Subject: Re: Building EPICS base/IOC only for cross target
From: Florian Feldbauer via Tech-talk <[email protected]>
To: "Johnson, Andrew N." <[email protected]>
Date: Tue, 11 Feb 2020 18:21:05 +0100
Hey Andrew,
thanks for the answer. I thought about this idea, but in the developers guide (base 3.15) only PROC_IOC_<osclass> was mentioned.
Good to know one can also define this for single target archs.
Florian
Am 11.02.2020 um 18:16 schrieb Johnson, Andrew N.:
Hi Florian,
Thanks for the clarification. The way to handle this is to adjust the Makefile that compiles the IOC so it *only* tries to build and link the IOC program for the linux-arm target, not for the Linux host. There is a slight trick to doing this, but it’s usually a simple one-line addition.
Where the Makefile says something like
   PROD_IOC = <iocname>
replace it with this:
   PROD_IOC_linux-arm = <iocname>
   PROD_IOC += $(PROD_IOC_$(T_A))
When building any architecture other than linux-arm the second line will evaluate to nothing, so nothing will be built.
HTH,
- Andrew
On Feb 11, 2020, at 10:52 AM, Florian Feldbauer via Tech-talk <[email protected]> wrote:
Hey Michael,
as far as I understood, they would like to build everything (base, support modules and IOC) just for the target arch.
But the error occurs for the IOC (which contains a custom support module)
The missing library is the libisegHal which is only build for linux-arm as a part of the same yocto image.
The library is needed for iseg's support module.
Cheers,
Florian
Am 11.02.2020 um 16:34 schrieb Michael Davidsaver:
Can you clarify a couple of points?
Are you referring to building EPICS Base itself, or a support module / IOC application?
Which libraries are missing?  (this might answer the previous question)
On 2/11/20 5:27 AM, Florian Feldbauer via Tech-talk wrote:
Hey all,
I was contacted by iseg with the following problem:
They want to include EPICS in their yocto image for the crate controllers.
The host system is a linux-x86_64 system, the target arch linux-arm.
Currently their Yocto recipe fails, because EPICS is build for both host and target arch and some libraries are missing for the host.
Is there a way to build EPICS only for a target architecture?
Best regards,
Florian
Dr. Florian Feldbauer
Ruhr-Universität Bochum
Experimentalphysik I AG
Universitätsstr. 150
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Phone:  (+49)234 / 32-23563
Fax:    (+49)234 / 32-14170
https://paluma.ruhr-uni-bochum.de
Fach-Nr. 125
D-44801 Bochum
Office: NB 2/134
Re: Building EPICS base/IOC only for cross target Johnson, Andrew N. via Tech-talk
Building EPICS base/IOC only for cross target Florian Feldbauer via Tech-talk
Re: Building EPICS base/IOC only for cross target Michael Davidsaver via Tech-talk
Re: Building EPICS base/IOC only for cross target Florian Feldbauer via Tech-talk
Prev: Re: Building EPICS base/IOC only for cross target Johnson, Andrew N. via Tech-talk
Next: Re: send/receive waveform over network. Tomasz Brys via Tech-talk
Next: Re: Building EPICS base/IOC only for cross target Johnson, Andrew N. via Tech-talk
