1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: Buffer full issue with ADAravis
From: Katie Matusik via Tech-talk <[email protected]>
Date: Fri, 21 Feb 2020 15:00:39 -0800
Hi Mark,
Please see the attached file. I changed the polling rate to 1 s.
Thank you!
Katie
On Fri, Feb 21, 2020 at 2:20 PM Mark Rivers <[email protected]> wrote:
Hi Katie,
OK, that is useful.  This is the interesting part:
2020/02/21 21:28:36.198 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 21:28:36.198 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.198 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.198 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 21:28:36.198 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.294 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.294 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.294 asynNDArrayDriver:writeInt32: function=8, paramName=ACQUIRE, value=1
2020/02/21 21:28:36.294 ADDriver:writeInt32: function=8, paramName=ACQUIRE, value=1
2020/02/21 21:28:36.297 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.343 ADGenICam::writeInt32 function=8, value=1, status=0
2020/02/21 21:28:36.343 ADAravis:writeInt32: function=8 ACQUIRE, value=1
2020/02/21 21:28:36.343 asynManager::portThread port=ARV1 callback
2020/02/21 21:28:36.343 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 21:28:36.343 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 21:28:36.343 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 21:28:36.343 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 21:28:36.397 ARV1 addr -1 queueRequest priority 0 not lockHolder
So up until 36.198 no memory buffers had been allocated.  At 36.294 the ACQUIRE=1 command was received, and the camera was told to start.  At 36.343 20 buffers using 114.3 MB had been allocated.
Unfortunately there is not enough debugging printout in the driver to see why 20 buffers were allocated (rather than only 1) and why it did not correctly increment the number of received images and do the callbacks to plugins.
I have created a new branch of ADAravis on Github called Teledyn_debug.  At the top level of your local ADAravis do
git pull
git checkout Teledyn_debug
make clean
make
Do the same thing you did for the last output and send it to me.  You can turn down the scan rate of Buffer and memory polling” from 0.1 second to 1 second to reduce the amount of output.
Sent: Friday, February 21, 2020 3:35 PM
Hi Mark,
Please find the output attached.
Thank you!
Katie
On Fri, Feb 21, 2020 at 1:15 PM Mark Rivers <[email protected]> wrote:
Hi Katie,
That output does not show what I want.
Please do the following:
-          Comment out the asynSetTraceMask line in the startup script again
-          Boot the IOC
-          Once it is done booting type that asynSetTraceMask command interactively on the command line
-          Press the Acquire button
-          Let it run for a few seconds and then type exit.
Send me the output.
Sent: Friday, February 21, 2020 1:19 PM
Hi Mark,
When I press "acquire", I don't get any output in the iocsh console. I'm attaching a text file of the console output when asyntrace is enabled; I truncated at some point and am hopefully providing you with the relevant info. For wc, I get  2161 3959 58969 Teledyne_ShadoBox.template; when I use the original script version (i.e. remove "IntReg"), then I recover your exact output:  2119  3881 57783 GenICamApp/Db/Teledyne_ShadoBox.template.
Thanks so much,
Katie
On Fri, Feb 21, 2020 at 10:19 AM Mark Rivers <[email protected]> wrote:
Hi Katie,
Ø  I should mention that I made two changes to makeDb.py in order for it to generate the database file:  line 26 was changed to specify the encoding type, "genicam_lines = open(args[0], encoding="utf-8").readlines()" otherwise it threw an error (I'm using python v3.6.9),
I am using Python 3.7.3 and I did not get that error on the xml you attached to your previous message.  This is what I see when I run addCamera, which runs makeDb.py and makeAdl.py.
corvette:~/devel/areaDetector/ADGenICam>./addCamera.sh Teledyne_ShadoBox
Don't know what to do with IntReg
More than 16 enum entries for GevSupportedOptionSelector mbbi record, discarding additional options.
   If needed, edit the Enumeration tag for GevSupportedOptionSelector to select the 16 you want.
Don't know what to do with Register
Ø  and I added "IntReg" to the list of data types in line 145, "if node.nodeName in ["Integer", "IntConverter", "IntSwissKnife", "IntReg"]:".
I do see messages that say “Don't know what to do with IntReg”, but I think they are harmless, just as the ones that say “Don't know what to do with Register”.  This is what I get running “wc” on the resulting .template file.
corvette:~/devel/areaDetector/ADGenICam>wc GenICamApp/Db/Teledyne_ShadoBox.template
What do you get?
Sent: Friday, February 21, 2020 12:03 PM
To: 'Katie Matusik' <[email protected]>
Subject: RE: Buffer full issue with ADAravis
Hi Katie,
Ø  When I press acquire, the buffer again immediately fills up and neither the values in the "Status" box nor in the stats plugin change.
The buffer is not actually “filling up”.  It does indicate that 20 NDArrays have been allocated, totaling 114.3 MB.  Your arrays are 2304x1300 pixels, presumably 2-bytes per pixel, which is  5.71 MB per array.  20 arrays would be 114.3 MB, which is excactly what it says it allocated.
When you press Acquire are there any messages on the iocsh console?
It looks like the ADAravis driver is allocating NDArrays, but it is never doing callbacks, and never realizing that acquisition is complete.
We are going to need to enable some debugging to figure out why.
The first thing to do is to enable all asynTrace information from the driver.  In your startup script uncomment this line after aravisConfig():
asynSetTraceMask($(PORT), 0, TRACE_ERROR|TRACEIO_DRIVER|TRACE_FLOW)
If that does not provide enough information you will need to add some more asynPrint statements in the driver to track down what is going wrong.
Sent: Friday, February 21, 2020 10:54 AM
Hi Mark,
Please see attached for the plugins/all and statistics screens, as well as the xml file. The pixel format options are mono14 and mono12packed. I changed the status rate to 1 second and enabled the statistics plugin. When I press acquire, the buffer again immediately fills up and neither the values in the "Status" box nor in the stats plugin change. I should mention that I made two changes to makeDb.py in order for it to generate the database file:  line 26 was changed to specify the encoding type, "genicam_lines = open(args[0], encoding="utf-8").readlines()" otherwise it threw an error (I'm using python v3.6.9), and I added "IntReg" to the list of data types in line 145, "if node.nodeName in ["Integer", "IntConverter", "IntSwissKnife", "IntReg"]:".
