1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Read/Write waveforms using Channel Access C API
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Thu, 23 Jan 2020 13:48:56 +0100
Just to make sure...
You are aware that there are a number of existing tools for reading and writing sets of PVs (PVTable in CS-Studio, MASAR, CASR, BURT and others) and you have found them not being solutions to your problem.
Cheers,
~Ralph
On Thu, 23 Jan 2020 at 12:28, Abdalla Ahmad via Tech-talk <[email protected]> wrote:
Hi
I am working on a tool which reads a list of PVs (some of which are waveforms) and save those PVs values for later loading them. My problem is with the waveform record, is there a way to know the waveform’s size and read each element? The way I am reading PVs is structured where each DBR type (double, long, enum and string for now) has a struct like this:
typedef struct {
                chid channel;
                int status;
                struct dbr_ctrl_TYPE info;
                struct dbr_sts_TYPE data;
Best Regards,
Abdalla.
RE: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Prev: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Next: RE: Read/Write waveforms using Channel Access C API Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
