1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: s7plc with S7-1200
From: "Saleh, Ibrahim via Tech-talk" <[email protected]>
Date: Wed, 8 Jan 2020 23:19:54 +0000
Hello,
Does anyone use s7plc EPICS support with SIEMENS S7-1200 CPU? I am using CP 1243-1 to establish communication through TCP connection using TSEND_C and TRCV_C instructions.
When I run the IOC I got the following messages:
dbLoadDatabase "dbd/s7-1200.dbd"
s7_1200_registerRecordDeviceDriver pdbbase
#var s7plcDebug 0
s7plcConfigure("s7-1200","192.168.0.2",2000,240,240,1,5000,50)
## Load record instances
dbLoadRecords("db/dio.db")
iocInit
Starting iocInit
## EPICS R3.14.12.8
## EPICS Base built Dec  4 2019
01/03/20 11:24:56.417 s7plcConnect s7-1200: connected to 192.168.0.2:2000
01/03/20 11:25:01.423 s7plcWaitForInput s7-1200: timeout after 5 seconds.
01/03/20 11:25:01.423 s7plcReceiveThread s7-1200: waiting for input failed: Connection timed out
01/03/20 11:25:01.423 s7plcCloseConnection s7-1200
It is shown that IOC is connected but I am not sure if the PLC code configuration in the TIA Portal is correct or not.
Any ideas?
Thanks.
Ibrahim
Prev: Re: EPICS release series after 7.0: 7.1 or 8.0? J. Lewis Muir via Tech-talk
Next: Can't import PyEpics on CentOS 7 Chiang, Liang-Chih [江良志] via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: "st.cmd" internal code question Mark Rivers via Tech-talk
