1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Fwd: send/receive waveform over network.
Date: Thu, 6 Feb 2020 17:14:35 +0000
Forgot to CC tech-talk.
Sent from my iPhone
Begin forwarded message:
From: Mark Rivers <[email protected]<mailto:[email protected]>>
Date: February 6, 2020 at 11:11:17 AM CST
To: Tomasz Brys <[email protected]<mailto:[email protected]>>
Subject: Re: send/receive waveform over network.
Hi Tomasz,
There is no limitation that prevents Stream Device from sending a large waveform. In fact I have done so with the Tabor waveform generator in the synApps "ip" module.
https://github.com/epics-modules/ip/blob/master/ipApp/Db/Tabor8024.proto
Sent from my iPhone
On Feb 6, 2020, at 11:02 AM, Tomasz Brys via Tech-talk <[email protected]<mailto:[email protected]>> wrote:
Hi
I have a beginner question. I want to send via ethernet (TCP/UDP) a waveform from IOC to external device. The waveform consists of binary data and can be big so the Stream Device is not a solution. To simplify the problem, I tested it with longout and a local server listening on port 7777.
In my startup command I have:
drvAsynIPPortConfigure("det-stream", "localhost:7777")
Then I load my db, which is very simple:
record(longout, "p") {
   field(VAL, "1")
   field(DTYP, "asynInt32")
   field(OUT,  "@asyn(det-stream)")
I started IOC, no errors. But how I can send the VAL over TCP?
"dbpf p 2" does not work, neither "dbpf p.PROC"
Do I have to write my own implementation of asynDriver?
Is it any differences between sending longout and waveform?
Regards
Tomasz
send/receive waveform over network. Tomasz Brys via Tech-talk
Prev: send/receive waveform over network. Tomasz Brys via Tech-talk
Next: Re: areaDetector crashes EPICS IOC and autosave failure Jong Woo Kim via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Re: send/receive waveform over network. Mark Rivers via Tech-talk
