1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: firewalld configuration for EPICS?
From: Ralph Lange via Tech-talk <[email protected]>
To: EPICS Tech Talk <[email protected]>
Date: Fri, 28 Feb 2020 11:25:53 +0100
Small note:
On Mon, 24 Feb 2020 at 14:10, Goetz Pfeiffer via Tech-talk <[email protected]> wrote:
Settings for EPICS clients:
  firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5064 protocol=udp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule source-port port=5065 protocol=udp accept"
Additional settings for EPICS servers:
  firewall-cmd --add-rich-rule="rule port port=5064 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule port port=5064 protocol=udp accept"
  firewall-cmd --add-rich-rule="rule port port=5065 protocol=tcp accept"
  firewall-cmd --add-rich-rule="rule port port=5065 protocol=udp accept"
Channel Access does not use TCP on the beacon port (aka CA_REPEATER_PORT, ca-2, 5065). Opening it does no harm, but is not needed.
Cheers,
~Ralph
Re: firewalld configuration for EPICS? Goetz Pfeiffer via Tech-talk
Prev: Beckhoff PLC support; Motion control Artur Piscalov via Tech-talk
Next: RE:Support for Cryocon 22C Ruiz-Rodriguez, Mariano M. via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: firewalld configuration for EPICS? Abdalla Ahmad via Tech-talk
Next: asyn R4-39 available Mark Rivers via Tech-talk
