Subject: Re: CAS-client thread issues in areaDetector IOC
From: "Wlodek, Jakub via Tech-talk" <[email protected]>
Date: Thu, 23 Jan 2020 17:32:45 +0000
Hi Mark,
As far as I know the cameras on the beamline are running on EPICS base versions ranging from 7.0.1 to 7.0.3, and the camera I am testing is running R7.0.3.1.
I just recompiled everything to make sure it has all been built against the correct base, and reran with valgrind, and it does seem that the issue is memory access:
First, I see this invalid write error message repeatedly:
==32571== Invalid write of size 8
==32571==    at 0x10FAD50: ellDelete (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x1110645: free_threadInfo.part.0 (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x111087F: start_routine (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x681C6DA: start_thread (pthread_create.c:463)
==32571==    by 0x7AE988E: clone (clone.S:95)
==32571==  Address 0x321915f8 is 8 bytes inside a block of size 170 free'd
==32571==    at 0x4C30D3B: free (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==32571==  Block was alloc'd at
==32571==    at 0x4C31B25: calloc (in /usr/lib/valgrind/vgpreload_memcheck-amd64-linux.so)
==32571==    by 0x11103B6: init_threadInfo (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x1111357: epicsThreadCreateOpt (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x1109E56: epicsThreadCreate (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x10B72D3: req_server (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x11107C7: start_routine (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==
Then finally the pthread error and Segfault, and valgrind lists "access not within mapped region" as the cause
pthread_join error No such process
==32571==
==32571== Process terminating with default action of signal 11 (SIGSEGV)
==32571==  Access not within mapped region at address 0x8
==32571==    by 0x1111D8B: epicsThreadMustJoin (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x10B68DE: destroy_tcp_client (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==    by 0x10B74FC: camsgtask (in /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp)
==32571==  If you believe this happened as a result of a stack
==32571==  overflow in your program's main thread (unlikely but
==32571==  possible), you can try to increase the size of the
==32571==  main thread stack using the --main-stacksize= flag.
==32571==  The main thread stack size used in this run was 8388608.
==32571==
==32571== HEAP SUMMARY:
==32571==     in use at exit: 95,935,018 bytes in 345,749 blocks
==32571==   total heap usage: 762,443 allocs, 128,925 frees, 8,380,446,680 bytes allocated
==32571==
==32571== LEAK SUMMARY:
==32571==    definitely lost: 532,602 bytes in 8,403 blocks
==32571==    indirectly lost: 0 bytes in 0 blocks
==32571==      possibly lost: 26,580,722 bytes in 37,063 blocks
==32571==    still reachable: 68,112,742 bytes in 315,085 blocks
==32571==                       of which reachable via heuristic:
==32571==                         newarray           : 1,920 bytes in 18 blocks
==32571==         suppressed: 0 bytes in 0 blocks
==32571== Rerun with --leak-check=full to see details of leaked memory
==32571==
==32571== For counts of detected and suppressed errors, rerun with: -v
==32571== Use --track-origins=yes to see where uninitialised values come from
==32571== ERROR SUMMARY: 2057 errors from 33 contexts (suppressed: 0 from 0)
Segmentation fault (core dumped)
Now the question becomes what have I done to cause this improper memory access - I ran an IOC from the same sources with ADSimDetector and did not see this issue, at least not in my limited test time.
Jakub
Sent: Thursday, January 23, 2020 12:06 PM
To: Wlodek, Jakub <[email protected]>
Cc: [email protected] <[email protected]>
Subject: RE: CAS-client thread issues in areaDetector IOC
Hi Jakub,
The errors are in the Channel Access server from EPICS base.  Questions:
-          Are your working cameras using the same version of base as the camera you are testing?
-          Are you sure you have rebuilt everything that your camera IOC uses with this version of base?
This looks to me like it could be a memory corruption problem, e.g. array out of bounds.  Those errors can remain hidden until you make small changes to your code.
I suggest running the IOC under valgrind to see if it detects memory allocation issues.
From: Tech-talk <[email protected]> On Behalf Of Wlodek, Jakub via Tech-talk
Sent: Thursday, January 23, 2020 9:44 AM
To: [email protected]
Subject: CAS-client thread issues in areaDetector IOC
Hi all,
I am currently ironing out a few bugs in an areaDetector driver I wrote a while ago for USB webcams, and doing some code cleanup (removing redundant code etc.), and I have encountered an
error I have not seen before, and I'm not sure what I have done to introduce it. I have ~15 beamline cameras working with this driver for time frames ranging from several months to a year, so I am
fairly certain this is a new issue. Essentially, after the IOC runs normally for  some time, I get the following stack trace dumped to the EPICS shell:
epicsEventTrigger: pthread_mutex_lock failed: Invalid argument
epicsEventMustTriggerThread CAS-client (0x7f4e4c042f00) can't proceed, suspending.
Dumping a stack trace of thread 'CAS-client':
[    0x55bf0e032393]: /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(epicsStackTrace+0x73)
[    0x55bf0e022dc5]: /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(cantProceed+0xc5)
[    0x55bf0dfabfb3]: /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(db_close_events+0x33)
[    0x55bf0dfd38df]: /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(destroy_tcp_client+0x8f)
[    0x55bf0dfd44fd]: /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(camsgtask+0x13d)
[    0x55bf0e02d7c8]: /epics/src/support/areaDetector/ADUVC/iocs/adUVCIOC/bin/linux-x86_64/adUVCApp(start_routine+0xf8)
[    0x7f4f922c46db]: /lib/x86_64-linux-gnu/libpthread.so.0(start_thread+0xdb)
[    0x7f4f9105988f]: /lib/x86_64-linux-gnu/libc.so.6(clone+0x3f)
Thread CAS-client (0x7f4e4c042f00) suspended
2020/01/23 10:28:32.930 ADUVC::acquireStop Stopping aquisition
2020/01/23 10:28:32.930 ADUVC::writeInt32 function=8 value=0
epicsEventMustTriggerThread CAS-client (0x7f4e4c0433d0) can't proceed, suspending.
Thread CAS-client (0x7f4e4c0433d0) suspended
Note how it does not crash after the first stack dump, and the number of times this gets printed varies, usually up to 10 times. I running the IOC with all
plugins except for NDStdArrays disabled, and capturing 640x480 images @ 30 fps. The currently updated code is available here: https://github.com/jwlodek/ADUVC, with the four
most recent commits being the code cleanup changes since the last known-working version. Could anyone help shine some light on what might be the issue here?
Jakub Wlodek
Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
Prev: Building Matlab Channel Access with Base R3.15.7 Eric Norum via Tech-talk
Next: Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
Prev: RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
