Subject: RE: areaDetector crashes EPICS IOC and autosave failure
To: Jong Woo Kim <[email protected]>
Cc: "[email protected]" <[email protected]>, Jong Woo Kim <[email protected]>
Date: Thu, 30 Jan 2020 17:39:49 +0000
Hi Jong Woo,
Ø     Actually data hasn't been collected
You have also not told us how you are collecting the data.  Are you using the Stream interface or the FileWriter interface? Are you using an areaDetector plugin to save the data, or are you just using the HDF5 file produced by the Eiger server?
From: Tech-talk <[email protected]> On Behalf Of Jong Woo Kim via Tech-talk
Sent: Thursday, January 30, 2020 10:33 AM
To: [email protected]
Cc: Jong Woo Kim <[email protected]>; Jong Woo Kim <[email protected]>
Subject: areaDetector crashes EPICS IOC and autosave failure
Hello,
When the data collection is done on 'eigerDetector.adl', EPICS IOC is crashed and actually data hasn't been collected.
In addition, whatever parameters I changed on 'eigerDetector' are not applied in autosave. These are the summary followed by the message.
a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message)
     I made sure that this file has contents and it is in a right folder
          support/calc-R3-7-3/calcApp/Db/sseq_settings.req
          support/calc-R3-7-3/db/sseq_settings.req
b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message)
     It keeps trying to save settings every 30 second as it is set on the first purple line. But it can't.
c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC (Red in the following message)
--------------------------------------------------- Message on monitor--------------------------------------------------------------
## EPICS R3.15.6
## EPICS Base built Dec  2 2019
reboot_restore: entry for file 'auto_settings.sav'
reboot_restore: Found filename 'auto_settings.sav' in restoreFileList.
*** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) ***
save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200127-151325'
save_restore: Can't write backup file.
2020/01/27 15:13:25.455 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CLEAR
EIG1:cam1:FWClear devAsynInt32::initCommon drvUserCreate
Bad init_rec return value  PV: EIG1:cam1:FWClear ao: init_record
*** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) ***
reboot_restore: done with file 'auto_settings.sav'
# Avoid deluge of messages when debugging
#dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive
# save things every thirty seconds
create_monitor_set("auto_settings.req", 30, "P= EIG1:")
save_restore:readReqFile: unable to open file sseq_settings.req. Exiting.
epics> save_restore: Can't connect to all status PV(s)
auto_settings.sav: 1330 of 1330 PV's connected
save_restore: Can't connect to status PV(s) for list 'auto_settings.sav'
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151357]
save_restore:write_save_file: Can't write save file. [200127-151357]
../save_restore.c(1774): [0xd]=write_it:Permission denied
save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151427]
save_restore:write_save_file: Can't write save file. [200127-151427]
Segmentation fault (core dumped)
[iocEiger]$
areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Prev: RE: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Next: Re: CAS-client thread issues in areaDetector IOC Wlodek, Jakub via Tech-talk
Prev: Re: areaDetector crashes EPICS IOC and autosave failure Mark Rivers via Tech-talk
Next: Problems with scaler record and base 7.0.3.1 Mark Rivers via Tech-talk
