Subject: Re: possibility of using areaDetector to drive Varax 4343 detector
From: "ChenZhang@Gmail via Tech-talk" <[email protected]>
Date: Fri, 24 Jan 2020 13:54:41 -0600
The vendor software is called XIS (Windows), which allows us to write frames to a buffer, then manually save them to disk.  We will contact the vendor to confirm if a different SDK is used for this new model.
Chen
> On Jan 24, 2020, at 1:41 PM, Mark Rivers <[email protected]> wrote:
>> I was wondering if it would be possible to use areaDetector to drive Varax 4343.
> Do you know what software is provided with that detector?  There are 2 areaDetector drivers for Varax flat panel detectors, ADPerkinElmer and ADDexela.  Does the 4343 use the same SDK as either of these?
> Mark
> -----Original Message-----
> From: Tech-talk <[email protected]> On Behalf Of ChenZhang@Gmail via Tech-talk
> Sent: Friday, January 24, 2020 1:26 PM
> To: [email protected]
> Subject: possibility of using areaDetector to drive Varax 4343 detector
> Hi All,
> We are trying to test the hardware triggering of Varax 4343 for HT-HEDM, and the vendor software does not support directly dumping frames from buffer to disk.  I was wondering if it would be possible to use areaDetector to drive Varax 4343.
> Best,
> Chen
> Chen Zhang
> Postdoc Researcher
> Department of Mechanical Engineering
> Colorado School of Mines
> 1500 Illinois Street Golden, CO 80401
> [email protected]
> [email protected]
Re: possibility of using areaDetector to drive Varax 4343 detector Miceli, Antonino via Tech-talk
possibility of using areaDetector to drive Varax 4343 detector ChenZhang@Gmail via Tech-talk
RE: possibility of using areaDetector to drive Varax 4343 detector Mark Rivers via Tech-talk
Prev: RE: Getting images from area detector plugins Mark Rivers via Tech-talk
Next: Re: possibility of using areaDetector to drive Varax 4343 detector Miceli, Antonino via Tech-talk
Prev: RE: possibility of using areaDetector to drive Varax 4343 detector Mark Rivers via Tech-talk
