1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026  Index 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Subject: quadEM R9-3 now available
Date: Mon, 2 Mar 2020 21:37:04 +0000
Folks,
quadEM R9-3 is now available.
This is from the R9-3 release notes:
- This version of quadEM requires ADCore R3-8 or later.
- Previous versions of quadEM will not work with ADCore R3-8 or later because the Acquire parameter is now implemented in the asynNDArrayDriver base class, rather than being local to quadEM.
- Added a new drvNSLS2_IC driver which has independent control of each channel for use with separate ion chambers, for example, rather than a quad electrometer.
- drvNSLS_EM: Fixed logic error in turning off data transmission from meter when not acquiring.
- iocsh/commonPlugins.iocsh: Fixed names of FFT time series ports.
- Added .bob autoconverted files for Phoebus Display Manager.
The home page is here:
http://cars.uchicago.edu/software/epics/quadEM.html
The documentation is here:
http://cars.uchicago.edu/software/epics/quadEMDoc.html
The release notes are here:
http://cars.uchicago.edu/software/epics/quadEMReleaseNotes.html
The software repository is on github.  Releases can be obtained there.
https://github.com/epics-modules/quadEM
Let me know of any problems or suggestions.
Prev: RE: pco Camera USB and IEEE interface Ivashkevych, Oksana via Tech-talk
Next: Re: pco Camera USB and IEEE interface Bradnick, Ben (Tessella, RAL, TEC) via Tech-talk
Index: 1994  1995  1996  1997  1998  1999  2000  2001  2002  2003  2004  2005  2006  2007  2008  2009  2010  2011  2012  2013  2014  2015  2016  2017  2018  2019  <20202021  2022  2023  2024  2025  2026
Prev: RE: Streams Support for Varian Dual Mark Rivers via Tech-talk
Next: FW: EPICS on windows10 Debian Shell Alfio Rizzo via Tech-talk
