1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Carriage Return in asyn record IEOS/OEOS fields
To: 'Marissa Kranz' <[email protected]>
Date: Fri, 10 Jan 2020 22:17:50 +0000
Hi Marissa,
The asyn record documentation says this:
OEOS is set to the current value for the port when the record connects to the port. If OEOS is modified after the record connects to the port, then the output EOS will be changed using asynOctet->setOutputEos. IMPORTANT: The value of OEOS in the database file is never used, because it is modified when the record connects to the port.
IEOS is set to the current value for the port when the record connects to the port. If IEOS is modified after the record connects to the port, then the input EOS will be changed using asynOctet->setInputEos. IMPORTANT: The value of IEOS in the database file is never used, because it is modified when the record connects to the port.
You should set the input and output terminators for the asyn port itself, rather than in the asyn record.
Add the following lines to your startup script:
asynOctetSetInputEos("port",0,"\r")
asynOctetSetOutputEos("port",0,"\r")
where "port" is the name of the port you have created.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Marissa Kranz via Tech-talk
Sent: Friday, January 10, 2020 4:03 PM
To: [email protected]
Subject: Carriage Return in asyn record IEOS/OEOS fields
Hello,
I am using asyn records to send commands to ethernet connected power supplies. This particular supply requires \r for its end of string terminator. When I put \r into the IEOS or OEOS field in an asyn record and boot the IOC, the \r isn't instantiated in those fields- they are empty. I can dbput the \r in to those fields after the IOC is running to talk to the supply, but cannot get them to load at startup. I have confirmed that the \r exists in the .db files and tried using single and double quotes to get the \r to instantiate in the record fields with no success. These fields have worked for me in the past with terminators like \n, but I cannot get it work with \r.
The record documentation lists \r as the default value for the OEOS and IEOS fields, but leaving these fields blank to allow for the default and booting the IOC does not allow for communication with the supply. I have to explicitly dbput \r into the fields to be able to send and receive messages.
Has anyone encountered this is the past when using asyn and have a fix for getting the IOC to boot with \r in the OEOS and IEOS fields of asyn records?
Thank you,
Marissa Kranz
Marissa Kranz
Research Engineer
UW Medical Cyclotron Facility
University of Washington School of Medicine
425.246.4964
RE: Carriage Return in asyn record IEOS/OEOS fields Mark Rivers via Tech-talk
Carriage Return in asyn record IEOS/OEOS fields Marissa Kranz via Tech-talk
Prev: Carriage Return in asyn record IEOS/OEOS fields Marissa Kranz via Tech-talk
Next: RE: Carriage Return in asyn record IEOS/OEOS fields Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
