Hello, Qisheng Wang
I found the following e-mail that I had sent to a colleague in 2016. We have also seen
this error with other Gali's (DMC 40x0) with the Ethernet (although we separated jumbo frames via VLAN).
> I run two ( + one spare) Galil-Rio 47200 ( but not using motion control, just as analog and binary input/output for status messages, attenuator control and some interlocks)
> and got one DMC-8xxx with the undulator. This one controls the gap (motor) of the undulator but was not programmed by us but by the vendor STI.
> The rio-controllers looks nice but does not are working reliable if there are connected to the ethernet. Then they will stuck after one hours/days. Even with the
> galil-library this behaviour persists. I had opened some tickets at Galil but got no solution for this. It seem that the ethernet stack could not properly handle the broadcast messages.
> With Marc Clift I was in touch and we talked about his last October in Melbourne and he should be aware of this.
> Actually we hat the RIOs connected via serial line (via a moxa terminal server) and are using EPICS StreamDevice. So far so good. The DMC-8xxx (Undulator control) we ran
> it on a separate server ethernet interface and have it isolated (just with one kollmorgan motor driver). This also works in this manner.
Viele Grüße
Heinz Junkes
Experience directly varies with equipment ruined.
> On 17. Jan 2020, at 10:13, wangqisheng--- via Tech-talk <[email protected]> wrote:
> Hello, Tech-Talkers
> Galil 21X3 card works fine for many years for our beamline BL17U at Shanghai Synchrotron Radiation Facility. Recently there is a Galil DMC-4060 card used to control a six dimensional table. The driver is 3.0 download from githube. The enviornment list as bellow:
> dmc 40600 rev 1.3a 22803
> epics 3.15
> motor 7.1
> centos8
> The IOC can be initialized and works fine with the serial interface. If ethernet interface is used, the ioc can be started, the small motor edm works, but it will give out "internal error" when the full edm or medm GUI is opened.
> Closing some port number is not helpful.
> Any suggestions are very welcome.
> Thanks and Best Regards,
> Qisheng Wang 汪启胜
> Shanghai Institute of Applied Physics
> Chinese Academy of Sciences
> 239 Zhangheng Road, Pudong District
> Shanghai 201204,P.R.China
> Tel: +86-21-33933192; Fax: +86-21-33933021
> Email: [email protected]
smime.p7s
Description: S/MIME cryptographic signature
- Re: [EXTERNAL] Probelm with ethernet interface of Galil controller Pearson, Matthew R. via Tech-talk
- Probelm with ethernet interface of Galil controller wangqisheng--- via Tech-talk
StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
