Subject: Re: MRF Delay Compensation Function
From: Javier Cereijo García via Tech-talk <[email protected]>
To: Michael Davidsaver <[email protected]>, "Shen, Guobao" <[email protected]>
Cc: Timo Korhonen <[email protected]>, Tech-Talk <[email protected]>
Date: Thu, 20 Feb 2020 09:40:06 +0100
Hi all,
Yes, here at ESS we have done some tests in the lab in the past, although they were quite simple. I can share what we have learnt. These tests were done using mTCA-EVR-300 and mTCA-EVM-300, not VME.
The first feeling is that everything works as expected, and changing the target delay works smoothly, as well as changing the length of the optical fiber. There is one thing though that seems strange to me, and it is that the target delay must always be set so that it is greater than the physical delay, including internal delays. Otherwise some events will be missed. Even when using a 230-series EVG with the delay compensation disabled on the EVR side the target delay needs to be set correctly.
We didn't perform any complex jitter test, although monitoring the "DC lock" shows that it gets unlocked from time to time, usually recovering quickly. We didn't worry too much at that moment, the measured delay wasn't changing that quickly, I think that the lock monitor is quite sensitive. I can't recall from the top of my head if we were using the EVM's fractional synthesizer or an external RF source, so this may easily disappear in a more stable environment.
We are starting the commissioning phase soon so we will have better results.
Best regards,
Javier
On 19/02/2020 18:17, Michael Davidsaver wrote:
On 2/18/20 10:43 AM, Shen, Guobao via Tech-talk wrote:
Hi all,
Is there anyone who has been using MRF EVM-300 delay compensation function for any purpose, in the lab, test stand, real machine, etc?
ESS did some testing as well.
If yes, would you mind to share us your experience?
As I recall, it worked well on a test stand.  My personal knowledge ends there.
Guobao
Guobao Shen
[email protected] <mailto:[email protected]>
Controls Group Leader
Advanced Photon Source
Argonne National Laboratory
9700 S. Cass Avenue, Lemont, IL 60439
Embedded System Engineer
HW&I group, ICS division
European Spallation Source ERIC
Mobile: +46 (0)72 179 23 34
E-mail: [email protected]
Re: MRF Delay Compensation Function Shen, Guobao via Tech-talk
Re: MRF Delay Compensation Function Michael Davidsaver via Tech-talk
Prev: Re: EPICS Archiver appliance MySQL Persistence error Heinz Junkes via Tech-talk
Next: Re: MEMD is stuck on windows-x64 Mark Rivers via Tech-talk
Prev: Re: MRF Delay Compensation Function Michael Davidsaver via Tech-talk
Next: Re: MRF Delay Compensation Function Shen, Guobao via Tech-talk
