Subject: Re: Areadetector error in version R3-8
From: Sandeep Kumar Malu - UKRI STFC via Tech-talk <[email protected]>
Date: Fri, 21 Feb 2020 13:40:24 +0000
Hi Mark
I used base 3.15 for areadetector 3-5 and asyn 4-33. Meanwhile I'll check with base 7.0.3
Also FYI, for me line no 660 points to field(PORT, $(PORT)) in ADBase.template file
Thanks
Sandeep
Get Outlook for Android<https://aka.ms/ghei36>
Sent: Friday, 21 February 2020, 6:36 pm
To: Sandeep Kumar Malu - UKRI STFC
Cc: tech-talk
Hi Sandeep, > The error I get on loading ADBase template is - > dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1") > Error: syntax error > at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db" file "ADBase.template" line 660 > dbReadCOM: Parser stack dirty w/o error. 1 > Also please note, there is no such error in Areadetector version R3-5 with asyn version 4-33. The reason for upgrade is to use ADVimba plugin instead of ADProsilica plugin. That is a strange error. Line 660 is a blank line at the end of ADBase.template. I am using asyn R4-38 and areaDetector R3-8 with no problems, and I think many others are as well. I notice that you are using base 7.0.2.2. I am using base 7.0.3.1. You said that you did not see the problem with areaDetector R3-5 and asyn R4-33. What version of base were you using with those versions of areaDetector and asyn? I would suggest updating base to 7.0.3.1 and see if the problem persists. Mark ________________________________ From: Tech-talk on behalf of Sandeep Kumar Malu - UKRI STFC via Tech-talk Sent: Friday, February 21, 2020 6:11 AM To: [email protected] Subject: Areadetector error in version R3-8 Hi I recently upgrade EPICS base & support modules to latest versions which are as follows base - 7.0.2.2 seq - 2.2.6 asyn - 4-38 autosave - 5-9 astream - 2-6 busy -1-6 sscan - 2-10 areaDetector - 3-8 The error I get on loading ADBase template is - dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1") Error: syntax error at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db" file "ADBase.template" line 660 dbReadCOM: Parser stack dirty w/o error. 1 Though If I comment these line in ADBase template, I can stream camera without any error # Set ASYN_TRACEIO_HEX bit by default record(asyn,"$(P)$(R)AsynIO") { field(PORT, $(PORT)) field(TIB2,"1") info("ADType", "ADDriver") } Also please note, there is no such error in Areadetector version R3-5 with asyn version 4-33. The reason for upgrade is to use ADVimba plugin instead of ADProsilica plugin. Many Thanks Sandeep Malu
RE: Areadetector error in version R3-8 Mark Rivers via Tech-talk
Prev: Re: Areadetector error in version R3-8 Mark Rivers via Tech-talk
Next: RE: Areadetector error in version R3-8 Mark Rivers via Tech-talk
