Hi
I recently upgrade EPICS base & support modules to latest versions which are as follows
base – 7.0.2.2
seq – 2.2.6
asyn – 4-38
autosave – 5-9
astream – 2-6
busy -1-6
sscan – 2-10
areaDetector – 3-8
The error I get on loading ADBase template is –
dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1")
Error: syntax error
at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db" file "ADBase.template" line 660
dbReadCOM: Parser stack dirty w/o error. 1
Though If I comment these line in ADBase template, I can stream camera without any error
# Set ASYN_TRACEIO_HEX bit by default
record(asyn,"$(P)$(R)AsynIO")
info("ADType", "ADDriver")
Also please note, there is no such error in Areadetector version R3-5 with asyn version 4-33. The reason for upgrade is to use ADVimba plugin
instead of ADProsilica plugin.
Many Thanks
Sandeep Malu
