Sent: Wednesday, February 5, 2020 1:45:36 PM To: Jong Woo Kim <[email protected]> Cc: Jennings, Guy <[email protected]>; [email protected] >> EPICS Tech Talk <[email protected]> Subject: Re: areaDetector crashes EPICS IOC and autosave failure What version of Linux are you running?
Sent from my iPhone On Feb 5, 2020, at 2:16 PM, Jong Woo Kim via Tech-talk <[email protected]<mailto:[email protected]>> wrote: Thank you Mark, Michael and Guy. But I couldn't find any core dump files. There is folder /var/lib/systemd/coredump. But there is nothing in there. I also used the command 'coredumpctl'. I think something should appear if any. $ coredumpctl list No coredumps found. The message keeps saying like below. Segmentation fault (core dumped) What's wrong? ________________________________ From: Jennings, Guy <[email protected]<mailto:[email protected]>> Sent: Wednesday, February 5, 2020 6:39 AM To: Jong Woo Kim <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> >> EPICS Tech Talk <[email protected]<mailto:[email protected]>> Subject: Re: areaDetector crashes EPICS IOC and autosave failure To get a core dump out of systemd use the coredumpctl command. See man coredumpctl or try coredumpctl debug > On Feb 4, 2020, at 4:56 PM, Jong Woo Kim via Tech-talk <[email protected]<mailto:[email protected]>> wrote: > > Hi Mark, > > Thank you so much for letting me know. I could not find "core" in eigerDetectorApp or in any folder around it. Instead, I found systemd-coredump in "/usr/lib/systemd/systemd-coredump". > The following is the result of running gdb and bt. It seems okay to me. Is this a wrong file? > > $ gdb systemd-coredump > GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-115.el7 > Copyright (C) 2013 Free Software Foundation, Inc. > License GPLv3+: GNU GPL version 3 or later <https://urldefense.proofpoint.com/v2/url?u=http-3A__gnu.org_licenses_gpl.html&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=yfk-0Txa5oue0MIb0KpWAdOXJcpJMv_fkmChV49LPGY&m=DlM9V0xn01k9a4UG8Jo1piG8GCzfUEywJvqtMidZ8j0&s=5SqrqeDD_u5q7YAVAq3G5t22J2QiTSh0ygG4_hwdBFM&e= > > This is free software: you are free to change and redistribute it. > There is NO WARRANTY, to the extent permitted by law. Type "show copying" > and "show warranty" for details. > This GDB was configured as "x86_64-redhat-linux-gnu". > For bug reporting instructions, please see: > <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.gnu.org_software_gdb_bugs_&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=yfk-0Txa5oue0MIb0KpWAdOXJcpJMv_fkmChV49LPGY&m=DlM9V0xn01k9a4UG8Jo1piG8GCzfUEywJvqtMidZ8j0&s=yiatgN5YlRyxrEDD5VI0j6rOEa6rPgM-oDRq8LFNNNQ&e= >... > Reading symbols from /usr/lib/systemd/systemd-coredump...Reading symbols from /usr/lib/systemd/systemd-coredump...(no debugging symbols found)...done. > (no debugging symbols found)...done. > Missing separate debuginfos, use: debuginfo-install systemd-219-67.el7_7.2.x86_64 > (gdb) bt > No stack. > > > > > From: Mark Rivers <[email protected]<mailto:[email protected]>> > Sent: Friday, January 31, 2020 4:56 PM > To: Jong Woo Kim <[email protected]<mailto:[email protected]>> > Cc: [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> > Subject: RE: areaDetector crashes EPICS IOC and autosave failure > > Hi Jong Woo, > > Ø $ gdb /path/to/ADEiger_executable core --- > coredump doesn't work either > > I was not clear in my instructions. “/path/to/ADEiger_executable” is not what you should type, you should type the actual path, which is probably something like: > > EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/bin/linux-x86_64/eigerDetectorApp. > > And “core” is the name of the actual core.* file that was created when you got the core dump message when the IOC crashed. It is probably in your iocBoot/iocEiger directory. But on some systems it can be put in /var or somewhere else. > > Mark > > > > From: Jong Woo Kim <[email protected]<mailto:[email protected]>> > Sent: Friday, January 31, 2020 5:45 PM > To: Mark Rivers <[email protected]<mailto:[email protected]>> > Cc: [email protected]<mailto:[email protected]> > Subject: Re: areaDetector crashes EPICS IOC and autosave failure > > Hi Mark, > > Thank you so much. I resolved first two issues. But I'm still working on the last one 'eigerDetector crashes EPICS IOC' ( e.i. Segmentation fault (core dumped) ) > I wasn't able to find where it crashed. The following is the message I've got. > > Note that the version of areaDetector, ADEiger, ADCore and EPICS base are R3-7, R2-7, R3-8, 3-15-6, respectively. > We're using FileWriter interface