1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: Re: firewalld configuration for EPICS?
From: Gabriel Fedel via Tech-talk <[email protected]>
To: Abdalla Ahmad <[email protected]>, <[email protected]>
Date: Tue, 25 Feb 2020 10:50:27 +0100
Hi Abdalla,
Thank for the reference.
But I think even using this script the firewall will block the other IOCs to send data to the client, will not?
Best Regards
On 2/25/20 8:53 AM, Abdalla Ahmad wrote:
Hi Gabriel
You are right. In the case of multiple IOCs, each IOC other than the first one to run will get a random port number. See this link by Ralph https://wiki-ext.aps.anl.gov/epics/index.php/How_to_Make_Channel_Access_Reach_Multiple_Soft_IOCs_on_a_Linux_Host where you create a Network manager dispatcher script where it broadcasts UDP traffic to all processes.
Best Regards,
Abdalla.
-----Original Message-----
From: Tech-talk <[email protected]> On Behalf Of Gabriel Fedel via Tech-talk
Sent: Monday, February 24, 2020 6:33 PM
To: [email protected]
Hi all,
I'm doing some tests with firewalld configuration, using yours examples, but I think they will not work if there are more than 1 IOC running on same machine, right?
Because the port for the other IOCs to transfer data will be other then the 5064/5065 for CA (and 5076/5077 for PVAccess).
Is my understanding correct?
Is there some alternative for these cases?
Best Regards
On 2/24/20 1:27 PM, Jörn Dreyer via Tech-talk wrote:
I have the following content in an XML file under
/etc/firewalld/services/EPICSChannelAccess.xml
<?xml version="1.0" encoding="utf-8"?> <service>
   <short>EPICS Channel Access service</short>
   <port port="ca-1" protocol="tcp"/>
   <port port="ca-1" protocol="udp"/>
   <port port="ca-2" protocol="tcp"/>
   <port port="ca-2" protocol="udp"/>
   <source-port port="ca-1" protocol="tcp"/>
   <source-port port="ca-1" protocol="udp"/>
   <source-port port="ca-2" protocol="tcp"/>
   <source-port port="ca-2" protocol="udp"/> </service>
But this requres a link o be set on my system from /usr/etc/services
to /etc/services. Somehow firewalld under OpenSuSE Tumbleweed does not
yet honor the new path to this file. But if you replace the symbolic
port names to the corresponding numbers it also works.
Jörn
Am Montag, 24. Februar 2020, 14:09:57 CET schrieb Goetz Pfeiffer via
Tech-talk:
  > On 4/3/19 11:51 AM, Dirk Zimoch via Tech-talk wrote:
  > > Hi
  > > Does anyone already have a firewalld configuration to allow
Channel
  > > Access? I.e. something like a
/usr/lib/firewalld/services/epics.xml
file?
  > > Dirk
  > Hello Dirk,
  > I just struggled with firewalld in order to make EPICS clients and
servers
  > work and I found this solution for the command line:
  > Settings for EPICS clients:
  >   firewall-cmd --add-rich-rule="rule source-port port=5064
protocol=tcp
  > accept" firewall-cmd --add-rich-rule="rule source-port port=5064
  > protocol=udp accept" firewall-cmd --add-rich-rule="rule source-port
  > port=5065 protocol=tcp accept" firewall-cmd --add-rich-rule="rule
  > source-port port=5065 protocol=udp accept"
  > Additional settings for EPICS servers:
  >   firewall-cmd --add-rich-rule="rule port port=5064 protocol=tcp accept"
  >   firewall-cmd --add-rich-rule="rule port port=5064 protocol=udp accept"
  >   firewall-cmd --add-rich-rule="rule port port=5065 protocol=tcp accept"
  >   firewall-cmd --add-rich-rule="rule port port=5065 protocol=udp accept"
  > Make changes permanent:
  >   firewall-cmd --runtime-to-permanent
  > Greetings
  >   Goetz
Gabriel Fedel
Gabriel Fedel
Ship 8, Floor 2.
EPICS Integrator
Integrated Control System Division
The European Spallation Souce
Odarslövsvägen 113
224 84 Lund
mobile Sweden: 0723356030
mobile International: +46723356030
RE: firewalld configuration for EPICS? Abdalla Ahmad via Tech-talk
Re: firewalld configuration for EPICS? Goetz Pfeiffer via Tech-talk
Re: firewalld configuration for EPICS? Jörn Dreyer via Tech-talk
Re: firewalld configuration for EPICS? Gabriel Fedel via Tech-talk
Prev: Re: Problem in installing synApps_6_0 Kim SeongBin via Tech-talk
Next: RE: firewalld configuration for EPICS? Abdalla Ahmad via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: Re: firewalld configuration for EPICS? Gabriel Fedel via Tech-talk