Thanks so much,
Katie
Image removed by sender.
This email and any files transmitted with it are confidential and intended solely for the use of the individual or entity to whom they are addressed. If you have received this email in error, please notify the system manager. This message contains confidential information and is intended only for the individual named. If you are not the named addressee, you should not disseminate, distribute or copy this email. Please notify the sender immediately by email if you have received this email by mistake and delete this email from your system. If you are not the intended recipient, you are notified that disclosing, copying, distributing or taking any action in reliance on the contents of this information is strictly prohibited
Katie Matusik
Systems Engineer
5750 Imhoff Drive, Suite I
Concord, CA 94520 USA
Office: 1 (925) 326 - 7926
Katie Matusik
Systems Engineer
Katie Matusik
Systems Engineer
epics> asynSetTraceMask($(PORT), 0, TRACE_ERROR|TRACEIO_DRIVER|TRACE_FLOW)
2020/02/21 22:58:03.728 ARV1:cam1:AsynIO: exception 3, asynExceptionTraceMask
epics>
epics> 2020/02/21 22:58:04.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:04.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:04.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:04.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:04.536 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:04.536 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:04.536 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:04.536 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:04.536 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:04.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:04.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:04.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:04.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:04.538 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:04.538 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:04.539 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:04.539 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:04.539 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:04.539 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:04.539 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:04.539 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:04.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:04.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:04.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:04.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:04.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:04.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:04.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:04.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:04.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:04.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:04.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:04.539 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:04.539 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:04.539 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:04.539 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:04.539 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:04.540 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:04.540 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:04.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:04.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:04.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:04.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:04.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:04.540 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:04.540 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:04.540 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:04.540 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:04.540 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:04.540 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:04.540 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:04.540 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:04.540 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:04.540 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:04.540 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:04.540 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:04.540 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:04.540 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:04.540 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:04.540 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:04.540 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:04.540 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:04.540 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:04.540 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:04.540 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:04.541 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:04.541 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:04.541 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:04.541 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:04.541 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:04.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:04.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:04.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:04.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:04.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:04.541 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:04.541 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:04.541 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:04.541 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:04.541 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:04.543 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:04.543 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:04.543 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:04.543 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:04.543 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:04.543 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:04.543 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:04.543 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:04.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:04.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:04.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:04.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:04.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:04.544 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:04.544 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:04.544 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:04.544 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:04.544 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:04.544 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:04.544 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:04.544 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:04.544 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:04.544 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:04.544 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:04.544 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:04.544 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:04.544 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:04.544 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:04.544 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:04.544 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:04.544 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:04.544 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:04.544 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:04.544 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:04.544 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:04.544 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:04.544 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:04.544 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:04.544 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:04.544 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:04.544 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:04.544 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:04.544 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:04.544 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:04.544 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:04.544 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:04.544 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:04.544 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:04.544 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:04.545 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:04.545 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:04.545 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:04.545 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:04.545 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:04.545 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:04.545 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:04.545 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:04.545 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:04.545 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:04.545 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:04.546 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:04.546 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:04.546 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:04.546 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:04.546 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:04.546 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:04.546 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:04.546 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:04.546 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:04.546 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:04.546 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:04.546 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:04.546 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:04.546 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:04.546 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:04.546 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:04.546 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:04.546 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:04.546 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:04.546 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 22:58:04.546 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:04.546 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 22:58:04.546 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 22:58:05.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:05.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:05.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:05.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:05.535 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:05.535 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:05.536 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:05.536 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:05.536 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:05.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:05.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:05.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:05.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:05.539 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:05.539 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:05.539 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:05.539 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:05.539 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:05.539 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:05.539 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:05.539 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:05.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:05.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:05.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:05.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:05.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:05.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:05.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:05.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:05.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:05.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:05.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:05.540 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:05.540 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:05.540 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:05.540 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:05.540 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:05.540 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:05.540 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:05.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:05.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:05.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:05.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:05.