Subject: Re: MRF Delay Compensation Function
From: "Shen, Guobao via Tech-talk" <[email protected]>
To: Javier Cereijo García <[email protected]>, Michael Davidsaver <[email protected]>
Cc: Timo Korhonen <[email protected]>, Tech-Talk <[email protected]>
Date: Thu, 20 Feb 2020 14:40:50 +0000
> the target delay must always be set so that it is greater than the physical delay, including internal delays. Otherwise some events will be missed
That's interesting and good to know.
It seems a firmware issue. Did you get any response from Jukka?
> We are starting the commissioning phase soon so we will have better results.
Would love to know your experience.
Guobao
On 2/20/20, 2:40 AM, "Javier Cereijo García" <[email protected]> wrote:
    Hi all,
    Yes, here at ESS we have done some tests in the lab in the past,
    although they were quite simple. I can share what we have learnt. These
    tests were done using mTCA-EVR-300 and mTCA-EVM-300, not VME.
    The first feeling is that everything works as expected, and changing the
    target delay works smoothly, as well as changing the length of the
    optical fiber. There is one thing though that seems strange to me, and
    it is that the target delay must always be set so that it is greater
    events will be missed. Even when using a 230-series EVG with the delay
    compensation disabled on the EVR side the target delay needs to be set
    correctly.
    We didn't perform any complex jitter test, although monitoring the "DC
    lock" shows that it gets unlocked from time to time, usually recovering
    quickly. We didn't worry too much at that moment, the measured delay
    wasn't changing that quickly, I think that the lock monitor is quite
    sensitive. I can't recall from the top of my head if we were using the
    EVM's fractional synthesizer or an external RF source, so this may
    easily disappear in a more stable environment.
    Best regards,
    Javier
    On 19/02/2020 18:17, Michael Davidsaver wrote:
    > On 2/18/20 10:43 AM, Shen, Guobao via Tech-talk wrote:
    >> Hi all,
    >> Is there anyone who has been using MRF EVM-300 delay compensation function for any purpose, in the lab, test stand, real machine, etc?
    > ESS did some testing as well.
    >> If yes, would you mind to share us your experience?
    > As I recall, it worked well on a test stand.  My personal knowledge ends there.
    >> Thanks,
    >> Guobao
    >> Guobao Shen
    >> [email protected] <mailto:[email protected]>
    >> Controls Group Leader
    >> Advanced Photon Source
    >> Argonne National Laboratory
    >> 9700 S. Cass Avenue, Lemont, IL 60439
    Embedded System Engineer
    HW&I group, ICS division
    European Spallation Source ERIC
    Mobile: +46 (0)72 179 23 34
    E-mail: [email protected]
Re: MRF Delay Compensation Function Timo Korhonen via Tech-talk
MRF Delay Compensation Function Shen, Guobao via Tech-talk
Re: MRF Delay Compensation Function Michael Davidsaver via Tech-talk
Re: MRF Delay Compensation Function Javier Cereijo García via Tech-talk
Prev: Re: MEMD is stuck on windows-x64 Mark Rivers via Tech-talk
Next: Re: [EXTERNAL] matrix multiplication and inversions Pearson, Matthew R. via Tech-talk
Prev: Re: MRF Delay Compensation Function Javier Cereijo García via Tech-talk
Next: Re: MRF Delay Compensation Function Timo Korhonen via Tech-talk
