Subject: Building Matlab Channel Access with Base R3.15.7
To: [email protected]
Date: Thu, 23 Jan 2020 09:24:04 -0800
Recent attempts to build the Matlab channel access extension on my OS X machine resulted in
In file included from mca.cpp:15:
In file included from /usr/local/epics/R3.15.7/base/include/cadef.h:40:
In file included from /usr/local/epics/R3.15.7/base/include/epicsThread.h:131:
In file included from /usr/local/epics/R3.15.7/base/include/epicsMutex.h:13:
In file included from /usr/local/epics/R3.15.7/base/include/epicsAssert.h:20:
/usr/local/epics/R3.15.7/base/include/compilerDependencies.h:19:10: fatal error: 'compilerSpecific.h' file not found
The mca extension build system doesn’t use any of the EPICS build stuff and thus must be told the location of the compiler-specific headers.
Also, the dbStaticHost library doesn’t seem to exist now, but removing the reference to it doesn’t seem to hurt things.
Here’s my quick fix — should work on Linux too, but not tested:
diff --git a/Makefile b/Makefile
index f6f63f8..fc21b2a 100644
--- a/Makefile
+++ b/Makefile
@@ -9,6 +9,7 @@
 ifeq (darwin, $(findstring darwin,$(EPICS_HOST_ARCH)))
 OS_CLASS = Darwin
+CMPLR_CLASS = clang
 MEXOUT = mexmac
 # For Octave:
 # MEXOUT = mex
@@ -17,6 +18,7 @@ endif
 ifeq (linux, $(findstring linux,$(EPICS_HOST_ARCH)))
 OS_CLASS = Linux
+CMPLR_CLASS = gcc
 MEXOUT = mexglx
 endif
@@ -52,12 +54,13 @@ FLAGS += -v
 # Includes -------------------------------------------
 # EPICS Base
 FLAGS += -I$(EPICS_BASE)/include
+FLAGS += -I$(EPICS_BASE)/include/compiler/$(CMPLR_CLASS)
 FLAGS += -I$(EPICS_BASE)/include/os/$(OS_CLASS)
 FLAGS += -DEPICS_DLL_NO
 # Libraries ------------------------------------------
 # EPICS Base
-FLAGS += -L$(EPICS_BASE)/lib/$(EPICS_HOST_ARCH) -ldbStaticHost -lCom -lca
+FLAGS += -L$(EPICS_BASE)/lib/$(EPICS_HOST_ARCH) -lCom -lca
 $(OUT):
        mkdir $(OUT)
Eric Norum
[email protected]
Prev: Re: EPICS support for PoE Injector Hub Gessner, Spencer J. via Tech-talk
Next: Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
Prev: Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
Next: possibility of using areaDetector to drive Varax 4343 detector ChenZhang@Gmail via Tech-talk
