1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH
From: Gerrit Kühn via Tech-talk <[email protected]>
To: Tech-talk <[email protected]>
Date: Tue, 21 Jan 2020 09:24:30 +0100
Am Mon, 20 Jan 2020 07:18:23 +0100
schrieb Gerrit Kühn via Tech-talk <[email protected]>:
> > The scalcout record comes from the synApps "calc" module.  When you
> > build streamDevice your configure/RELEASE file needs to point to CALC
> > if you want to use that record.  The details vary between releases of
> > streamDevice.  When you build your application you also need to include
> > CALC if you enabled it when building streamDevice.
> That'll the the reason then. I have calc installed and built StreamDevice
> with it, but not the application. Still, it feels a bit strange that
> everything appears to continue to run after this error, just the path
> isn't set during initialisation.
Hm, I tried to fix this now by adding CALC to the application (both in the
configure/RELEASE and in the environment), but the record it creates is
still empty. No error messages to be seen during the build, though. What
do I have to check to find out where this is not being picked up properly?
cu
  Gerrit
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Ralph Lange via Tech-talk
StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Prev: RE: Arithmetic calculations before sending a command Mark Rivers via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Ralph Lange via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
