1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH
To: Gerrit Kühn <[email protected]>
Date: Fri, 17 Jan 2020 14:12:53 +0000
> dbLoadDatabase "dbd/boostik.dbd"
> Declaration of recordtype(scalcout) preceeded full definition.
> Error at or before "}" in file "dbd/boostik.dbd" line 16095
The scalcout record comes from the synApps "calc" module.  When you build streamDevice your configure/RELEASE file needs to point to CALC if you want to use that record.  The details vary between releases of streamDevice.  When you build your application you also need to include CALC if you enabled it when building streamDevice.
Sent: Friday, January 17, 2020 7:48 AM
To: Mark Rivers
Cc: tech-talk
Am Fri, 17 Jan 2020 13:12:35 +0000
schrieb Mark Rivers <[email protected]>:
> > The built ioc complains about not finding the protocol file, but it
> > only looks in "."
> Are you seeing the following error message?  You should see this if the
> protocol path is really not set.
Ah, this finally made me look into the right place:
There was another error message always hidden outside my terminal (and not
coloured red ;-):
boostik_registerRecordDeviceDriver pdbbase
registerRecordDeviceDriver failed sel
Looks like this prevented the initialization from happening. The lines it
complains about are
recordtype(scalcout) {
device(scalcout, INST_IO, devscalcoutStream, "stream")
This was created by makeBaseApp. Looks like there is something missing in
the recordtype definition. What should be there?
For testing, I just commented out these lines, and now the PROTOCOL_PATH
gets parsed correctly and everything looks nice.
cu
  Gerrit
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Mark Rivers via Tech-talk
Prev: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
Next: RE: PicoScope support? Mark Rivers via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: StreamDevice not parsing STREAM_PROTOCOL_PATH Gerrit Kühn via Tech-talk