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:05.541 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:05.541 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:05.541 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:05.541 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:05.541 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:05.541 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:05.541 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:05.541 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:05.541 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:05.541 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:05.541 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:05.541 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:05.541 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:05.541 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:05.541 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:05.541 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:05.541 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:05.541 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:05.541 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:05.541 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:05.541 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:05.541 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:05.541 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:05.541 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:05.541 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:05.541 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:05.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:05.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:05.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:05.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:05.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:05.542 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:05.542 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:05.542 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:05.542 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:05.542 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:05.544 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:05.544 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:05.544 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:05.544 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:05.544 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:05.544 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:05.544 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:05.544 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:05.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:05.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:05.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:05.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:05.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:05.544 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:05.544 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:05.545 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:05.545 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:05.545 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:05.545 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:05.545 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:05.545 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:05.545 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:05.545 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:05.545 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:05.545 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:05.545 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:05.545 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:05.545 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:05.545 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:05.545 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:05.545 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:05.545 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:05.545 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:05.545 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:05.545 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:05.545 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:05.545 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:05.545 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:05.545 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:05.545 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:05.546 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:05.546 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:05.546 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:05.546 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:05.546 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:05.546 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:05.546 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:05.546 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:05.546 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:05.546 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:05.546 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:05.546 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:05.546 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:05.546 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:05.546 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:05.546 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:05.546 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:05.546 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:05.546 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:05.546 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:05.547 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:05.547 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:05.547 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:05.547 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:05.547 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:05.547 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:05.547 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:05.547 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:05.547 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:05.547 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:05.547 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:05.548 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:05.548 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:05.548 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:05.548 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:05.548 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:05.548 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:05.548 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:05.548 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:05.548 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 22:58:05.548 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:05.548 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 22:58:05.548 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 22:58:06.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:06.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:06.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:06.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:06.535 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:06.535 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:06.535 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:06.535 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:06.535 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:06.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:06.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:06.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:06.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:06.538 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:06.538 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:06.538 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:06.538 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:06.538 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:06.538 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:06.538 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:06.539 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:06.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:06.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:06.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:06.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:06.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:06.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:06.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:06.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:06.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:06.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:06.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:06.539 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:06.539 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:06.539 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:06.539 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:06.539 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:06.539 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:06.539 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:06.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:06.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:06.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:06.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:06.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:06.540 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:06.540 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:06.540 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:06.540 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:06.540 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:06.540 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:06.540 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:06.540 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:06.540 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:06.540 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:06.540 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:06.540 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:06.540 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:06.540 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:06.540 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:06.540 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:06.540 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:06.540 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:06.540 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:06.540 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:06.540 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:06.540 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:06.540 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:06.540 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:06.540 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:06.540 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:06.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:06.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:06.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:06.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:06.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:06.541 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:06.541 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:06.541 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:06.541 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:06.541 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:06.543 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:06.543 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:06.543 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:06.543 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:06.543 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:06.543 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:06.543 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:06.543 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:06.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:06.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:06.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:06.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:06.