Subject: Carriage Return in asyn record IEOS/OEOS fields
From: Marissa Kranz via Tech-talk <[email protected]>
Date: Fri, 10 Jan 2020 14:02:45 -0800
Hello,
I am using asyn records to send commands to ethernet connected power supplies. This particular supply requires \r for its end of string terminator. When I put \r into the IEOS or OEOS field in an asyn record and boot the IOC, the \r isn't instantiated in those fields- they are empty. I can dbput the \r in to those fields after the IOC is running to talk to the supply, but cannot get them to load at startup. I have confirmed that the \r exists in the .db files and tried using single and double quotes to get the \r to instantiate in the record fields with no success. These fields have worked for me in the past with terminators like \n, but I cannot get it work with \r.
The record documentation lists \r as the default value for the OEOS and IEOS fields, but leaving these fields blank to allow for the default and booting the IOC does not allow for communication with the supply. I have to explicitly dbput \r into the fields to be able to send and receive messages.
Has anyone encountered this is the past when using asyn and have a fix for getting the IOC to boot with \r in the OEOS and IEOS fields of asyn records?
Thank you,
Marissa Kranz
Marissa Kranz
Research Engineer
UW Medical Cyclotron Facility
University of Washington School of Medicine
425.246.4964
RE: Carriage Return in asyn record IEOS/OEOS fields Mark Rivers via Tech-talk
Prev: Re: EPICS release series after 7.0: 7.1 or 8.0? J. Lewis Muir via Tech-talk
Next: RE: Carriage Return in asyn record IEOS/OEOS fields Mark Rivers via Tech-talk
Prev: Error when running st.cmd of SmartMotor <<-- cancel the question 최원철 via Tech-talk
