1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: firewalld configuration for EPICS?
From: Goetz Pfeiffer via Tech-talk <[email protected]>
To: Dirk Zimoch <[email protected]>, EPICS <[email protected]>
Date: Mon, 24 Feb 2020 14:09:57 +0100
On 4/3/19 11:51 AM, Dirk Zimoch via Tech-talk wrote:
> Hi
> Does anyone already have a firewalld configuration to allow Channel Access? I.e. something like a /usr/lib/firewalld/services/epics.xml file?
> Dirk
Hello Dirk,
I just struggled with firewalld in order to make EPICS clients and servers work and I found this solution for the command line:
Settings for EPICS clients:
  firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=udp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=udp accept"
Additional settings for EPICS servers:
  firewall-cmd --add-rich-rule="rule port port=5064 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule port port=5064 protocol=udp accept"
  firewall-cmd --add-rich-rule="rule port port=5065 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule port port=5065 protocol=udp accept"
Make changes permanent:
  firewall-cmd --runtime-to-permanent
Greetings
  Goetz
Attachment: signature.asc
Description: OpenPGP digital signature
Re: firewalld configuration for EPICS? Jörn Dreyer via Tech-talk
Re: firewalld configuration for EPICS? Ralph Lange via Tech-talk
Prev: RE: Areadetector error in version R3-8 Sandeep Kumar Malu - UKRI STFC via Tech-talk
Next: Re: firewalld configuration for EPICS? Jörn Dreyer via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: Problem in installing synApps_6_0 Kim SeongBin via Tech-talk
