Subject: RE: SNCSEQ Error Windows
From: "Hetz, Benjamin via Tech-talk" <[email protected]>
Date: Tue, 11 Feb 2020 12:09:40 +0000
Sure, the Files in the Source directory are the one build by makeBaseApp -t example:
dbSubExample.c
dbSubExample.dbd
devinterlocksVersion.c
devinterlocksVersion.dbd
devXxxSoft.c
initTrace.c
initTrace.dbd
interlocksHello.c
interlocksHello.dbd
interlocksMain.cpp
Makefile
O.Common
O.windows-x64-static
sncExample.dbd
sncExample.stt
sncProgram.st
xxxRecord.c
xxxRecord.dbd
xxxSupport.dbd
And the Makefile is:
TOP=../..
include $(TOP)/configure/CONFIG
#  ADD MACRO DEFINITIONS BELOW HERE
# Use typed rset structure (see 3.16.1 release notes)
USR_CPPFLAGS += -DUSE_TYPED_RSET
# xxxRecord.h will be created from xxxRecord.dbd
DBDINC += xxxRecord
# Install xxxSupport.dbd into <top>/dbd
DBD += xxxSupport.dbd
# Build an IOC support library
LIBRARY_IOC += interlocksSupport
# Compile and add code to the support library
interlocksSupport_SRCS += xxxRecord.c
interlocksSupport_SRCS += devXxxSoft.c
# Link locally-provided code into the support library,
# rather than directly into the IOC application, that
# causes problems on Windows DLL builds
interlocksSupport_SRCS += dbSubExample.c
interlocksSupport_SRCS += devinterlocksVersion.c
interlocksSupport_SRCS += interlocksHello.c
interlocksSupport_SRCS += initTrace.c
interlocksSupport_LIBS += $(EPICS_BASE_IOC_LIBS)
# Auto-generate a header file containing a version string.
# Version comes from the VCS if available, else date+time.
GENVERSION = interlocksVersion.h
# Macro name
GENVERSIONMACRO = interlocksVERSION
# Build the IOC application
PROD_IOC = interlocks
# interlocks.dbd will be created and installed
DBD += interlocks.dbd
# interlocks.dbd will include these files:
interlocks_DBD += base.dbd
interlocks_DBD += xxxSupport.dbd
interlocks_DBD += dbSubExample.dbd
interlocks_DBD += devinterlocksVersion.dbd
interlocks_DBD += interlocksHello.dbd
interlocks_DBD += initTrace.dbd
# interlocks_registerRecordDeviceDriver.cpp derives from interlocks.dbd
interlocks_SRCS += interlocks_registerRecordDeviceDriver.cpp
# Build the main IOC entry point where needed
interlocks_SRCS_DEFAULT += interlocksMain.cpp
interlocks_SRCS_vxWorks += -nil-
# Link in the code from our support library
interlocks_LIBS += interlocksSupport
# To build SNL programs, SNCSEQ must be defined
# in the <top>/configure/RELEASE file
ifneq ($(SNCSEQ),)
    # Build sncExample into interlocksSupport
    sncExample_SNCFLAGS += +r
    interlocks_DBD += sncExample.dbd
    # A .stt sequence program is *not* pre-processed:
    interlocksSupport_SRCS += sncExample.stt
    interlocksSupport_LIBS += seq pv
    interlocks_LIBS += seq pv
    # Build sncProgram as a standalone program
    PROD_HOST += sncProgram
    sncProgram_SNCFLAGS += +m
    # A .st sequence program *is* pre-processed:
    sncProgram_SRCS += sncProgram.st
    sncProgram_LIBS += seq pv
    sncProgram_LIBS += $(EPICS_BASE_HOST_LIBS)
endif
# Link QSRV (pvAccess Server) if available
ifdef EPICS_QSRV_MAJOR_VERSION
    interlocks_LIBS += qsrv
    interlocks_LIBS += $(EPICS_BASE_PVA_CORE_LIBS)
    interlocks_DBD += PVAServerRegister.dbd
    interlocks_DBD += qsrv.dbd
endif
# Finally link IOC to the EPICS Base libraries
interlocks_LIBS += $(EPICS_BASE_IOC_LIBS)
include $(TOP)/configure/RULES
#  ADD EXTRA GNUMAKE RULES BELOW HERE
# Explicit dependency needed for generated header file
devinterlocksVersion$(DEP): $(COMMON_DIR)/$(GENVERSION)
> -----Original Message-----
> From: Mark Rivers <[email protected]>
> Sent: Tuesday, February 11, 2020 1:00 PM
> To: Hetz, Benjamin <[email protected]>
> Subject: Re: SNCSEQ Error Windows
> Can you send the Makefile you are using, and a listing of the files in the
> source directory?
> ________________________________
> From: Tech-talk <[email protected]> on behalf of Hetz,
> Benjamin via Tech-talk <[email protected]>
> Sent: Tuesday, February 11, 2020 3:06 AM
> To: [email protected]
> Subject: SNCSEQ Error Windows
> Hello,
> I am having following problem:
> I am using the Windows build of EPICS with VS compiler and Strawbery Perl.
> Compiling SNCSeq 2.2.8 went fine and also its demo/example files were build
> in seq-2_2_8\examples and running.
> Following the instruction from https://www-
> csr.bessy.de/control/SoftDist/sequencer/Compiling.html I created an
> example IOC and changed SNCSEQ in configure/REALESE to
> "C:/opt/epics/base-7_0_3/modules/seq-2_2_8".
> Running now gmake in the example ioc top dir yields following error:
> gmake[3]: *** No rule to make target 'sncExample.obj', needed by
> 'interlocksSupport.lib'.  Stop.
> gmake[3]: Leaving directory
> 'C:/opt/epics/interlocks/interlocksApp/src/O.windows-x64-static'
> gmake[2]: *** [C:/opt/epics/base-7_0_3/configure/RULES_ARCHS:58:
> install.windows-x64-static] Error 2
> gmake[2]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp/src'
> gmake[1]: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84:
> src.install] Error 2
> gmake[1]: Leaving directory 'C:/opt/epics/interlocks/interlocksApp'
> gmake: *** [C:/opt/epics/base-7_0_3/configure/RULES_DIRS:84:
> interlocksApp.install] Error 2
> May anyone please help?
> Thank you, Ben
Re: SNCSEQ Error Windows Mark Rivers via Tech-talk
SNCSEQ Error Windows Hetz, Benjamin via Tech-talk
Prev: Re: SNCSEQ Error Windows Mark Rivers via Tech-talk
Next: Building EPICS base/IOC only for cross target Florian Feldbauer via Tech-talk
Next: Re: SNCSEQ Error Windows Mark Rivers via Tech-talk
