1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: New To Epics - Need Help starting first IOC
From: Kevan Anderson via Tech-talk <[email protected]>
To: [email protected]
Date: Wed, 12 Feb 2020 13:11:50 -0800
I downloaded epics base from the web and am trying to compile it and run it on windows 10 x64.
This is the problem I am having when I try to start a soft IOC.
I have grep searched the entire code base in c:\epics and found two locations where "base-3.14" exist. Neither of them help much.
As you can see, I downloaded 7.0.3.1, not 3.14...
Also, my PC does not have a D drive?
The file sum.cmd and associated .db come from here:
I have only installed the base package - run the window.bat, and configured my path to visual studio. Please note, this is unlikely a misconfiguration in a config file, because i grepped the whole folder.
Appreciate your help pointing me to next steps.
Kevan
Kevan Anderson
Beamline Controls Engineering
Advanced Light Source
Lawrence Berkeley National Laboratory
x5407
RE: New To Epics - Need Help starting first IOC Mark Rivers via Tech-talk
Prev: Re: Standard RTEMS NFSv3 client Matt Rippa via Tech-talk
Next: Re: Standard RTEMS NFSv3 client Johnson, Andrew N. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: RE: New To Epics - Need Help starting first IOC Mark Rivers via Tech-talk
