1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: RE: Getting images from area detector plugins
To: 'Randall Cayford' <[email protected]>
Date: Fri, 24 Jan 2020 23:17:53 +0000
Hi Randall,
I just verified that the ArrayData waveform record indeed contains a valid JPEG image.  I executed the following IDL commands, which read the waveform record via Channel Access and write it to a file called test.jpg.
IDL> t = caget('13SIM1:image1:ArrayData', v, max=100000L)
IDL> openw, 1, 'test.jpg'
IDL> writeu, 1, v
IDL> close, 1
I then double-clicked on that test.jpg file and it opened in Windows Photos fine.  I also dragged it into ImageJ and it opened fine.
Note that I had to tell caget() how many bytes to read (100000), which I specified manually just for this test.  It is actually about 50% larger than the actual JPEG data, so the file is larger than it needs to be.  That information is available over Channel Access from the CompressedSize_RBV PV.  CompressedSize is guaranteed to update before the ArrayData does, but the application needs to be fast enough so that the size it use for a read request applies to the next waveform update, because with compression the size is constantly changing.  Using PVA is much cleaner because the NTNDArray is atomic, the size is always correct.
From: Tech-talk <[email protected]> On Behalf Of Mark Rivers via Tech-talk
Sent: Friday, January 24, 2020 4:45 PM
Cc: '[email protected]' <[email protected]>
Hi Randall,
I have made the required changes to NDPluginStdArrays so that compressed NDArray data can be transmitted over Channel Access in $(P)$(R)ArrayData.
I just tested with ADSimDetector which was generating 1024x1024 UInt8 images at 10 Hz. NDPluginCodec was configured to compress with JPEG, 85% quality factor.  NDPluginStdArrays was getting its data from NDPluginCodec.
This is the result of camonitor of the first 500 elements in 13SIM:image1:ArrayData.  These are the first 3 arrays.
corvette:~/devel/areaDetector/ADCore>camonitor -#500 13SIM1:image1:ArrayData
13SIM1:image1:ArrayData 2020-01-24 16:16:12.255831 500 -1 -40 -1 -32 0 16 74 70 73 70 0 1 1 0 0 1 0 1 0 0 -1 -37 0 67 0 5 3 4 4 4 3 5 4 4 4 5 5 5 6 7 12 8 7 7 7 7 15 11 11 9 12 17 15 18 18 17 15 17 17 19 22 28 23 19 20 26 21 17 17 24 33 24 26 29 29 31 31 31 19 23 34 36 34 30 36 28 30 31 30 -1 -64 0 11 8 4 0 4 0 1 1 17 0 -1 -60 0 31 0 0 1 5 1 1 1 1 1 1 0 0 0 0 0 0 0 0 1 2 3 4 5 6 7 8 9 10 11 -1 -60 0 -75 16 0 2 1 3 3 2 4 3 5 5 4 4 0 0 1 125 1 2 3 0 4 17 5 18 33 49 65 6 19 81 97 7 34 113 20 50 -127 -111 -95 8 35 66 -79 -63 21 82 -47 -16 36 51 98 114 -126 9 10 22 23 24 25 26 37 38 39 40 41 42 52 53 54 55 56 57 58 67 68 69 70 71 72 73 