1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: CA link question
To: "'[email protected]'" <[email protected]>
Date: Wed, 8 Jan 2020 20:11:11 +0000
Andrew Johnson suggested that if I rewrite the calcout record INPB link field, using the same value as it currently has, that will cause Channel Access to disconnect and then reconnect, which would update the stale value in the calcout record.
I tried that and indeed it worked.
The question is why was the value from the CP link not up to date, i.e. not reflecting the current value of the link PV.
Andrew thinks this might be due to a known problem with links in 7.0.3.1.  If so, I think it needs to be fixed ASAP since it is making my IOC behave incorrectly.
Sent: Tuesday, January 7, 2020 6:42 PM
To: [email protected]
Subject: CA link question
Folks,
I have an IOC that is in a state I have not seen before.  I am trying to understand what it going on.
This is a calcout record.  INPA and INPB are CP links.
ioc13ida> dbpr "13IDA:eps_wait89",2
A   : 0             ACKS: INVALID       ACKT: YES           ADEL: 0
ASG :               B   : 1             BKPT: 00            C   : 0
CALC: MAX(A,2*B)    CLCV: 0             D   : 0             DESC: EPS input calc
DISA: 0             DISP: 0             DISS: NO_ALARM      DISV: 1
DLYA: 0             DOPT: Use CALC      DTYP: Soft Channel  E   : 0
EGU :               EVNT:               F   : 0             FLNK: CONSTANT
G   : 0             H   : 0             HHSV: NO_ALARM      HIGH: 0
HIHI: 0             HOPR: 0             HSV : NO_ALARM      HYST: 0
I   : 0             INAV: Ext PV OK     INBV: Ext PV OK     INCV: Constant
INDV: Constant      INEV: Constant      INFV: Constant      INGV: Constant
INHV: Constant      INIV: Constant      INJV: Constant      INKV: Constant
INLV: Constant      INPA: CA_LINK 13IDA:eps_bi89.VAL CP NMS
INPB: CA_LINK 13IDA:eps_invalid.VAL CP NMS                  INPC: CONSTANT
INPD: CONSTANT      INPE: CONSTANT      INPF: CONSTANT      INPG: CONSTANT
INPH: CONSTANT      INPI: CONSTANT      INPJ: CONSTANT      INPK: CONSTANT
INPL: CONSTANT      IVOA: Continue normally                 IVOV: 0
J   : 0             K   : 0             L   : 0             LCNT: 0
LLSV: NO_ALARM      LOLO: 0             LOPR: 0             LOW : 0
LSV : NO_ALARM      MDEL: 0             NAME: 13IDA:eps_wait89
NSEV: NO_ALARM      NSTA: NO_ALARM      OCAL: 0             OCLV: 0
ODLY: 0             OEVT:               OOPT: Every Time
OUT : DB_LINK 13IDA:eps_mbbi89.VAL PP NMS                   OUTV: Local PV
OVAL: 2             PACT: 0             PHAS: 0             PINI: NO
POVL: 2             PREC: 0             PRIO: LOW           PUTF: 0
PVAL: 2             RPRO: 0             SCAN: Passive       SDIS: CONSTANT
SEVR: NO_ALARM      STAT: NO_ALARM      TIME: 2020-01-07 23:35:22.701452929
TPRO: 0             TSE : 0             TSEL: CONSTANT      UDF : 0
UDFS: INVALID       VAL : 2
value = 0 = 0x0
Note that INPB is 13IDA:eps_invalid.VAL CP.  The current value of B is 1.
This is 13IDA:eps_invalid.  Note that its value is 0.
