Subject: RE: New To Epics - Need Help starting first IOC
To: 'Kevan Anderson' <[email protected]>
Date: Wed, 12 Feb 2020 23:00:57 +0000
Hi Kevan,
How did you download epics base from the Web?
You appear to have a directory called C:\epics\base-7.0.3.1\softioc.  Where did that directory come from?
This is the contents of the base-7.0.3.1 directory on my system after I have built it.
H:\epics\base-7.0.3.1>dir
Volume in drive H is local_rw
Volume Serial Number is 6DDD-530A
Directory of H:\epics\base-7.0.3.1
12/23/2019  09:51 AM    <DIR>          .
12/23/2019  09:50 AM    <DIR>          ..
12/04/2017  11:22 AM             4,710 LICENSE
12/04/2017  11:22 AM               782 Makefile
12/24/2019  01:50 PM    <DIR>          configure
12/23/2019  09:43 AM    <DIR>          documentation
02/02/2020  11:20 AM    <DIR>          modules
12/04/2017  11:22 AM    <DIR>          src
01/08/2019  05:12 PM    <DIR>          startup
12/04/2017  11:22 AM    <DIR>          test
02/06/2018  05:55 PM               983 README
12/23/2019  09:52 AM    <DIR>          cfg
12/24/2019  01:50 PM    <DIR>          lib
12/24/2019  01:50 PM    <DIR>          bin
02/02/2020  11:22 AM    <DIR>          html
12/23/2019  09:51 AM    <DIR>          templates
02/02/2020  11:22 AM    <DIR>          include
02/02/2020  11:23 AM    <DIR>          dbd
02/02/2020  11:22 AM    <DIR>          db
               3 File(s)          6,475 bytes
              16 Dir(s)  707,245,117,440 bytes free
Note that there is no softioc directory?
From: Tech-talk <[email protected]> On Behalf Of Kevan Anderson via Tech-talk
Sent: Wednesday, February 12, 2020 3:12 PM
To: [email protected]
Subject: New To Epics - Need Help starting first IOC
I downloaded epics base from the web and am trying to compile it and run it on windows 10 x64.
This is the problem I am having when I try to start a soft IOC.
I have grep searched the entire code base in c:\epics and found two locations where "base-3.14" exist. Neither of them help much.
As you can see, I downloaded 7.0.3.1, not 3.14...
Also, my PC does not have a D drive?
The file sum.cmd and associated .db come from here:
I have only installed the base package - run the window.bat, and configured my path to visual studio. Please note, this is unlikely a misconfiguration in a config file, because i grepped the whole folder.
Appreciate your help pointing me to next steps.
Kevan
Kevan Anderson
Beamline Controls Engineering
Advanced Light Source
Lawrence Berkeley National Laboratory
x5407
RE: New To Epics - Need Help starting first IOC Mark Rivers via Tech-talk
New To Epics - Need Help starting first IOC Kevan Anderson via Tech-talk
Prev: Re: Standard RTEMS NFSv3 client Johnson, Andrew N. via Tech-talk
Next: RE: New To Epics - Need Help starting first IOC Mark Rivers via Tech-talk
Prev: New To Epics - Need Help starting first IOC Kevan Anderson via Tech-talk
