1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: SNCSEQ Error Windows
To: "Hetz, Benjamin" <[email protected]>
Date: Tue, 11 Feb 2020 11:59:38 +0000
Can you send the Makefile you are using, and a listing of the files in the source directory?
From: Tech-talk <[email protected]> on behalf of Hetz, Benjamin via Tech-talk <[email protected]>
Sent: Tuesday, February 11, 2020 3:06 AM
To: [email protected]
Subject: SNCSEQ Error Windows
Hello,
I am having following problem:
I am using the Windows build of EPICS with VS compiler and Strawbery Perl. Compiling SNCSeq 2.2.8 went fine and also its demo/example files were build in seq-2_2_8\examples and running.
Following the instruction from https://www-csr.bessy.de/control/SoftDist/sequencer/Compiling.html I created an example IOC and changed SNCSEQ in configure/REALESE to "C:/opt/epics/base-7_0_3/modules/seq-2_2_8".
Running now gmake in the example ioc top dir yields following error:
gmake[3]: *** No rule to make target 'sncExample.obj', needed by 'interlocksSupport.lib'.  Stop.
gmake[3]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp/src/O.windows-x64-static'
gmake[2]: *** [C:/opt/epics/base-7_0_3/configure/RULES_ARCHS:58: install.windows-x64-static] Error 2
gmake[2]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp/src'
gmake[1]: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84: src.install] Error 2
gmake[1]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp'
gmake: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84: interlocksApp.install] Error 2
May anyone please help?
Thank you, Ben
RE: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Prev: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Next: RE: SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