to save data files. > ____________________________________________________________ > > $ gdb /path/to/ADEiger_executable core --- > coredump doesn't work either > GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-115.el7 > Copyright (C) 2013 Free Software Foundation, Inc. > License GPLv3+: GNU GPL version 3 or later <https://urldefense.proofpoint.com/v2/url?u=http-3A__gnu.org_licenses_gpl.html&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=yfk-0Txa5oue0MIb0KpWAdOXJcpJMv_fkmChV49LPGY&m=DlM9V0xn01k9a4UG8Jo1piG8GCzfUEywJvqtMidZ8j0&s=5SqrqeDD_u5q7YAVAq3G5t22J2QiTSh0ygG4_hwdBFM&e= > > This is free software: you are free to change and redistribute it. > There is NO WARRANTY, to the extent permitted by law. Type "show copying" > and "show warranty" for details. > This GDB was configured as "x86_64-redhat-linux-gnu". > For bug reporting instructions, please see: > <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.gnu.org_software_gdb_bugs_&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=yfk-0Txa5oue0MIb0KpWAdOXJcpJMv_fkmChV49LPGY&m=DlM9V0xn01k9a4UG8Jo1piG8GCzfUEywJvqtMidZ8j0&s=yiatgN5YlRyxrEDD5VI0j6rOEa6rPgM-oDRq8LFNNNQ&e= >... > /path/to/ADEiger_executable: No such file or directory. > .../EPICS/synApps_6_1/support/areaDetector-R3-7/ADEiger/iocs/eigerIOC/iocBoot/iocEiger/autosave/core: No such file or directory. > (gdb) > > ____________________________________________________________ > > I researched for coredump files > ____________________________________________________________ > > .../systemd/coredump.conf > .../bin/coredumpctl > .../bin/systemd-coredumpctl > .../lib/systemd/systemd-coredump > .../share/bash-completion/completions/coredumpctl > .../share/man/man1/coredumpctl.1.gz > .../share/man/man5/coredump.conf.5.gz > .../share/man/man5/coredump.conf.d.5.gz > .../share/man/man8/systemd-coredump.8.gz > .../share/zsh/site-functions/_coredumpctl > .../include/config/coredump.h > .../include/config/dev/coredump.h > .../include/config/want/dev/coredump.h > .../include/linux/coredump.h > .../include/linux/devcoredump.h > .../include/config/coredump.h > .../include/config/dev/coredump.h > .../include/config/want/dev/coredump.h > .../include/linux/coredump.h > .../include/linux/devcoredump.h > .../include/config/coredump.h > .../include/config/dev/coredump.h > .../include/config/want/dev/coredump.h > .../include/linux/coredump.h > .../include/linux/devcoredump.h > .../lib/systemd/coredump > ____________________________________________________________ > > This is one of examples that results from gdb. > ____________________________________________________________ > > $ gdb /var/lib/systemd/coredump > GNU gdb (GDB) Red Hat Enterprise Linux 7.6.1-115.el7 > Copyright (C) 2013 Free Software Foundation, Inc. > License GPLv3+: GNU GPL version 3 or later <https://urldefense.proofpoint.com/v2/url?u=http-3A__gnu.org_licenses_gpl.html&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=yfk-0Txa5oue0MIb0KpWAdOXJcpJMv_fkmChV49LPGY&m=DlM9V0xn01k9a4UG8Jo1piG8GCzfUEywJvqtMidZ8j0&s=5SqrqeDD_u5q7YAVAq3G5t22J2QiTSh0ygG4_hwdBFM&e= > > This is free software: you are free to change and redistribute it. > There is NO WARRANTY, to the extent permitted by law. Type "show copying" > and "show warranty" for details. > This GDB was configured as "x86_64-redhat-linux-gnu". > For bug reporting instructions, please see: > <https://urldefense.proofpoint.com/v2/url?u=http-3A__www.gnu.org_software_gdb_bugs_&d=DwIGaQ&c=l45AxH-kUV29SRQusp9vYR0n1GycN4_2jInuKy6zbqQ&r=yfk-0Txa5oue0MIb0KpWAdOXJcpJMv_fkmChV49LPGY&m=DlM9V0xn01k9a4UG8Jo1piG8GCzfUEywJvqtMidZ8j0&s=yiatgN5YlRyxrEDD5VI0j6rOEa6rPgM-oDRq8LFNNNQ&e= >... > /var/lib/systemd/coredump: Success. > > > > > From: Mark Rivers <[email protected]<mailto:[email protected]>> > Sent: Thursday, January 30, 2020 10:35 AM > To: Jong Woo Kim <[email protected]<mailto:[email protected]>> > Cc: Jong Woo Kim <[email protected]<mailto:[email protected]>>; [email protected]<mailto:[email protected]> <[email protected]<mailto:[email protected]>> > Subject: RE: areaDetector crashes EPICS IOC and autosave failure > > Hi Jong Woo, > > You have not told us what version of ADEiger, ADCore, EPICS base, etc. you are using. > > Ø a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message) > > Did you uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugin_settings.req? > #file "sseqRecord_settings.req", P=$(P), S=AcquireSequence > > If so you also need to uncomment this line from ADCore/iocBoot/EXAMPLE_commonPlugins.cmd > #set_requestfile_path("$(CALC)/calcApp/Db") > > Ø