Subject: Re: Areadetector error in version R3-8
To: Sandeep Kumar Malu - UKRI STFC <[email protected]>
Date: Fri, 21 Feb 2020 13:06:28 +0000
Hi Sandeep,
> The error I get on loading ADBase template is -
> dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1")
> Error: syntax error
> at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db"  file "ADBase.template" line 660
> dbReadCOM: Parser stack dirty w/o error. 1
> Also please note, there is no such error in Areadetector version R3-5 with asyn version 4-33. The reason for upgrade is to use ADVimba plugin instead of ADProsilica plugin.
That is a strange error.  Line 660 is a blank line at the end of ADBase.template.
I am using asyn R4-38 and areaDetector R3-8 with no problems, and I think many others are as well.
I notice that you are using base 7.0.2.2.  I am using base 7.0.3.1.
You said that you did not see the problem with areaDetector R3-5 and asyn R4-33.  What version of base were you using with those versions of areaDetector and asyn?
I would suggest updating base to 7.0.3.1 and see if the problem persists.
From: Tech-talk <[email protected]> on behalf of Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]>
Sent: Friday, February 21, 2020 6:11 AM
To: [email protected]
Subject: Areadetector error in version R3-8
Hi
I recently upgrade EPICS base & support modules to latest versions which are as follows
base - 7.0.2.2
seq - 2.2.6
asyn - 4-38
autosave - 5-9
astream - 2-6
busy -1-6
sscan - 2-10
areaDetector - 3-8
Error: syntax error
Though If I comment these line in ADBase template, I can stream camera without any error
# Set ASYN_TRACEIO_HEX bit by default
record(asyn,"$(P)$(R)AsynIO")
field(PORT, $(PORT))
field(TIB2,"1")
info("ADType", "ADDriver")
Many Thanks
Sandeep Malu
Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
Prev: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
Next: Re: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