74 83 84 85 86 87 88 89 90 99 100 101 102 103 104 105 106 115 116 117 118 119 120 121 122 -125 -124 -123 -122 -121 -120 -119 -118 -110 -109 -108 -107 -106 -105 -104 -103 -102 -94 -93 -92 -91 -90 -89 -88 -87 -86 -78 -77 -76 -75 -74 -73 -72 -71 -70 -62 -61 -60 -59 -58 -57 -56 -55 -54 -46 -45 -44 -43 -42 -41 -40 -39 -38 -31 -30 -29 -28 -27 -26 -25 -24 -23 -22 -15 -14 -13 -12 -11 -10 -9 -8 -7 -6 -1 -38 0 8 1 1 0 0 63 0 -93 12 85 114 24 -86 -20 49 85 -40 98 -85 -80 -59 87 97 -118 -82 67 21 93 -122 42 -69 12 85 118 24 -86 -20 49 85 -56 98 -85 -80 -59 87 97 -118 -82 -61 21 93 -122 42 -71 12 85 -14 -49 -19 121 -5 70 -1 0 -62 63 -10 -49 -121 -97 15 47 -1 0 -30 117 -52 58 -74 -83 3 -1 0 -57 -113 102 -126 22 31 -14 -37 -77 56 -1 0 87 -48 126 -13 38 63 -119 97 -118 -82 -61 21 93 -122 42 -69 12 85 118 24 -86 -28 49 85 -40 98 -85 -80 -59 87 97 -118 -82 -61 21 92 -122 42 -69 12 85 118 24 -86 -20 49 85 -40 98 -85 -112 -59 87 97 -118 -82 -61 21 93 -122 42 -69 12 85 114 24 -86 -20 49 85 -40 98 -85 -80 -59 87 97 -118 -82 67 21 93 -122 42
13SIM1:image1:ArrayData 2020-01-24 16:16:12.352025 500 -1 -40 -1 -32 0 16 74 70 73 70 0 1 1 0 0 1 0 1 0 0 -1 -37 0 67 0 5 3 4 4 4 3 5 4 4 4 5 5 5 6 7 12 8 7 7 7 7 15 11 11 9 12 17 15 18 18 17 15 17 17 19 22 28 23 19 20 26 21 17 17 24 33 24 26 29 29 31 31 31 19 23 34 36 34 30 36 28 30 31 30 -1 -64 0 11 8 4 0 4 0 1 1 17 0 -1 -60 0 31 0 0 1 5 1 1 1 1 1 1 0 0 0 0 0 0 0 0 1 2 3 4 5 6 7 8 9 10 11 -1 -60 0 -75 16 0 2 1 3 3 2 4 3 5 5 4 4 0 0 1 125 1 2 3 0 4 17 5 18 33 49 65 6 19 81 97 7 34 113 20 50 -127 -111 -95 8 35 66 -79 -63 21 82 -47 -16 36 51 98 114 -126 9 10 22 23 24 25 26 37 38 39 40 41 42 52 53 54 55 56 57 58 67 68 69 70 71 72 73 74 83 84 85 86 87 88 89 90 99 100 101 102 103 104 105 106 115 116 117 118 119 120 121 122 -125 -124 -123 -122 -121 -120 -119 -118 -110 -109 -108 -107 -106 -105 -104 -103 -102 -94 -93 -92 -91 -90 -89 -88 -87 -86 -78 -77 -76 -75 -74 -73 -72 -71 -70 -62 -61 -60 -59 -58 -57 -56 -55 -54 -46 -45 -44 -43 -42 -41 -40 -39 -38 -31 -30 -29 -28 -27 -26 -25 -24 -23 -22 -15 -14 -13 -12 -11 -10 -9 -8 -7 -6 -1 -38 0 8 1 1 0 0 63 0 -91 12 85 118 24 -86 -20 49 85 -40 98 -85 -112 -59 87 97 -118 -82 -61 21 93 -122 42 -69 12 85 114 24 -86 -20 49 85 -40 98 -85 -80 -59 87 97 -118 -82 67 21 93 -122 42 -69 12 85 -15 47 -19 121 -5 70 -1 0 -62 65 -10 -49 -121 -97 15 47 -1 0 -30 75 -52 58 -74 -83 3 -1 0 -57 -9 102 -126 22 31 -14 -57 -77 56 -1 0 89 -48 126 -17 38 79 -106 97 -118 -82 -61 21 93 -122 42 -71 12 85 118 24 -86 -20 49 85 -40 98 -85 -80 -59 87 33 -118 -82 -61 21 93 -122 42 -69 12 85 118 24 -86 -28 49 85 -40 98 -85 -80 -59 87 97 -118 -82 -61 21 92 -122 42 -69 12 85 118 24 -86 -20 49 85 -40 98 -85 -112 -59 87 97 -118 -82 -61 21 93 -122 42
