1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH
From: Gerrit Kühn via Tech-talk <[email protected]>
Date: Mon, 20 Jan 2020 07:18:23 +0100
Am Fri, 17 Jan 2020 14:12:53 +0000
schrieb Mark Rivers <[email protected]>:
> The scalcout record comes from the synApps "calc" module.  When you
> build streamDevice your configure/RELEASE file needs to point to CALC if
> you want to use that record.  The details vary between releases of
> streamDevice.  When you build your application you also need to include
> CALC if you enabled it when building streamDevice.
That'll the the reason then. I have calc installed and built StreamDevice
with it, but not the application. Still, it feels a bit strange that
everything appears to continue to run after this error, just the path
isn't set during initialisation.
cu
  Gerrit
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Prev: Re: Re: [EXTERNAL] Probelm with ethernet interface of Galil controller wangqisheng--- via Tech-talk
Next: AW: ca-gateway 2.1.2 compilation error Sintschuk, Michael via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
