1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: AW: ca-gateway 2.1.2 compilation error
From: "Sintschuk, Michael via Tech-talk" <[email protected]>
Date: Mon, 20 Jan 2020 16:00:23 +0000
The fix provided by Freddie Akeroyd:
worked for me. I could compile the module now but did not tested it with a gateway server.
Von: Sintschuk, Michael
Gesendet: Freitag, 20. Dezember 2019 15:53:28
An: [email protected]
Betreff: ca-gateway 2.1.2 compilation error
Hello,
I want to build the newest ca-gateway 2.1.2 module against the newest base-3.15.7, but it fails with the following errors:
/soft/epics/inst-3.15.7/ca-gateway/2.1.2 # make
make -C ./configure install
make[1]: Entering directory '/soft/epics/inst-3.15.7/ca-gateway/2.1.2/configure'
perl -CSD /soft/epics/base-3.15.7/bin/linux-x86_64/makeMakefile.pl O.linux-x86_64 ../..
mkdir O.Common
make -C O.linux-x86_64 -f ../Makefile TOP=../.. \
    T_A=linux-x86_64 install
make[2]: Entering directory '/soft/epics/inst-3.15.7/ca-gateway/2.1.2/configure/O.linux-x86_64'
perl -CSD /soft/epics/base-3.15.7/bin/linux-x86_64/convertRelease.pl checkRelease
make[2]: Leaving directory '/soft/epics/inst-3.15.7/ca-gateway/2.1.2/configure/O.linux-x86_64'
make[1]: Leaving directory '/soft/epics/inst-3.15.7/ca-gateway/2.1.2/configure'
make -C ./src install
make[1]: Entering directory '/soft/epics/inst-3.15.7/ca-gateway/2.1.2/src'
mkdir O.Common
make[2]: Entering directory '/soft/epics/inst-3.15.7/ca-gateway/2.1.2/src/O.linux-x86_64'
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gateStat.d  ../gateStat.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gateAsCa.d  ../gateAsCa.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gateAsyncIO.d  ../gateAsyncIO.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gateVc.d  ../gateVc.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gateAs.d  ../gateAs.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gateServer.d  ../gateServer.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gateResources.d  ../gateResources.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gatePv.d  ../gatePv.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -MM -MF gateway.d  ../gateway.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -c ../gateway.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -c ../gatePv.cc
/usr/bin/g++  -D_GNU_SOURCE -D_DEFAULT_SOURCE            -D_X86_64_  -DUNIX  -Dlinux     -O3   -Wall     -DSTAT_PVS -DRATE_STATS -DCONTROL_PVS -DCAS_DIAGNOSTICS -DHANDLE_EXCEPTIONS -DUSE_DENYFROM -DWITH_CAPUTLOG  -mtune=generic     -m64  -I. -I../O.Common -I. -I. -I.. -I../../include/compiler/gcc -I../../include/os/Linux -I../../include   -I/soft/epics/inst-3.15.7/caPutLog/3.6//include -I/soft/epics/base-3.15.7/include/compiler/gcc -I/soft/epics/base-3.15.7/include/os/Linux -I/soft/epics/base-3.15.7/include     -I/soft/epics/base-3.15.7/src/cas/generic -I/soft/epics/base-3.15.7/src/ca/legacy/pcas/generic    -c ../gateResources.cc
../gateResources.cc: In member function ‘void gateResources::putLog(FILE*, const char*, const char*, const char*, const gdd*, const gdd*)’:
../gateResources.cc:467:24: error: ‘VALUE_to_string’ was not declared in this scope
                        VALUE_to_string( acOldVal, 20, &oldVal, gddGetOurType(old_value) );
../gateResources.cc:467:24: note: suggested alternative: ‘dbr_sts_string’
                        dbr_sts_string
../gateResources.cc:470:16: error: ‘VALUE_to_string’ was not declared in this scope
                VALUE_to_string( acNewVal, 20, &newVal, gddGetOurType(new_value) );
../gateResources.cc:470:16: note: suggested alternative: ‘dbr_sts_string’
                dbr_sts_string
make[2]: *** [/soft/epics/base-3.15.7/configure/RULES_BUILD:236: gateResources.o] Error 1
make[2]: Leaving directory '/soft/epics/inst-3.15.7/ca-gateway/2.1.2/src/O.linux-x86_64'
make[1]: *** [/soft/epics/base-3.15.7/configure/RULES_ARCHS:58: install.linux-x86_64] Error 2
make[1]: Leaving directory '/soft/epics/inst-3.15.7/ca-gateway/2.1.2/src'
make: *** [/soft/epics/base-3.15.7/configure/RULES_DIRS:84: src.install] Error 2
Does anyone know what is causing that error?
I also compiled caPutLog 3.6 before that succecfully.
Best regards
Michael
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Next: Arithmetic calculations before sending a command dmnr infn via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: Probelm with ethernet interface of Galil controller [DLM=For-Official-Use-Only] CLIFT, Mark via Tech-talk