13SIM1:image1:ArrayData 2020-01-24 16:16:12.450525 500 -1 -40 -1 -32 0 16 74 70 73 70 0 1 1 0 0 1 0 1 0 0 -1 -37 0 67 0 5 3 4 4 4 3 5 4 4 4 5 5 5 6 7 12 8 7 7 7 7 15 11 11 9 12 17 15 18 18 17 15 17 17 19 22 28 23 19 20 26 21 17 17 24 33 24 26 29 29 31 31 31 19 23 34 36 34 30 36 28 30 31 30 -1 -64 0 11 8 4 0 4 0 1 1 17 0 -1 -60 0 31 0 0 1 5 1 1 1 1 1 1 0 0 0 0 0 0 0 0 1 2 3 4 5 6 7 8 9 10 11 -1 -60 0 -75 16 0 2 1 3 3 2 4 3 5 5 4 4 0 0 1 125 1 2 3 0 4 17 5 18 33 49 65 6 19 81 97 7 34 113 20 50 -127 -111 -95 8 35 66 -79 -63 21 82 -47 -16 36 51 98 114 -126 9 10 22 23 24 25 26 37 38 39 40 41 42 52 53 54 55 56 57 58 67 68 69 70 71 72 73 74 83 84 85 86 87 88 89 90 99 100 101 102 103 104 105 106 115 116 117 118 119 120 121 122 -125 -124 -123 -122 -121 -120 -119 -118 -110 -109 -108 -107 -106 -105 -104 -103 -102 -94 -93 -92 -91 -90 -89 -88 -87 -86 -78 -77 -76 -75 -74 -73 -72 -71 -70 -62 -61 -60 -59 -58 -57 -56 -55 -54 -46 -45 -44 -43 -42 -41 -40 -39 -38 -31 -30 -29 -28 -27 -26 -25 -24 -23 -22 -15 -14 -13 -12 -11 -10 -9 -8 -7 -6 -1 -38 0 8 1 1 0 0 63 0 -87 12 85 118 24 -86 -28 49 85 -40 98 -85 -80 -59 87 97 -118 -82 -61 21 92 -122 42 -69 12 85 118 24 -86 -20 49 85 -40 98 -85 -112 -59 87 97 -118 -82 -61 21 93 -122 42 -102 -26 123 91 11 25 -17 -17 -18 97 -75 -76 -74 -119 -90 -98 121 -92 9 28 72 -93 44 -20 -57 -123 80 1 36 -98 0 21 -7 -1 0 -5 87 126 -48 87 95 19 47 -92 -16 -81 -123 101 -102 -41 -63 -106 -46 -115 -52 65 73 53 71 83 -111 36 -128 -14 -79 2 1 72 -49 57 1 -40 110 -38 -79 -8 52 49 85 -56 98 -85 -80 -59 87 97 -118 -82 -61 21 93 -122 42 -71 12 85 118 24 -86 -20 49 85 -40 98 -85 -80 -59 87 33 -118 -82 -61 21 93 -122 42 -69 12 85 118 24 -86 -28 49 85 -40
I believe these data make sense as the start of a JPEG image.  The first 2 bytes of each array are -1 -40 which is hex FF D8.  According to Wikipedia (https://en.wikipedia.org/wiki/JPEG#Syntax_and_structure) FF D8 is JPEG “Start Of Image”, which makes sense for the first 2 bytes in stream.
The changes are on the master branch on Github.
CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
Getting images from area detector plugins Randall Cayford via Tech-talk
RE: Getting images from area detector plugins Mark Rivers via Tech-talk
Re: Getting images from area detector plugins Wang Xiaoqiang via Tech-talk
Re: Getting images from area detector plugins Mark Rivers via Tech-talk
Re: Getting images from area detector plugins Randall Cayford via Tech-talk
Prev: RE: Getting images from area detector plugins Mark Rivers via Tech-talk
Next: caQtDM on android Mezger Anton Christian (PSI) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