ioc13ida> dbpr "13IDA:eps_invalid",2
CALC: (A#0)||(B=0)||(C#0)||(D#0)        CLCV: 0             D   : 0
DESC: EPS invalid calculation           DISA: 0             DISP: 0
DISS: NO_ALARM      DISV: 1             DLYA: 0             DOPT: Use CALC
DTYP: Soft Channel  E   : 0             EGU :               EVNT:
F   : 0             FLNK: CONSTANT      G   : 0             H   : 0
HHSV: NO_ALARM      HIGH: 0             HIHI: 0             HOPR: 0
HSV : NO_ALARM      HYST: 0             I   : 0             INAV: Ext PV OK
INBV: Ext PV OK     INCV: Ext PV OK     INDV: Ext PV OK     INEV: Constant
INFV: Constant      INGV: Constant      INHV: Constant      INIV: Constant
INJV: Constant      INKV: Constant      INLV: Constant
INPA: CA_LINK 13IDA:eps_bi1.SEVR CP NMS INPB: CA_LINK 13IDA:eps_bi1.VAL CP NMS
INPC: CA_LINK 13IDA:eps_bi2.VAL CP NMS  INPD: CA_LINK 13IDA:eps_bi11.VAL CP NMS
INPE: CONSTANT      INPF: CONSTANT      INPG: CONSTANT      INPH: CONSTANT
INPI: CONSTANT      INPJ: CONSTANT      INPK: CONSTANT      INPL: CONSTANT
IVOA: Continue normally                 IVOV: 0             J   : 0
K   : 0             L   : 0             LCNT: 0             LLSV: NO_ALARM
LOLO: 0             LOPR: 0             LOW : 0             LSV : NO_ALARM
MDEL: 0             NAME: 13IDA:eps_invalid                 NSEV: NO_ALARM
NSTA: NO_ALARM      OCAL: 0             OCLV: 0             ODLY: 0
OEVT:               OOPT: Every Time    OUT : CONSTANT      OUTV: Constant
OVAL: 0             PACT: 0             PHAS: 0             PINI: NO
POVL: 0             PREC: 0             PRIO: LOW           PUTF: 0
PVAL: 0             RPRO: 0             SCAN: Passive       SDIS: CONSTANT
SEVR: NO_ALARM      STAT: NO_ALARM      TIME: 2020-01-08 00:35:15.769533950
UDFS: INVALID       VAL : 0
My questions:
-   Why is 13IDA:eps_wait89.B 2 if it gets its value from a record whose value is 0, and uses the CP link attribute?
-   If I force 13IDA:eps_wait89 to process with dbtr should it fetch the value of 13IDA:eps_invalid?  It does not seem to, B is still 1.
ioc13ida> dbtr "13IDA:eps_wait89"
ALST: 2             ASG :               B   : 1             BKPT: 00
C   : 0             CALC: MAX(A,2*B)    CLCV: 0             D   : 0
DESC: EPS input calc                    DISA: 0             DISP: 0
INBV: Ext PV OK     INCV: Constant      INDV: Constant      INEV: Constant
J   : 0             K   : 0             L   : 0             LA  : 0
LALM: 2             LB  : 1             LC  : 0             LCNT: 0
LD  : 0             LE  : 0             LF  : 0             LG  : 0
LH  : 0             LI  : 0             LJ  : 0             LK  : 0
LL  : 0             LLSV: NO_ALARM      LOLO: 0             LOPR: 0
LOW : 0             LSV : NO_ALARM      MDEL: 0             MLST: 2
NAME: 13IDA:eps_wait89                  NSEV: NO_ALARM      NSTA: NO_ALARM
OCAL: 0             OCLV: 0             ODLY: 0             OEVT:
OOPT: Every Time    OUT : DB_LINK 13IDA:eps_mbbi89.VAL PP NMS
OUTV: Local PV      OVAL: 2             PACT: 0             PHAS: 0
PINI: NO            POVL: 2             PREC: 0             PRIO: LOW
PROC: 1             PUTF: 0             PVAL: 2             RPRO: 0
SCAN: Passive       SDIS: CONSTANT      SEVR: NO_ALARM      STAT: NO_ALARM
TIME: 2020-01-08 00:38:43.652867248     TPRO: 0             TSE : 0
TSEL: CONSTANT      UDF : 0             UDFS: INVALID       VAL : 2
value = 0 = 0x0
Re: CA link question Benjamin Franksen via Tech-talk
CA link question Mark Rivers via Tech-talk
Prev: Re: EPICS release series after 7.0: 7.1 or 8.0? J. Lewis Muir via Tech-talk
Next: Re: EPICS release series after 7.0: 7.1 or 8.0? Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: CA link question Mark Rivers via Tech-talk
Next: Re: CA link question Benjamin Franksen via Tech-talk
