> Also FYI, for me line no 660 points to field(PORT, $(PORT)) in ADBase.template file
If that is true then you are not using ADCore R3-8, which you said you were in your original message.
Here is the proof:
corvette:ADCore/ADApp/Db>git checkout R3-8 ADBase.template
corvette:ADCore/ADApp/Db>cat -n ADBase.template
1 #=================================================================#
2 # Template file: ADBase.template
3 # Database for area detector control using asyn driver and standard asyn device support
4 # Mark Rivers
5 # March 9, 2008
6
649 ###################################################################
650 # The asynRecord is used for mainly for trace mask #
651 ###################################################################
652
653 # Set ASYN_TRACEIO_HEX bit by default
654 record(asyn,"$(P)$(R)AsynIO")
655 {
656 field(PORT, $(PORT))
657 field(TIB2,"1")
658 info("ADType", "ADDriver")
659 }
660
So in R3-8 line 660 is blank.
However, if I checkout the master branch of ADBase.template I see this:
653 ###################################################################
654 # The asynRecord is used for mainly for trace mask #
655 ###################################################################
656
657 # Set ASYN_TRACEIO_HEX bit by default
658 record(asyn,"$(P)$(R)AsynIO")
659 {
660 field(PORT, $(PORT))
661 field(TIB2,"1")
662 info("ADType", "ADDriver")
663 }
664
So I think you may be running the master branch of ADCore.
I am running the master branch and I don't see your error.
It will be interesting to see if the problem goes away if you run base 7.0.3.1.
-----Original Message-----
From: Sandeep Kumar Malu - UKRI STFC <[email protected]>
Sent: Friday, February 21, 2020 7:40 AM
To: Mark Rivers <[email protected]>
Cc: tech-talk <[email protected]>
Subject: Re: Areadetector error in version R3-8
Hi Mark
I used base 3.15 for areadetector 3-5 and asyn 4-33. Meanwhile I'll check with base 7.0.3
Thanks
Sandeep
Get Outlook for Android<https://aka.ms/ghei36>
Sent: Friday, 21 February 2020, 6:36 pm
To: Sandeep Kumar Malu - UKRI STFC
Cc: tech-talk
Hi Sandeep, > The error I get on loading ADBase template is - > dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1") > Error: syntax error > at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db" file "ADBase.template" line 660 > dbReadCOM: Parser stack dirty w/o error. 1 > Also please note, there is no such error in Areadetector version R3-5 with asyn version 4-33. The reason for upgrade is to use ADVimba plugin instead of ADProsilica plugin. That is a strange error. Line 660 is a blank line at the end of ADBase.template. I am using asyn R4-38 and areaDetector R3-8 with no problems, and I think many others are as well. I notice that you are using base 7.0.2.2. I am using base 7.0.3.1. You said that you did not see the problem with areaDetector R3-5 and asyn R4-33. What version of base were you using with those versions of areaDetector and asyn? I would suggest updating base to 7.0.3.1 and see if the problem persists. Mark ________________________________ From: Tech-talk on behalf of Sandeep Kumar Malu - UKRI STFC via Tech-talk Sent: Friday, February 21, 2020 6:11 AM To: [email protected] Subject: Areadetector error in version R3-8 Hi I recently upgrade EPICS base & support modules to latest versions which are as follows base - 7.0.2.2 seq - 2.2.6 asyn - 4-38 autosave - 5-9 astream - 2-6 busy -1-6 sscan - 2-10 areaDetector - 3-8 The error I get on loading ADBase template is - dbLoadRecords("ADBase.template","P=Y-CAM:,R=cam1:,PORT=Y-CAM:CAM,ADDR=0,TIMEOUT=1") Error: syntax error at or before ":CAM" in path "/usr/local/epics/support/areaDetector/current/ADCore/db" file "ADBase.template" line 660 dbReadCOM: Parser stack dirty w/o error. 1 Though If I comment these line in ADBase template, I can stream camera without any error # Set ASYN_TRACEIO_HEX bit by default record(asyn,"$(P)$(R)AsynIO") { field(PORT, $(PORT)) field(TIB2,"1") info("ADType", "ADDriver") } Also please note, there is no such error in Areadetector version R3-5 with asyn version 4-33. The reason for upgrade is to use ADVimba plugin instead of ADProsilica plugin. Many Thanks Sandeep Malu
- RE: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
- Re: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
Re: Buffer full issue with ADAravis Katie Matusik via Tech-talk
<2020>
2025
2026
<2020>
2025
2026
