Ø
but when the user want send a value like 100 I want to send 10 to the device. How can I do this calculation before sending the value?
Ø
I tried SET VOLT (%.0f/10) but it doesn't work.
Look at the documentation here:
https://paulscherrerinstitute.github.io/StreamDevice/ao.html
For output formats using %f on the ao record you can use the ASLO and AOFF fields to scale the OVAL field.
On Behalf Of dmnr infn via Tech-talk
Sent: Monday, January 20, 2020 10:48 AM
To: [email protected]; [email protected]
Subject: Arithmetic calculations before sending a command
Hi everyone,
I have a DB with protocol in this manner:
record (ao, "RF:Setth_a0")
field (DESC, "Setting threshold accelerator")
field (DTYP, "stream")
field (OUT, "@MDO.proto setth_a0 $(PORT)")
field (DRVL, "0")
field (DRVH, "11230")
field (LOPR, "0")
field (HOPR, "11230")
field (PREC, "0")
setth_a0 {
out "SET VOLT %.0f";
With CS Studio I have a spinner associated to this PV, but when the user want send a value like 100 I want to send 10 to the device. How can I do this calculation before sending the value?
- Arithmetic calculations before sending a command dmnr infn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
<2020>
2025
2026
Spring Meeting? Patrick Oppermann via Tech-talk
<2020>
2025
2026
ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
Distributions
Download
Documents
Links
Licensing
