Subject: Re: MRF Delay Compensation Function
From: Jukka Pietarinen via Tech-talk <[email protected]>
To: Timo Korhonen <[email protected]>, Guobao Shen <[email protected]>, Javier Cereijo Garcia <[email protected]>, Michael Davidsaver <[email protected]>
Cc: Tech-Talk <[email protected]>
Date: Fri, 21 Feb 2020 10:26:14 +0200
The reason the target delay has to be longer than the sum of the physical and internal delays is that if the target delay is shorter than possible the EVR is still trying to shorten the delay. When the delay error is greater than one event clock this is done by skipping a write to the delay compensation FIFO - this is to speed up the initial locking time and this can lead to an event being missed. During normal operation the delay error is always much less than one event clock cycle and the adjustment is done by phase shifting the event clock and no events are lost.
The above applies to the delay compensation mode. The current (DC) EVRs are capable of a running in non-delay compensated mode (compatible with the EVG-230) and in this case the "target delay" value is the actual delay of the delay compensation FIFO. The target delay value defaults to 0x00080000 which means there are eight events in the FIFO and there is a safe margin from the FIFO getting empty.
There are also flags that indicate if the delay target is too short or too long. I now see that the system could be improved by adding limits to both the lower and higher end of the FIFO that stop adjusting beyond the FIFO empty and full states.
I will address the lock indication issue - this might be related to the event clock frequency which for ESS is 88.0525 MHz, I cannot recall seeing this issue on the VME boards running at an 142.857 MHz event clock.
Best Regards,
Jukka
On 2/20/20 5:55 PM, Timo Korhonen via Tech-talk wrote:
On 20/02/20 15:40, "Shen, Guobao" <[email protected]> wrote:
     > the target delay must always be set so that it is greater than the physical delay, including internal delays. Otherwise some events will be missed
That's interesting and good to know.
     It seems a firmware issue. Did you get any response from Jukka?
This is not a firmware issue in the sense that it could be "corrected" by some change in the firmware. It is by nature of the delay compensation system; the system simply cannot go back in time.
I got some information related to occasional unlocking of the delay compensation feedback loop that we have seen a few times in the lab.
In essence, Jukka is able to reproduce the issue although it seems to be very rare.  The current assumption, as far as I understood, is that this is probably due to some threshold settings in the Xilinx DCM (Digital Clock Manager) being set too low. Also, as well as I understand, this does not cause any jumps in the delays. There will be updates to this but I think this is a very minor issue.
(sorry that this is missing some context for tech-talk readers; it would take a lot of text to replicate the whole discussion here. We can post a summary later if there is interest.)
Best regards,
Timo
> We are starting the commissioning phase soon so we will have better results. Would love to know your experience. Thanks,
     Guobao
On 2/20/20, 2:40 AM, "Javier Cereijo García" <[email protected]> wrote: Hi all, Yes, here at ESS we have done some tests in the lab in the past,
         although they were quite simple. I can share what we have learnt. These
         tests were done using mTCA-EVR-300 and mTCA-EVM-300, not VME.
The first feeling is that everything works as expected, and changing the
         target delay works smoothly, as well as changing the length of the
         optical fiber. There is one thing though that seems strange to me, and
         it is that the target delay must always be set so that it is greater
         events will be missed. Even when using a 230-series EVG with the delay
         compensation disabled on the EVR side the target delay needs to be set
         correctly.
We didn't perform any complex jitter test, although monitoring the "DC
         lock" shows that it gets unlocked from time to time, usually recovering
         quickly. We didn't worry too much at that moment, the measured delay
         wasn't changing that quickly, I think that the lock monitor is quite
         sensitive. I can't recall from the top of my head if we were using the
         EVM's fractional synthesizer or an external RF source, so this may
         easily disappear in a more stable environment.
We are starting the commissioning phase soon so we will have better results. Best regards, Javier On 19/02/2020 18:17, Michael Davidsaver wrote:
         > On 2/18/20 10:43 AM, Shen, Guobao via Tech-talk wrote:
         >> Hi all,
         >> Is there anyone who has been using MRF EVM-300 delay compensation function for any purpose, in the lab, test stand, real machine, etc?
         > ESS did some testing as well.
         >> If yes, would you mind to share us your experience?
         > As I recall, it worked well on a test stand.  My personal knowledge ends there.
         >> Thanks,
         >> Guobao
         >> Guobao Shen
         >> [email protected] <mailto:[email protected]>
         >> Controls Group Leader
         >> Advanced Photon Source
         >> Argonne National Laboratory
         >> 9700 S. Cass Avenue, Lemont, IL 60439
Embedded System Engineer
         HW&I group, ICS division
         European Spallation Source ERIC
Mobile: +46 (0)72 179 23 34
         E-mail: [email protected]
MRF Delay Compensation Function Shen, Guobao via Tech-talk
Re: MRF Delay Compensation Function Michael Davidsaver via Tech-talk
Re: MRF Delay Compensation Function Javier Cereijo García via Tech-talk
Re: MRF Delay Compensation Function Shen, Guobao via Tech-talk
Re: MRF Delay Compensation Function Timo Korhonen via Tech-talk
Prev: Re: Buffer full issue with ADAravis Mark Rivers via Tech-talk
Next: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
Prev: Re: MRF Delay Compensation Function Timo Korhonen via Tech-talk
Next: Error compiling ADAravis Katie Matusik via Tech-talk
