd Michael Westfall via Tech-talk
