Subject: Can't import PyEpics on CentOS 7
From: Chiang, Liang-Chih [江良志] via Tech-talk <[email protected]>
Date: Thu, 9 Jan 2020 03:29:31 +0000
I could install PyEpics on CentOS 6.10(x86_64) and Python 3.7,
and there is no problem using caget, caput, PV, Motor, etc.. of PyEpics.
However, in the following environment, 'import epics' will result in error.
    CentOS version 7.4, x86_64 architecture
    Linux kernel version 3.10.0
    Python 3.7 (created by Miniconda virtual environment)
The PyEpics was installed by the following command:
$ conda install -c GSECARS pyepics
In Python interactive shell:
>>> import epics
Traceback (most recent call last):
  File "/home/user/miniconda3/envs/py37/lib/python3.7/ctypes/__init__.py", line 97, in CFUNCTYPE
    return _c_functype_cache[(restype, argtypes, flags)]
KeyError: (None, (<class 'epics.dbr.access_rights_handler_args'>,), 1)
During handling of the above exception, another exception occurred:
  File "<stdin>", line 1, in <module>
  File "/home/user/miniconda3/envs/py37/lib/python3.7/site-packages/epics/__init__.py", line 29, in <module>
    from . import ca
  File "/home/user/miniconda3/envs/py37/lib/python3.7/site-packages/epics/ca.py", line 761, in <module>
    dbr.access_rights_handler_args)
  File "/home/user/miniconda3/envs/py37/lib/python3.7/site-packages/epics/dbr.py", line 339, in make_callback
    return ctypes.CFUNCTYPE(None, args)(func)
  File "/home/user/miniconda3/envs/py37/lib/python3.7/ctypes/__init__.py", line 99, in CFUNCTYPE
    class CFunctionType(_CFuncPtr):
TypeError: item 1 in _argtypes_ passes a struct/union with a bitfield by value, which is unsupported.
I also tried installing PyEpics by 'pip install pyepics', similar error message will show up when installing.
Best regards.
LiangChih Chiang
email: [email protected]
Beamline Group
National Synchrotron Radiation Research Center (NSRRC)
Re: Can't import PyEpics on CentOS 7 Matt Newville via Tech-talk
Prev: s7plc with S7-1200 Saleh, Ibrahim via Tech-talk
Next: EPICS Smartmotor example IOC 최원철 via Tech-talk
Next: Re: Can't import PyEpics on CentOS 7 Matt Newville via Tech-talk