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:06.544 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:06.544 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:06.544 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:06.544 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:06.544 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:06.544 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:06.544 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:06.544 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:06.544 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:06.544 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:06.544 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:06.544 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:06.544 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:06.544 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:06.544 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:06.544 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:06.544 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:06.544 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:06.544 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:06.544 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:06.544 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:06.544 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:06.544 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:06.544 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:06.544 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:06.544 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:06.545 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:06.545 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:06.545 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:06.545 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:06.545 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:06.545 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:06.545 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:06.545 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:06.545 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:06.545 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:06.545 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:06.545 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:06.545 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:06.545 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:06.545 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:06.545 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:06.545 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:06.545 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:06.545 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:06.545 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:06.545 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:06.546 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:06.546 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:06.546 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:06.546 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:06.546 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:06.546 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:06.546 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:06.546 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:06.546 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:06.546 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:06.546 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:06.546 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:06.546 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:06.546 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:06.546 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:06.547 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:06.547 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:06.547 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:06.547 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:06.547 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=0.000000
2020/02/21 22:58:06.547 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:06.547 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=0
2020/02/21 22:58:06.547 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 22:58:06.979 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:06.979 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:06.980 asynNDArrayDriver:writeInt32: function=8, paramName=ACQUIRE, value=1
2020/02/21 22:58:06.980 ADDriver:writeInt32: function=8, paramName=ACQUIRE, value=1
2020/02/21 22:58:06.984 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:06.986 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:06.989 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:06.991 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:06.994 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:06.997 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:06.999 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.002 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.004 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.007 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.010 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.013 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.016 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.019 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.022 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.025 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.027 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.030 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.033 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.035 ADAravis:allocBuffer: allocated new buffer OK
2020/02/21 22:58:07.037 ADGenICam::writeInt32 function=8, value=1, status=0
2020/02/21 22:58:07.037 ADAravis:writeInt32: function=8 ACQUIRE, value=1
2020/02/21 22:58:07.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:07.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:07.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:07.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:07.535 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:07.535 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:07.536 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:07.536 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:07.536 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:07.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:07.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:07.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:07.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:07.538 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:07.538 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:07.538 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:07.538 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:07.538 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:07.538 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:07.538 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:07.538 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:07.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:07.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:07.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:07.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:07.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:07.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:07.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:07.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:07.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:07.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:07.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:07.539 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:07.539 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:07.539 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:07.539 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:07.539 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:07.539 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:07.539 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:07.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:07.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:07.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:07.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:07.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:07.540 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:07.540 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:07.540 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:07.540 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:07.540 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:07.540 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:07.540 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:07.540 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:07.540 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:07.540 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:07.540 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:07.540 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:07.540 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:07.540 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:07.540 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:07.540 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:07.540 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:07.540 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:07.540 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:07.540 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:07.540 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:07.540 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:07.541 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:07.541 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:07.541 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:07.541 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:07.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:07.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:07.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:07.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:07.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:07.541 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:07.541 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:07.541 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:07.541 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:07.541 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:07.544 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:07.544 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:07.544 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:07.544 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:07.544 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:07.544 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:07.544 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:07.544 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:07.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:07.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:07.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:07.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:07.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:07.544 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:07.544 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:07.544 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:07.544 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:07.544 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:07.545 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:07.545 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:07.545 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:07.545 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:07.545 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:07.545 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:07.545 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:07.545 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:07.545 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:07.545 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:07.545 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:07.545 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:07.545 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:07.545 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:07.545 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:07.545 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:07.545 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:07.545 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:07.545 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:07.545 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:07.545 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:07.545 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:07.546 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:07.546 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:07.546 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:07.546 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:07.546 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:07.546 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:07.546 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:07.546 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:07.546 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:07.546 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:07.546 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:07.546 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:07.546 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:07.546 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:07.546 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:07.546 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:07.546 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:07.546 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:07.546 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:07.546 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:07.547 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:07.547 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:07.547 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:07.547 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:07.547 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:07.547 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:07.547 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:07.547 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:07.547 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:07.547 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:07.547 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:07.548 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:07.548 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:07.548 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:07.548 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:07.548 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:07.548 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:07.548 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:07.548 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:07.548 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 22:58:07.548 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:07.548 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 22:58:07.548 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 22:58:08.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:08.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:08.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:08.