Subject: CA link question
Date: Wed, 8 Jan 2020 00:41:40 +0000
Folks,
I have an IOC that is in a state I have not seen before.  I am trying to understand what it going on.
This is a calcout record.  INPA and INPB are CP links.
ioc13ida> dbpr "13IDA:eps_wait89",2
A   : 0             ACKS: INVALID       ACKT: YES           ADEL: 0
ASG :               B   : 1             BKPT: 00            C   : 0
CALC: MAX(A,2*B)    CLCV: 0             D   : 0             DESC: EPS input calc
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DLYA: 0             DOPT: Use CALC      DTYP: Soft Channel  E   : 0
EGU :               EVNT:               F   : 0             FLNK: CONSTANT
G   : 0             H   : 0             HHSV: NO_ALARM      HIGH: 0
HIHI: 0             HOPR: 0             HSV : NO_ALARM      HYST: 0
I   : 0             INAV: Ext PV OK     INBV: Ext PV OK     INCV: Constant
INDV: Constant      INEV: Constant      INFV: Constant      INGV: Constant
INHV: Constant      INIV: Constant      INJV: Constant      INKV: Constant
INLV: Constant      INPA: CA_LINK 13IDA:eps_bi89.VAL CP NMS
INPB: CA_LINK 13IDA:eps_invalid.VAL CP NMS                  INPC: CONSTANT
INPD: CONSTANT      INPE: CONSTANT      INPF: CONSTANT      INPG: CONSTANT
INPH: CONSTANT      INPI: CONSTANT      INPJ: CONSTANT      INPK: CONSTANT
INPL: CONSTANT      IVOA: Continue normally                 IVOV: 0
J   : 0             K   : 0             L   : 0             LCNT: 0
LLSV: NO_ALARM      LOLO: 0             LOPR: 0             LOW : 0
LSV : NO_ALARM      MDEL: 0             NAME: 13IDA:eps_wait89
NSEV: NO_ALARM      NSTA: NO_ALARM      OCAL: 0             OCLV: 0
ODLY: 0             OEVT:               OOPT: Every Time
OUT : DB_LINK 13IDA:eps_mbbi89.VAL PP NMS                   OUTV: Local PV
OVAL: 2             PACT: 0             PHAS: 0             PINI: NO
POVL: 2             PREC: 0             PRIO: LOW           PUTF: 0
PVAL: 2             RPRO: 0             SCAN: Passive       SDIS: CONSTANT
SEVR: NO_ALARM      STAT: NO_ALARM      TIME: 2020-01-07 23:35:22.701452929
TPRO: 0             TSE : 0             TSEL: CONSTANT      UDF : 0
UDFS: INVALID       VAL : 2
value = 0 = 0x0
Note that INPB is 13IDA:eps_invalid.VAL CP.  The current value of B is 1.
This is 13IDA:eps_invalid.  Note that its value is 0.
ioc13ida> dbpr "13IDA:eps_invalid",2
CALC: (A#0)||(B=0)||(C#0)||(D#0)        CLCV: 0             D   : 0
DESC: EPS invalid calculation           DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DLYA: 0             DOPT: Use CALC
DTYP: Soft Channel  E   : 0             EGU :               EVNT:
F   : 0             FLNK: CONSTANT      G   : 0             H   : 0
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV : NO_ALARM      HYST: 0             I   : 0             INAV: Ext PV OK
INBV: Ext PV OK     INCV: Ext PV OK     INDV: Ext PV OK     INEV: Constant
INFV: Constant      INGV: Constant      INHV: Constant      INIV: Constant
INJV: Constant      INKV: Constant      INLV: Constant
INPA: CA_LINK 13IDA:eps_bi1.SEVR CP NMS INPB: CA_LINK 13IDA:eps_bi1.VAL CP NMS
INPC: CA_LINK 13IDA:eps_bi2.VAL CP NMS  INPD: CA_LINK 13IDA:eps_bi11.VAL CP NMS
INPE: CONSTANT      INPF: CONSTANT      INPG: CONSTANT      INPH: CONSTANT
INPI: CONSTANT      INPJ: CONSTANT      INPK: CONSTANT      INPL: CONSTANT
IVOA: Continue normally                 IVOV: 0             J   : 0
K   : 0             L   : 0             LCNT: 0             LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW : 0             LSV : NO_ALARM
MDEL: 0             NAME: 13IDA:eps_invalid                 NSEV: NO_ALARM
NSTA: NO_ALARM      OCAL: 0             OCLV: 0             ODLY: 0
OEVT:               OOPT: Every Time    OUT : CONSTANT      OUTV: Constant
OVAL: 0             PACT: 0             PHAS: 0             PINI: NO
POVL: 0             PREC: 0             PRIO: LOW           PUTF: 0
PVAL: 0             RPRO: 0             SCAN: Passive       SDIS: CONSTANT
SEVR: NO_ALARM      STAT: NO_ALARM      TIME: 2020-01-08 00:35:15.769533950
UDFS: INVALID       VAL : 0
My questions:
-   Why is 13IDA:eps_wait89.B 2 if it gets its value from a record whose value is 0, and uses the CP link attribute?
-   If I force 13IDA:eps_wait89 to process with dbtr should it fetch the value of 13IDA:eps_invalid?  It does not seem to, B is still 1.
ioc13ida> dbtr "13IDA:eps_wait89"
ALST: 2             ASG :               B   : 1             BKPT: 00
C   : 0             CALC: MAX(A,2*B)    CLCV: 0             D   : 0
DESC: EPS input calc                    DISA: 0             DISP: 0
INBV: Ext PV OK     INCV: Constant      INDV: Constant      INEV: Constant
J   : 0             K   : 0             L   : 0             LA  : 0
LALM: 2             LB  : 1             LC  : 0             LCNT: 0
LD  : 0             LE  : 0             LF  : 0             LG  : 0
LH  : 0             LI  : 0             LJ  : 0             LK  : 0
LL  : 0             LLSV: NO_ALARM      LOLO: 0             LOPR: 0
LOW : 0             LSV : NO_ALARM      MDEL: 0             MLST: 2
NAME: 13IDA:eps_wait89                  NSEV: NO_ALARM      NSTA: NO_ALARM
OCAL: 0             OCLV: 0             ODLY: 0             OEVT:
OOPT: Every Time    OUT : DB_LINK 13IDA:eps_mbbi89.VAL PP NMS
OUTV: Local PV      OVAL: 2             PACT: 0             PHAS: 0
PINI: NO            POVL: 2             PREC: 0             PRIO: LOW
PROC: 1             PUTF: 0             PVAL: 2             RPRO: 0
SCAN: Passive       SDIS: CONSTANT      SEVR: NO_ALARM      STAT: NO_ALARM
TIME: 2020-01-08 00:38:43.652867248     TPRO: 0             TSE : 0
TSEL: CONSTANT      UDF : 0             UDFS: INVALID       VAL : 2
value = 0 = 0x0
RE: CA link question Mark Rivers via Tech-talk
Prev: RE: Ethernet question Mark Rivers via Tech-talk
Next: Re: Ethernet question Ryan Pierce via Tech-talk
Prev: Re: EPICS release series after 7.0: 7.1 or 8.0? Benjamin Franksen via Tech-talk
Next: RE: CA link question Mark Rivers via Tech-talk
