Subject: Read/Write waveforms using Channel Access C API
From: Abdalla Ahmad via Tech-talk <[email protected]>
Date: Thu, 23 Jan 2020 11:28:13 +0000
Hi
I am working on a tool which reads a list of PVs (some of which are waveforms) and save those PVs values for later loading them. My problem is with the waveform record, is there a way to know the waveform’s size and read each element? The way I am reading PVs is structured where each DBR type (double, long, enum and string for now) has a struct like this:
typedef struct {
                chid channel;
                int status;
                struct dbr_ctrl_TYPE info;
                struct dbr_sts_TYPE data;
Best Regards,
Abdalla.
Re: Read/Write waveforms using Channel Access C API Ralph Lange via Tech-talk
Prev: Re:Re: usage of Java Channel Access Client 吴煊 via Tech-talk
Next: Re: Read/Write waveforms using Channel Access C API Ralph Lange via Tech-talk
Prev: Re: EPICS support for PoE Injector Hub Gessner, Spencer J. via Tech-talk