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:08.535 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:08.535 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:08.536 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:08.536 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:08.536 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:08.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:08.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:08.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:08.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:08.538 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:08.538 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:08.539 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:08.539 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:08.539 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:08.539 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:08.539 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:08.539 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:08.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:08.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:08.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:08.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:08.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:08.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:08.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:08.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:08.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:08.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:08.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:08.539 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:08.539 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:08.539 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:08.539 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:08.540 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:08.540 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:08.540 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:08.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:08.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:08.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:08.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:08.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:08.540 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:08.540 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:08.540 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:08.540 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:08.540 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:08.540 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:08.540 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:08.540 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:08.540 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:08.540 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:08.540 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:08.540 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:08.540 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:08.540 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:08.540 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:08.540 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:08.540 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:08.540 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:08.540 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:08.541 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:08.541 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:08.541 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:08.541 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:08.541 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:08.541 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:08.541 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:08.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:08.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:08.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:08.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:08.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:08.541 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:08.541 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:08.541 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:08.541 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:08.541 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:08.543 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:08.544 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:08.544 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:08.544 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:08.544 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:08.544 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:08.544 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:08.544 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:08.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:08.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:08.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:08.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:08.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:08.544 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:08.544 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:08.544 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:08.544 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:08.544 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:08.544 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:08.544 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:08.544 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:08.544 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:08.544 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:08.544 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:08.545 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:08.545 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:08.545 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:08.545 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:08.545 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:08.545 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:08.545 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:08.545 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:08.545 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:08.545 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:08.545 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:08.545 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:08.545 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:08.545 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:08.545 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:08.545 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:08.545 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:08.545 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:08.545 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:08.545 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:08.545 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:08.545 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:08.545 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:08.545 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:08.545 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:08.545 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:08.545 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:08.545 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:08.545 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:08.545 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:08.545 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:08.545 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:08.546 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:08.546 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:08.546 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:08.546 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:08.547 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:08.547 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:08.547 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:08.547 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:08.547 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:08.547 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:08.547 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:08.547 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:08.547 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:08.547 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:08.547 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:08.547 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:08.547 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:08.547 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:08.547 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:08.547 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:08.547 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:08.547 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:08.547 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:08.547 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 22:58:08.547 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:08.547 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 22:58:08.548 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:08.548 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 22:58:09.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:09.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:09.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:09.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:09.535 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:09.535 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:09.535 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:09.536 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:09.536 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:09.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:09.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:09.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:09.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:09.538 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:09.538 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:09.538 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:09.538 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:09.539 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:09.539 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:09.539 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:09.539 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:09.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:09.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:09.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:09.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:09.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:09.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:09.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:09.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:09.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:09.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:09.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:09.539 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:09.539 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:09.539 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:09.539 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:09.539 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:09.539 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:09.540 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:09.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:09.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:09.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:09.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:09.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:09.540 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:09.540 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:09.540 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:09.540 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:09.540 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:09.540 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:09.540 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:09.540 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:09.540 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:09.540 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:09.540 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:09.540 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:09.540 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:09.540 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:09.540 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:09.540 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:09.540 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:09.540 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:09.540 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:09.541 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:09.541 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:09.541 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:09.541 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:09.541 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:09.541 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:09.541 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:09.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:09.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:09.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:09.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:09.