Subject: Re: EPICS R3.15 and menuScan.dbd
From: Michael Westfall via Tech-talk <[email protected]>
Date: Mon, 6 Jan 2020 19:06:57 -0300
Ah, that makes sense. Thanks
Except, I still get the error because apparently there are copies of menuScan in several of the dbd files from the support modules that were probably pulled when including base.dbd for each module.
So..... maybe support modules should not include base.dbd?
On Mon, Jan 6, 2020 at 6:33 PM Johnson, Andrew N. via Tech-talk <[email protected]> wrote:
On 1/6/20 3:25 PM, Johnson, Andrew N. via Tech-talk wrote:
On 1/6/20 2:55 PM, Michael Westfall via Tech-talk wrote:
In the past (using EPICS R3.14.12.x) when we wanted to use custom scan rates, we included a customized version of menuScan.dbd in the source code directory of the IOC project and added 'project_DBD += menuScan.dbd' to the Makefile.
Ah, don't do that last bit, see below. You probably didn't actually do that with 3.14 either...
On further thought you might have done that with 3.14 and it would have worked, but it won't in 3.15 or later versions. The 3.14 dbExpand program ignored any redefinitions of menus and just kept the first definition that it found. 3.15 uses a stricter dbdExpand.pl program, which annoyingly points out things like that and insists that you correct them (but the result is less likely to do something you weren't expecting to happen).
- Andrew
Complexity comes for free, Simplicity you have to work for.
Mike Westfall
Control Systems Software Engineer
Re: EPICS R3.15 and menuScan.dbd Johnson, Andrew N. via Tech-talk
EPICS R3.15 and menuScan.dbd Michael Westfall via Tech-talk
Prev: Re: Ethernet question J. Lewis Muir via Tech-talk
Next: Re: New sequencer release 2.2.8 Johnson, Andrew N. via Tech-talk
Prev: Re: EPICS R3.15 and menuScan.dbd Johnson, Andrew N. via Tech-talk
Next: Re: EPICS R3.15 and menuScan.dbd Johnson, Andrew N. via Tech-talk
