1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH
From: Gerrit Kühn via Tech-talk <[email protected]>
Date: Fri, 17 Jan 2020 14:28:25 +0100
Am Fri, 17 Jan 2020 13:12:35 +0000
schrieb Mark Rivers <[email protected]>:
> > The built ioc complains about not finding the protocol file, but it
> > only looks in "."
>     - The line from your startup script that sets STREAM_PROTOCOL_PATH
epicsEnvSet("STREAM_PROTOCOL_PATH","/opt/rtapps/epics-3.15.3_long/aei/boostik/proto")
>     - The exact error message you are seeing when you say it does not
> find the protocol file?
Starting iocInit
## EPICS R3.15.3 $Date: Sun 2015-11-22 17:54:12 +0100$ ## EPICS Base built
Feb 17 2016
2020/01/17 14:25:32 Can't find readable file 'boostik.proto' in '.'
2020/01/17 14:25:32 while reading protocol 'setAmplifierDisable' for
[... various record initialization errors etc....]
> Are you seeing the following error message?  You should see this if the
> protocol path is really not set.
>           drvStreamInit: Warning! STREAM_PROTOCOL_PATH not set. Defaults
> to "."
No, I don't see that. That's why I wrote that it looks like the drvInit()
part is never called.
cu
  Gerrit
StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
