Subject: RE: CAS-client thread issues in areaDetector IOC
To: "'Wlodek, Jakub'" <[email protected]>, Michael Davidsaver <[email protected]>
Date: Mon, 27 Jan 2020 18:57:13 +0000
I suggest using the simDetector and a Python script for testing.  Start the simDetector with no plugins enabled, and have Python just press start and stop in a loop.  If that does not fail then enable plugins one at a time until you find a minimal configuration is that will generate the error.  Then others can try to reproduce.
I just did a lot of clicking on the simDetector with Ubuntu 18.04 and base 7.0.3.1 and cannot make it fail.
Sent: Monday, January 27, 2020 11:35 AM
To: Michael Davidsaver <[email protected]>
Cc: Mark Rivers <[email protected]>; [email protected]
Subject: Re: CAS-client thread issues in areaDetector IOC
Hi Mark
Is this error consistent or intermittent?
I observe it every time I start an IOC, but not immediately after startup, it shows up after some time with normal operation (acquire start/stop, enable/disable plugins etc.)
I can't seem to nail down a specific series of steps that leads to the error, but it seems consistent. I also re cloned and rebuilt everything again from scratch in a different location
to make sure something wasn't messed up in that specific set of sources, and I saw the same issue.
Jakub
Sent: Monday, January 27, 2020 12:28 PM
To: Wlodek, Jakub <[email protected]>
Cc: Mark Rivers <[email protected]>; [email protected] <[email protected]>
On 1/27/20 7:45 AM, Wlodek, Jakub wrote:
> In addition, the following tests showed some error message, but were seemingly re-run successfully:
We have some tests which intentionally provoke error to ensure that
they can be handled correctly.  Unless you see any "fail" instead of "ok",
then the tests are passing and we'll have to look elsewhere.
> iocshTest.t ................... 1/19 Command no_such_command not found.
> iocsh Error: Break
> Can't open no_such_file.cmd: No such file or directory
> iocshTest.t ................... ok
> chfPluginTest.t ............ 1/1433 chfConfigParseStart: plugin pvt alloc failed
> chfPluginTest.t ............ ok
> netget.t ................ 1/3 **** The executable "caRepeater" couldn't be located
> **** because of errno = "No such file or directory".
> **** You may need to modify your PATH environment variable.
> **** Unable to start "CA Repeater" process.
> netget.t ................ ok
> There were also several tests that listed json parsing errors.
> Regards,
> Jakub
> *From:* Michael Davidsaver <[email protected]>
> *Sent:* Friday, January 24, 2020 4:52 PM
> *To:* Wlodek, Jakub <[email protected]>
> *Cc:* Mark Rivers <[email protected]>; [email protected] <[email protected]>
> *Subject:* Re: CAS-client thread issues in areaDetector IOC
> On 1/24/20 10:15 AM, Mark Rivers wrote:
>> Ø  Could it be that there is a problem with something in the newest release of epics-base?
>> You are running 7.0.3 now.  If you go back to 7.0.3.1 does the problem re-appear?
> If the assert() failure does re-appear, could you run the base unittests and report any which don't pass?
>> make runtests
Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
RE: CAS-client thread issues in areaDetector IOC Mark Rivers via Tech-talk
Re: CAS-client thread issues in areaDetector IOC Michael Davidsaver via Tech-talk
Prev: RE: XSPRESS3 hdf5 problems Mark Rivers via Tech-talk
Next: Re: XSPRESS3 hdf5 problems John Dobbins via Tech-talk
Prev: Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
Next: Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