b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message) > Ø ../save_restore.c(1774): [0xd]=write_it:Permission denied > > That error seems pretty simple. It is a file permission problem. The files in that directory, or the directory itself, must not have write permission for the account that is running ADEiger application. Fix the file permissions. > > Ø c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC (Red in the following message) > Ø Actually data hasn't been collected > Segmentation fault (core dumped) > > You have a core dump file. You need to run gdb on that to find where it crashed. > Run this: > gdb /path/to/ADEiger_executable core.xxx > > where core.xxx is the name of your core dump file. Once you get the gdb> prompt type this command > backtrace > > Mark > > > From: Tech-talk <[email protected]<mailto:[email protected]>> On Behalf Of Jong Woo Kim via Tech-talk > Sent: Thursday, January 30, 2020 10:33 AM > To: [email protected]<mailto:[email protected]> > Cc: Jong Woo Kim <[email protected]<mailto:[email protected]>>; Jong Woo Kim <[email protected]<mailto:[email protected]>> > Subject: areaDetector crashes EPICS IOC and autosave failure > > Hello, > > When the data collection is done on 'eigerDetector.adl', EPICS IOC is crashed and actually data hasn't been collected. > In addition, whatever parameters I changed on 'eigerDetector' are not applied in autosave. These are the summary followed by the message. > > a) It keeps failing to open 'sseq_setting.req' file (Purple in the following message) > I made sure that this file has contents and it is in a right folder > support/calc-R3-7-3/calcApp/Db/sseq_settings.req > support/calc-R3-7-3/db/sseq_settings.req > > b) It keeps failing to writing 'auto_settings.sav' file (Blue in the following message) > It keeps trying to save settings every 30 second as it is set on the first purple line. But it can't. > > c) When the data acquisition is done on eigerDetector, it crashes EPICS IOC (Red in the following message) > Actually data hasn't been collected > > > --------------------------------------------------- Message on monitor-------------------------------------------------------------- > > ############################################################################ > ## EPICS R3.15.6 > ## EPICS Base built Dec 2 2019 > ############################################################################ > reboot_restore: entry for file 'auto_settings.sav' > reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. > *** restoring from './autosave/auto_settings.sav' at initHookState 6 (before record/device init) *** > save_restore:myFileCopy: Can't open file './autosave/auto_settings.sav_200127-151325' > save_restore: Can't write backup file. > 2020/01/27 15:13:25.455 asynPortDriver:drvUserCreate: addr=0, cannot find parameter CLEAR > EIG1:cam1:FWClear devAsynInt32::initCommon drvUserCreate > Bad init_rec return value PV: EIG1:cam1:FWClear ao: init_record > > reboot_restore: entry for file 'auto_settings.sav' > reboot_restore: Found filename 'auto_settings.sav' in restoreFileList. > *** restoring from './autosave/auto_settings.sav' at initHookState 7 (after record/device init) *** > reboot_restore: done with file 'auto_settings.sav' > > iocRun: All initialization complete > # Avoid deluge of messages when debugging > #dbpf $(PREFIX)cam1:PoolUsedMem.SCAN Passive > # save things every thirty seconds > create_monitor_set("auto_settings.req", 30, "P= EIG1:") > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > save_restore:readReqFile: unable to open file sseq_settings.req. Exiting. > epics> save_restore: Can't connect to all status PV(s) > auto_settings.sav: 1330 of 1330 PV's connected > save_restore: Can't connect to status PV(s) for list 'auto_settings.sav' > save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151357] > *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** > save_restore:write_save_file: Can't write save file. [200127-151357] > *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** > ../save_restore.c(1774): [0xd]=write_it:Permission denied > save_restore:write_it - unable to open file './autosave/auto_settings.sav' [200127-151427] > *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** > save_restore:write_save_file: Can't write save file. [200127-151427] > *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** *** > ../save_restore.c(1774): [0xd]=write_it:Permission denied > Segmentation fault (core dumped) > [iocEiger]$
| ANJ, 19 Mar 2026 |
Home
News
About
Talk
Base
Modules
Extensions
