Subject: RE: possibility of using areaDetector to drive Varax 4343 detector
To: "'ChenZhang@Gmail'" <[email protected]>
Date: Fri, 24 Jan 2020 19:41:24 +0000
> I was wondering if it would be possible to use areaDetector to drive Varax 4343.
Do you know what software is provided with that detector?  There are 2 areaDetector drivers for Varax flat panel detectors, ADPerkinElmer and ADDexela.  Does the 4343 use the same SDK as either of these?
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of ChenZhang@Gmail via Tech-talk
Sent: Friday, January 24, 2020 1:26 PM
To: [email protected]
Subject: possibility of using areaDetector to drive Varax 4343 detector
Hi All,
We are trying to test the hardware triggering of Varax 4343 for HT-HEDM, and the vendor software does not support directly dumping frames from buffer to disk.  I was wondering if it would be possible to use areaDetector to drive Varax 4343.
Best,
Chen
Chen Zhang
Postdoc Researcher
Department of Mechanical Engineering
Colorado School of Mines
1500 Illinois Street Golden, CO 80401
[email protected]
[email protected]
Re: possibility of using areaDetector to drive Varax 4343 detector ChenZhang@Gmail via Tech-talk
Prev: possibility of using areaDetector to drive Varax 4343 detector ChenZhang@Gmail via Tech-talk
Next: RE: Getting images from area detector plugins Mark Rivers via Tech-talk
Next: Re: possibility of using areaDetector to drive Varax 4343 detector ChenZhang@Gmail via Tech-talk
