1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Building EPICS base/IOC only for cross target
From: "Johnson, Andrew N. via Tech-talk" <[email protected]>
To: Florian Feldbauer <[email protected]>
Date: Tue, 11 Feb 2020 17:16:24 +0000
Hi Florian,
Thanks for the clarification. The way to handle this is to adjust the Makefile that compiles the IOC so it *only* tries to build and link the IOC program for the linux-arm target, not for the Linux host. There is a slight trick to doing this, but it’s usually a simple one-line addition.
Where the Makefile says something like
  PROD_IOC = <iocname>
replace it with this:
  PROD_IOC_linux-arm = <iocname>
  PROD_IOC += $(PROD_IOC_$(T_A))
When building any architecture other than linux-arm the second line will evaluate to nothing, so nothing will be built.
HTH,
- Andrew
> On Feb 11, 2020, at 10:52 AM, Florian Feldbauer via Tech-talk <[email protected]> wrote:
> Hey Michael,
> as far as I understood, they would like to build everything (base, support modules and IOC) just for the target arch.
> But the error occurs for the IOC (which contains a custom support module)
> The missing library is the libisegHal which is only build for linux-arm as a part of the same yocto image.
> The library is needed for iseg's support module.
> Cheers,
> Florian
> Am 11.02.2020 um 16:34 schrieb Michael Davidsaver:
>> Can you clarify a couple of points?
>> Are you referring to building EPICS Base itself, or a support module / IOC application?
>> Which libraries are missing?  (this might answer the previous question)
>> On 2/11/20 5:27 AM, Florian Feldbauer via Tech-talk wrote:
>>> Hey all,
>>> I was contacted by iseg with the following problem:
>>> They want to include EPICS in their yocto image for the crate controllers.
>>> The host system is a linux-x86_64 system, the target arch linux-arm.
>>> Currently their Yocto recipe fails, because EPICS is build for both host and target arch and some libraries are missing for the host.
>>> Is there a way to build EPICS only for a target architecture?
>>> Best regards,
>>> Florian
> Dr. Florian Feldbauer
> Ruhr-Universität Bochum
> Experimentalphysik I AG
> Universitätsstr. 150
> Fach-Nr. 125
> D-44801 Bochum
> Office: NB 2/134
> Phone:  (+49)234 / 32-23563
> Fax:    (+49)234 / 32-14170
> https://paluma.ruhr-uni-bochum.de
Re: Building EPICS base/IOC only for cross target Florian Feldbauer via Tech-talk
Re: Building EPICS base/IOC only for cross target Michael Davidsaver via Tech-talk
Prev: Re: Building EPICS base/IOC only for cross target Florian Feldbauer via Tech-talk
Next: Re: Building EPICS base/IOC only for cross target Florian Feldbauer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