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:09.541 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:09.541 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:09.541 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:09.541 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:09.541 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:09.543 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:09.543 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:09.544 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:09.544 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:09.544 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:09.544 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:09.544 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:09.544 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:09.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:09.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:09.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:09.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:09.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:09.544 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:09.544 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:09.544 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:09.544 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:09.544 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:09.544 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:09.544 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:09.544 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:09.544 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:09.544 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:09.544 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:09.544 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:09.544 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:09.544 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:09.545 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:09.545 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:09.545 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:09.545 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:09.545 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:09.545 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:09.545 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:09.545 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:09.545 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:09.545 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:09.545 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:09.545 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:09.545 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:09.545 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:09.545 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:09.545 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:09.545 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:09.545 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:09.545 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:09.545 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:09.545 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:09.545 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:09.545 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:09.545 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:09.545 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:09.545 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:09.545 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:09.545 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:09.545 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:09.545 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:09.545 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:09.545 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:09.545 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:09.546 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:09.546 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:09.547 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:09.547 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:09.547 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:09.547 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:09.547 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:09.547 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:09.547 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:09.547 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:09.547 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:09.547 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:09.547 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:09.547 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:09.547 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:09.547 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:09.547 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:09.547 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:09.547 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:09.547 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 22:58:09.547 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:09.547 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 22:58:09.547 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 22:58:10.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:10.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:10.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:10.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:10.535 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:10.535 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:10.536 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:10.536 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:10.536 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:10.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:10.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:10.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:10.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:10.538 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:10.538 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:10.538 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:10.538 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:10.538 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:10.539 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:10.539 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:10.539 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:10.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:10.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:10.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:10.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:10.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:10.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:10.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:10.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:10.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:10.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:10.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:10.539 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:10.539 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:10.539 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:10.539 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:10.539 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:10.539 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:10.540 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:10.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:10.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:10.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:10.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:10.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:10.540 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:10.540 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:10.540 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:10.540 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:10.540 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:10.540 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:10.540 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:10.540 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:10.540 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:10.540 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:10.540 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:10.540 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:10.540 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:10.540 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:10.540 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:10.540 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:10.540 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:10.540 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:10.540 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:10.540 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:10.541 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:10.541 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:10.541 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:10.541 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:10.541 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:10.541 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:10.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:10.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:10.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:10.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:10.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:10.541 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:10.541 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:10.541 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:10.541 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:10.541 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:10.543 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:10.543 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:10.543 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:10.543 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:10.543 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:10.544 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:10.544 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:10.544 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:10.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:10.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:10.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:10.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:10.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:10.544 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:10.544 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:10.544 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:10.544 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:10.544 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:10.544 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:10.544 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:10.544 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:10.544 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:10.544 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:10.544 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:10.544 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:10.544 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:10.544 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:10.544 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:10.544 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:10.544 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:10.544 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:10.545 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:10.545 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:10.545 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:10.545 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:10.545 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:10.545 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:10.545 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:10.545 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:10.545 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:10.545 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:10.545 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:10.545 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:10.545 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:10.545 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:10.545 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:10.545 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:10.545 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:10.545 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:10.545 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:10.545 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:10.545 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:10.545 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:10.545 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:10.545 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:10.545 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:10.546 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:10.546 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:10.546 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:10.546 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:10.547 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:10.547 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:10.547 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:10.547 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:10.547 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:10.547 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:10.547 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:10.547 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:10.547 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:10.547 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:10.547 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:10.547 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:10.547 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:10.547 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:10.547 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:10.547 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:10.547 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:10.547 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:10.547 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:10.547 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 22:58:10.547 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:10.547 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 22:58:10.547 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=0
