1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: StreamDevice not parsing STREAM_PROTOCOL_PATH
From: Gerrit Kühn via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 17 Jan 2020 11:16:23 +0100
Hello all,
I added a recent (2.8.10) StreamDevice to an existing (older) EPICS
sinstalltion (3.15.3). Everything appears to work fine except for the
parsing of the STREAM_PROTOCOL_PATH variable. The built ioc complains
about not finding the protocol file, but it only looks in ".". I tried
using epicsEnvSet and a shell environment variable, still StreamDevice
insists on just looking into ".". Linking my protocol file to this place
makes everything work.
Turning on debugging and logging, it looks like drvInit() in
StreamEpics.cc (which looks like it is responsible for parsing the
variable) is never called, I get no debug output at all from this.
Is this a known incompatibility (i.e., should I try an older release of
StreamDevice), or are there any other reasons which can cause this
behaviour?
cu
  Gerrit
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Prev: Re: Probelm with ethernet interface of Galil controller Heinz Junkes via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Re: [EXTERNAL] Probelm with ethernet interface of Galil controller wangqisheng--- via Tech-talk