2020/02/21 22:58:10.851 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:10.851 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:10.852 asynNDArrayDriver:writeInt32: function=8, paramName=ACQUIRE, value=0
2020/02/21 22:58:10.852 ADDriver:writeInt32: function=8, paramName=ACQUIRE, value=0
2020/02/21 22:58:10.924 ADGenICam::writeInt32 function=8, value=0, status=0
2020/02/21 22:58:10.924 ADAravis:writeInt32: function=8 ACQUIRE, value=0
2020/02/21 22:58:11.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:11.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:11.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:11.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:11.535 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:11.535 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:11.536 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:11.536 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:11.536 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:11.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:11.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:11.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:11.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:11.538 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:11.538 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:11.538 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:11.538 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:11.539 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:11.539 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:11.539 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:11.539 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:11.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:11.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:11.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:11.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:11.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:11.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:11.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:11.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:11.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:11.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:11.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:11.539 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:11.539 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:11.539 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:11.540 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:11.540 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:11.540 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:11.540 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:11.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:11.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:11.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:11.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:11.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:11.540 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:11.540 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:11.540 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:11.540 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:11.540 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:11.540 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:11.540 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:11.541 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:11.541 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:11.541 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:11.541 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:11.541 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:11.541 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:11.541 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:11.541 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:11.541 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:11.541 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:11.541 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:11.541 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:11.541 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:11.541 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:11.541 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:11.541 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:11.541 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:11.541 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:11.541 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:11.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:11.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:11.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:11.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:11.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:11.541 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:11.542 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:11.542 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:11.542 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:11.542 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:11.544 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:11.544 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:11.544 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:11.544 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:11.544 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:11.544 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:11.544 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:11.544 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:11.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:11.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:11.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:11.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:11.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:11.545 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:11.545 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:11.545 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:11.545 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:11.545 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:11.545 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:11.545 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:11.545 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:11.545 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:11.545 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:11.545 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:11.545 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:11.545 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:11.545 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:11.545 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:11.545 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:11.545 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:11.545 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:11.545 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:11.545 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:11.545 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:11.546 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:11.546 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:11.546 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:11.546 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:11.546 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:11.546 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:11.546 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:11.547 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:11.547 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:11.547 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:11.547 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:11.547 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:11.547 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:11.547 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:11.547 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:11.547 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:11.547 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:11.547 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:11.547 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:11.547 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:11.547 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:11.548 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:11.548 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:11.548 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:11.548 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:11.548 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:11.549 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:11.549 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:11.549 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:11.549 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:11.549 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:11.549 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:11.549 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:11.549 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:11.549 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:11.549 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:11.549 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:11.549 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:11.549 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:11.549 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:11.549 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:11.549 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:11.549 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:11.549 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:11.549 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:11.549 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 22:58:11.549 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:11.549 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 22:58:11.549 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=20
2020/02/21 22:58:12.535 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:12.535 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:12.535 ADDriver:writeInt32: function=90, paramName=READ_STATUS, value=1
2020/02/21 22:58:12.535 Param[MANUFACTURER] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:12.535 Param[MODEL] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:12.535 Param[SERIAL_NUMBER] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:12.535 Param[SIZE_X] GenICamFeature::read: reading Width
2020/02/21 22:58:12.536 Param[SIZE_Y] GenICamFeature::read: reading Height
2020/02/21 22:58:12.536 Param[IMAGE_MODE] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:12.536 Param[NIMAGES] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:12.536 Param[TEMPERATURE_ACTUAL] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:12.536 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:12.538 Param[GC_PIXEL_FORMAT] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:12.538 Param[GC_E_deviceAcquisitionType] GenICamFeature::read: reading deviceAcquisitionType
2020/02/21 22:58:12.538 Param[GC_E_DeviceTLType] GenICamFeature::read: reading DeviceTLType
2020/02/21 22:58:12.538 Param[GC_E_UserSetDefaultSelector] GenICamFeature::read: reading UserSetDefaultSelector
2020/02/21 22:58:12.538 Param[GC_E_UserSetSelector] GenICamFeature::read: reading UserSetSelector
2020/02/21 22:58:12.538 Param[GC_E_Standby] GenICamFeature::read: reading Standby
2020/02/21 22:58:12.539 Param[GC_E_ReadOutMode] GenICamFeature::read: reading ReadOutMode
2020/02/21 22:58:12.539 Param[GC_E_ReadOutDirection] GenICamFeature::read: reading ReadOutDirection
2020/02/21 22:58:12.539 Param[GC_E_SynchronizationMode] GenICamFeature::read: reading SynchronizationMode
2020/02/21 22:58:12.539 Param[GC_E_DigitalGain] GenICamFeature::read: reading DigitalGain
2020/02/21 22:58:12.539 Param[GC_E_Offset] GenICamFeature::read: reading Offset
2020/02/21 22:58:12.539 Param[GC_E_ImageSourceSelector] GenICamFeature::read: reading ImageSourceSelector
2020/02/21 22:58:12.539 Param[GC_E_PixelFormat] GenICamFeature::read: reading PixelFormat
2020/02/21 22:58:12.539 Param[GC_E_PixelCoding] GenICamFeature::read: reading PixelCoding
2020/02/21 22:58:12.539 Param[GC_E_PixelSize] GenICamFeature::read: reading PixelSize
2020/02/21 22:58:12.539 Param[GC_E_Mono12PackedBitSelection] GenICamFeature::read: reading Mono12PackedBitSelection
2020/02/21 22:58:12.539 Param[GC_E_AcquisitionMode] GenICamFeature::read: reading AcquisitionMode
2020/02/21 22:58:12.539 Param[GC_E_deviceUPnPDiscoveryMode] GenICamFeature::read: reading deviceUPnPDiscoveryMode
2020/02/21 22:58:12.539 Param[GC_E_GevIPConfigurationStatus] GenICamFeature::read: reading GevIPConfigurationStatus
2020/02/21 22:58:12.539 Param[GC_E_GevCurrentIPConfiguration] GenICamFeature::read: reading GevCurrentIPConfiguration
2020/02/21 22:58:12.539 Param[GC_E_GevCCP] GenICamFeature::read: reading GevCCP
2020/02/21 22:58:12.539 Param[GC_E_deviceCCP] GenICamFeature::read: reading deviceCCP
2020/02/21 22:58:12.540 Param[GC_E_GevSupportedOptionSelector] GenICamFeature::read: reading GevSupportedOptionSelector
2020/02/21 22:58:12.540 Param[GC_E_GevDeviceModeCharacterSet] GenICamFeature::read: reading GevDeviceModeCharacterSet
2020/02/21 22:58:12.540 Param[GC_E_FileSelector] GenICamFeature::read: reading FileSelector
2020/02/21 22:58:12.540 Param[GC_E_FileOperationSelector] GenICamFeature::read: reading FileOperationSelector
2020/02/21 22:58:12.540 Param[GC_E_FileOpenMode] GenICamFeature::read: reading FileOpenMode
2020/02/21 22:58:12.540 Param[GC_E_FileOperationStatus] GenICamFeature::read: reading FileOperationStatus
2020/02/21 22:58:12.540 Param[GC_B_MainPLLLocked] GenICamFeature::read: reading MainPLLLocked
2020/02/21 22:58:12.540 Param[GC_B_SensorPLLLocked] GenICamFeature::read: reading SensorPLLLocked
2020/02/21 22:58:12.540 Param[GC_B_DeviceRegistersValid] GenICamFeature::read: reading DeviceRegistersValid
2020/02/21 22:58:12.540 Param[GC_B_GevSCPSFireTestPacket] GenICamFeature::read: reading GevSCPSFireTestPacket
2020/02/21 22:58:12.540 Param[GC_B_GevCurrentIPConfigurationLLA] GenICamFeature::read: reading GevCurrentIPConfigurationLLA
2020/02/21 22:58:12.540 Param[GC_B_GevCurrentIPConfigurationDHCP] GenICamFeature::read: reading GevCurrentIPConfigurationDHCP
2020/02/21 22:58:12.540 Param[GC_B_GevCurrentIPConfigurationPersistentIP] GenICamFeature::read: reading GevCurrentIPConfigurationPersistentIP
2020/02/21 22:58:12.540 Param[GC_B_GevSupportedOption] GenICamFeature::read: reading GevSupportedOption
2020/02/21 22:58:12.540 Param[GC_B_GevSupportedIPConfigurationLLA] GenICamFeature::read: reading GevSupportedIPConfigurationLLA
2020/02/21 22:58:12.540 Param[GC_B_GevSupportedIPConfigurationDHCP] GenICamFeature::read: reading GevSupportedIPConfigurationDHCP
2020/02/21 22:58:12.541 Param[GC_B_GevSupportedIPConfigurationPersistentIP] GenICamFeature::read: reading GevSupportedIPConfigurationPersistentIP
2020/02/21 22:58:12.541 Param[GC_B_GevGVCPExtendedStatusCodes] GenICamFeature::read: reading GevGVCPExtendedStatusCodes
2020/02/21 22:58:12.541 Param[GC_B_GevGVCPHeartbeatDisable] GenICamFeature::read: reading GevGVCPHeartbeatDisable
2020/02/21 22:58:12.541 Param[GC_B_GevDeviceModeIsBigEndian] GenICamFeature::read: reading GevDeviceModeIsBigEndian
2020/02/21 22:58:12.541 Param[GC_B_GevSCPSDoNotFragment] GenICamFeature::read: reading GevSCPSDoNotFragment
2020/02/21 22:58:12.541 Param[GC_B_GevSCPSBigEndian] GenICamFeature::read: reading GevSCPSBigEndian
2020/02/21 22:58:12.541 Param[GC_B_ftpFileAccessSupported] GenICamFeature::read: reading ftpFileAccessSupported
2020/02/21 22:58:12.541 Param[GC_S_DeviceVendorName] GenICamFeature::read: reading DeviceVendorName
2020/02/21 22:58:12.541 Param[GC_S_DeviceModelName] GenICamFeature::read: reading DeviceModelName
2020/02/21 22:58:12.541 Param[GC_S_DeviceVersion] GenICamFeature::read: reading DeviceVersion
2020/02/21 22:58:12.541 Param[GC_S_DeviceManufacturerInfo] GenICamFeature::read: reading DeviceManufacturerInfo
2020/02/21 22:58:12.541 Param[GC_S_DeviceProductIDBuild] GenICamFeature::read: reading DeviceProductIDBuild
2020/02/21 22:58:12.541 Param[GC_S_DeviceID] GenICamFeature::read: reading DeviceID
2020/02/21 22:58:12.541 Param[GC_S_HardwareRevision] GenICamFeature::read: reading HardwareRevision
2020/02/21 22:58:12.541 Param[GC_S_TimingVersion] GenICamFeature::read: reading TimingVersion
2020/02/21 22:58:12.541 Param[GC_S_DeviceUserID] GenICamFeature::read: reading DeviceUserID
2020/02/21 22:58:12.541 Param[GC_S_GevFirstURL] GenICamFeature::read: reading GevFirstURL
2020/02/21 22:58:12.541 Param[GC_S_GevSecondURL] GenICamFeature::read: reading GevSecondURL
2020/02/21 22:58:12.541 Param[GC_S_DeviceManifestPrimaryURL] GenICamFeature::read: reading DeviceManifestPrimaryURL
2020/02/21 22:58:12.541 Param[GC_S_DeviceManifestSecondaryURL] GenICamFeature::read: reading DeviceManifestSecondaryURL
2020/02/21 22:58:12.541 Param[GC_I_deviceMacAddress] GenICamFeature::read: reading deviceMacAddress
2020/02/21 22:58:12.541 Param[GC_I_DeviceTLVersionMajor] GenICamFeature::read: reading DeviceTLVersionMajor
2020/02/21 22:58:12.541 Param[GC_I_DeviceTLVersionMinor] GenICamFeature::read: reading DeviceTLVersionMinor
2020/02/21 22:58:12.541 Param[GC_I_deviceDFNCVersionMajor] GenICamFeature::read: reading deviceDFNCVersionMajor
2020/02/21 22:58:12.541 Param[GC_I_deviceDFNCVersionMinor] GenICamFeature::read: reading deviceDFNCVersionMinor
2020/02/21 22:58:12.541 Param[GC_I_DeviceSFNCVersionMajor] GenICamFeature::read: reading DeviceSFNCVersionMajor
2020/02/21 22:58:12.541 Param[GC_I_DeviceSFNCVersionMinor] GenICamFeature::read: reading DeviceSFNCVersionMinor
2020/02/21 22:58:12.542 Param[GC_I_DeviceSFNCVersionSubMinor] GenICamFeature::read: reading DeviceSFNCVersionSubMinor
2020/02/21 22:58:12.542 Param[GC_I_deviceCalibrationDateRaw] GenICamFeature::read: reading deviceCalibrationDateRaw
2020/02/21 22:58:12.542 Param[GC_D_DeviceTemperature] GenICamFeature::read: reading DeviceTemperature
2020/02/21 22:58:12.544 Param[GC_I_SettingsRevision] GenICamFeature::read: reading SettingsRevision
2020/02/21 22:58:12.544 Param[GC_D_FrameRate] GenICamFeature::read: reading FrameRate
2020/02/21 22:58:12.544 Param[GC_I_ExtendedExposure] GenICamFeature::read: reading ExtendedExposure
2020/02/21 22:58:12.544 Param[GC_I_FrameInterval] GenICamFeature::read: reading FrameInterval
2020/02/21 22:58:12.544 Param[GC_I_ROIStartV] GenICamFeature::read: reading ROIStartV
2020/02/21 22:58:12.544 Param[GC_I_ROIStopV] GenICamFeature::read: reading ROIStopV
2020/02/21 22:58:12.544 Param[GC_I_ROIStartH] GenICamFeature::read: reading ROIStartH
2020/02/21 22:58:12.544 Param[GC_I_ROIStopH] GenICamFeature::read: reading ROIStopH
2020/02/21 22:58:12.544 Param[GC_I_SensorDigitalTestPatternValue] GenICamFeature::read: reading SensorDigitalTestPatternValue
2020/02/21 22:58:12.544 Param[GC_I_TestImageIncrement] GenICamFeature::read: reading TestImageIncrement
2020/02/21 22:58:12.544 Param[GC_I_Width] GenICamFeature::read: reading Width
2020/02/21 22:58:12.544 Param[GC_I_Height] GenICamFeature::read: reading Height
2020/02/21 22:58:12.544 Param[GC_I_AcquisitionFrameCount] GenICamFeature::read: reading AcquisitionFrameCount
2020/02/21 22:58:12.544 Param[GC_I_GevStreamChannelSelector] GenICamFeature::read: reading GevStreamChannelSelector
2020/02/21 22:58:12.544 Param[GC_I_GevLinkSpeed] GenICamFeature::read: reading GevLinkSpeed
2020/02/21 22:58:12.545 Param[GC_I_GevSCPSPacketSize] GenICamFeature::read: reading GevSCPSPacketSize
2020/02/21 22:58:12.545 Param[GC_I_GevSCPD] GenICamFeature::read: reading GevSCPD
2020/02/21 22:58:12.545 Param[GC_D_devicePacketResendBufferSize] GenICamFeature::read: reading devicePacketResendBufferSize
2020/02/21 22:58:12.545 Param[GC_I_PayloadSize] GenICamFeature::read: reading PayloadSize
2020/02/21 22:58:12.545 Param[GC_I_GevMACAddress] GenICamFeature::read: reading GevMACAddress
2020/02/21 22:58:12.545 Param[GC_I_GevCurrentIPAddress] GenICamFeature::read: reading GevCurrentIPAddress
2020/02/21 22:58:12.545 Param[GC_I_GevCurrentSubnetMask] GenICamFeature::read: reading GevCurrentSubnetMask
2020/02/21 22:58:12.545 Param[GC_I_GevCurrentDefaultGateway] GenICamFeature::read: reading GevCurrentDefaultGateway
2020/02/21 22:58:12.545 Param[GC_I_GevPersistentIPAddress] GenICamFeature::read: reading GevPersistentIPAddress
2020/02/21 22:58:12.545 Param[GC_I_GevPersistentSubnetMask] GenICamFeature::read: reading GevPersistentSubnetMask
2020/02/21 22:58:12.545 Param[GC_I_GevPersistentDefaultGateway] GenICamFeature::read: reading GevPersistentDefaultGateway
2020/02/21 22:58:12.545 Param[GC_I_GevPrimaryApplicationSocket] GenICamFeature::read: reading GevPrimaryApplicationSocket
2020/02/21 22:58:12.545 Param[GC_I_GevPrimaryApplicationIPAddress] GenICamFeature::read: reading GevPrimaryApplicationIPAddress
2020/02/21 22:58:12.545 Param[GC_I_GevInterfaceSelector] GenICamFeature::read: reading GevInterfaceSelector
2020/02/21 22:58:12.545 Param[GC_I_GevNumberOfInterfaces] GenICamFeature::read: reading GevNumberOfInterfaces
2020/02/21 22:58:12.545 Param[GC_I_GevMessageChannelCount] GenICamFeature::read: reading GevMessageChannelCount
2020/02/21 22:58:12.545 Param[GC_I_GevStreamChannelCount] GenICamFeature::read: reading GevStreamChannelCount
2020/02/21 22:58:12.545 Param[GC_I_GevDiscoveryAckDelay] GenICamFeature::read: reading GevDiscoveryAckDelay
2020/02/21 22:58:12.545 Param[GC_I_GevMCPHostPort] GenICamFeature::read: reading GevMCPHostPort
2020/02/21 22:58:12.545 Param[GC_I_GevMCDA] GenICamFeature::read: reading GevMCDA
2020/02/21 22:58:12.545 Param[GC_I_GevHeartbeatTimeout] GenICamFeature::read: reading GevHeartbeatTimeout
2020/02/21 22:58:12.545 Param[GC_I_GevMCTT] GenICamFeature::read: reading GevMCTT
2020/02/21 22:58:12.545 Param[GC_I_GevMCRC] GenICamFeature::read: reading GevMCRC
2020/02/21 22:58:12.545 Param[GC_I_GevMCSP] GenICamFeature::read: reading GevMCSP
2020/02/21 22:58:12.546 Param[GC_I_GevSCPInterfaceIndex] GenICamFeature::read: reading GevSCPInterfaceIndex
2020/02/21 22:58:12.546 Param[GC_I_GevSCPHostPort] GenICamFeature::read: reading GevSCPHostPort
2020/02/21 22:58:12.546 Param[GC_I_GevSCDA] GenICamFeature::read: reading GevSCDA
2020/02/21 22:58:12.546 Param[GC_I_GevSCSP] GenICamFeature::read: reading GevSCSP
2020/02/21 22:58:12.546 Param[GC_I_GevVersionMajor] GenICamFeature::read: reading GevVersionMajor
2020/02/21 22:58:12.546 Param[GC_I_GevVersionMinor] GenICamFeature::read: reading GevVersionMinor
2020/02/21 22:58:12.546 Param[GC_I_DeviceManifestEntrySelector] GenICamFeature::read: reading DeviceManifestEntrySelector
2020/02/21 22:58:12.546 Param[GC_I_DeviceManifestXMLMajorVersion] GenICamFeature::read: reading DeviceManifestXMLMajorVersion
2020/02/21 22:58:12.546 Param[GC_I_DeviceManifestXMLMinorVersion] GenICamFeature::read: reading DeviceManifestXMLMinorVersion
2020/02/21 22:58:12.546 Param[GC_I_DeviceManifestXMLSubMinorVersion] GenICamFeature::read: reading DeviceManifestXMLSubMinorVersion
2020/02/21 22:58:12.546 Param[GC_I_DeviceManifestSchemaMajorVersion] GenICamFeature::read: reading DeviceManifestSchemaMajorVersion
2020/02/21 22:58:12.546 Param[GC_I_DeviceManifestSchemaMinorVersion] GenICamFeature::read: reading DeviceManifestSchemaMinorVersion
2020/02/21 22:58:12.546 Param[GC_I_TLParamsLocked] GenICamFeature::read: reading TLParamsLocked
2020/02/21 22:58:12.546 Param[GC_I_FileAccessOffset] GenICamFeature::read: reading FileAccessOffset
2020/02/21 22:58:12.546 Param[GC_I_FileAccessLength] GenICamFeature::read: reading FileAccessLength
2020/02/21 22:58:12.546 Param[GC_I_FileOperationResult] GenICamFeature::read: reading FileOperationResult
2020/02/21 22:58:12.546 Param[GC_I_TimingFormatReg] GenICamFeature::read: reading TimingFormatReg
2020/02/21 22:58:12.546 Param[GC_I_TimingVersionReg] GenICamFeature::read: reading TimingVersionReg
2020/02/21 22:58:12.546 Param[GC_I_TimingTypeReg] GenICamFeature::read: reading TimingTypeReg
2020/02/21 22:58:12.546 Param[GC_I_TimingReferenceReg] GenICamFeature::read: reading TimingReferenceReg
2020/02/21 22:58:12.546 Param[GC_I_transferQueueCurrentBlockCount] GenICamFeature::read: reading transferQueueCurrentBlockCount
2020/02/21 22:58:12.547 Param[GC_I_FileSize] GenICamFeature::read: reading FileSize
2020/02/21 22:58:12.547 Param[GC_C_UserSetLoad] GenICamFeature::read: reading UserSetLoad
2020/02/21 22:58:12.547 Param[GC_C_UserSetSave] GenICamFeature::read: reading UserSetSave
2020/02/21 22:58:12.547 Param[GC_C_DeviceReset] GenICamFeature::read: reading DeviceReset
2020/02/21 22:58:12.547 Param[GC_C_SoftwareTrigger] GenICamFeature::read: reading SoftwareTrigger
2020/02/21 22:58:12.547 Param[GC_C_RefreshDiagnoseBits] GenICamFeature::read: reading RefreshDiagnoseBits
2020/02/21 22:58:12.547 Param[GC_C_AcquisitionArm] GenICamFeature::read: reading AcquisitionArm
2020/02/21 22:58:12.547 Param[GC_C_AcquisitionStart] GenICamFeature::read: reading AcquisitionStart
2020/02/21 22:58:12.547 Param[GC_C_AcquisitionStop] GenICamFeature::read: reading AcquisitionStop
2020/02/21 22:58:12.547 Param[GC_C_AcquisitionAbort] GenICamFeature::read: reading AcquisitionAbort
2020/02/21 22:58:12.547 Param[GC_C_DeviceRegistersStreamingStart] GenICamFeature::read: reading DeviceRegistersStreamingStart
2020/02/21 22:58:12.547 Param[GC_C_DeviceRegistersStreamingEnd] GenICamFeature::read: reading DeviceRegistersStreamingEnd
2020/02/21 22:58:12.547 Param[GC_C_DeviceFeaturePersistenceStart] GenICamFeature::read: reading DeviceFeaturePersistenceStart
2020/02/21 22:58:12.547 Param[GC_C_DeviceFeaturePersistenceEnd] GenICamFeature::read: reading DeviceFeaturePersistenceEnd
2020/02/21 22:58:12.547 Param[GC_C_DeviceRegistersCheck] GenICamFeature::read: reading DeviceRegistersCheck
2020/02/21 22:58:12.547 Param[GC_C_FileOperationExecute] GenICamFeature::read: reading FileOperationExecute
2020/02/21 22:58:12.547 ADGenICam::writeInt32 function=90, value=1, status=0
2020/02/21 22:58:12.547 ADAravis:writeInt32: function=90 READ_STATUS, value=1
2020/02/21 22:58:12.547 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:12.548 asynManager::portThread port=ARV1 callback
2020/02/21 22:58:12.548 asynPortDriver:readFloat64: function=57, name=POOL_USED_MEMORY, value=114.257812
2020/02/21 22:58:12.548 ARV1 addr -1 queueRequest priority 0 not lockHolder
2020/02/21 22:58:12.548 asynPortDriver:readInt32: function=54, name=POOL_ALLOC_BUFFERS, value=20
2020/02/21 22:58:12.548 asynPortDriver:readInt32: function=55, name=POOL_FREE_BUFFERS, value=20
Buffer full issue with ADAravis Katie Matusik via Tech-talk
Re: Buffer full issue with ADAravis Mark Rivers via Tech-talk
Re: Buffer full issue with ADAravis Katie Matusik via Tech-talk
RE: Buffer full issue with ADAravis Mark Rivers via Tech-talk
Prev: RE: Buffer full issue with ADAravis Mark Rivers via Tech-talk
Next: Re: matrix multiplication and inversions Matt Rippa via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Next: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
