Subject: RE: Streams Support for Varian Dual
To: 'Heinz Junkes' <[email protected]>
Date: Mon, 9 Mar 2020 13:44:59 +0000
Hi Heinz,
Thanks for sending that.  I believe these protocols are actually incorrect:
wsetpt1 { out "#\$1" "71%0.1E"; in ">\$1" "71";    }
wsetpt2 { out "#\$1" "72%0.1E"; in ">\$1" "72";    }
whvpwr  { out "#\$1" "30%1b";   in ">\$1" "00";    }
Those "set" commands actually only return an ACK character, they do not return the string in the protocol.  It does not generate an error message but it does generate a timeout.  The new protocol file in epics-modules/ip just looks for the ACK and does not timeout.
-----Original Message-----
Sent: Sunday, March 8, 2020 4:29 AM
Cc: Ralph Lange <[email protected]>; [email protected]
Subject: Re: Streams Support for Varian Dual
Hello, Mark,
this is the protocol file Ralph was talking about. We have that in the field:
epics@fel-aes:~/FHI/IOCVAC/IOCVACApp/Db$ more multigauge.proto # MultiGauge Compatible protocol for the Varian Dual Controller # Pete Owens 22-1-02 # Ralph Lange 19-08-11
terminator   = CR;
replytimeout = 1000;
readtimeout  = 1000;
extrainput   = Ignore;
# this protocol is just for testing
raw  { out "#\$1" "000"; in "%s"; }
vmeas   { out "#\$1" "07?";     in ">\$1" "07%d";  }
imeas   { out "#\$1" "08?";     in ">\$1" "08%f";  }
pmeas   { out "#\$1" "02?";     in ">\$1" "02%f";  }
rsetpt1 { out "#\$1" "71?";     in ">\$1" "71%f";  }
rsetpt2 { out "#\$1" "72?";     in ">\$1" "72%f";  }
rhvpwr  { out "#\$1" "30?";     in ">\$1" "30%1b"; }
dtype   { out "#\$1" "11?";     in ">\$1" "11%s";  }
I saw that you made some useful changes. I will try these out on occasion.
Heinz
> On 2. Mar 2020, at 16:28, Mark Rivers via Tech-talk <[email protected]> wrote:
> Hi Ralph and Pete,
> Thanks very much for those.
> I have fixed some problems and added some new PVs.
> My version is in the synApps ip module:
> https://github.com/epics-modules/ip
> The files are
> ipApp/Db/VarianDualIP.db
> ipApp/Db/VarianDualIP.protocol
> ipApp/Db/VarianDaulIP_settings.req
> ipApp/op/adl/VarianDualIP.adl
> ipApp/op/*/autoconvert/VarianDuallIP.*
> Thanks,
> Mark
> From: Ralph Lange <[email protected]>
> Sent: Friday, February 28, 2020 10:52 AM
> Subject: Fwd: Streams Support for Varian Dual
> Here's what I got from Pete for Heinz' FEL project nine years ago. :-)
> I probably updated them for the FEL, but I don't have access to their system anymore. Heinz will know - he's on vacation and I don't know when he will be back.
> Cheers,
> ~Ralph
> ---------- Forwarded message ---------
> From: <[email protected]>
> Date: Fri, 22 Jul 2011 at 19:02
> To: <[email protected]>
> Hi Ralph,
> Here are the original files.
> Pete
> From: Ralph Lange [mailto:[email protected]]
> Sent: 22 July 2011 13:02
> To: Owens, Peter (STFC,DL,TECH)
> Subject: Streams Support for Varian Dual
> Hi Pete,
> you are listed in the EPICS Support database as contact for the
> Streams support for Varian Dual Ion Pump Controllers.
> Do you have something that you can tar up to get me started?
> Thanks a lot,
> Ralph
> Scanned by iCritical.
RE: Streams Support for Varian Dual Mark Rivers via Tech-talk
Re: Streams Support for Varian Dual Heinz Junkes via Tech-talk
Prev: EPICS connection with S7-1500 PLC Vishnu Patel via Tech-talk
Next: Load or reload databases after IOC initialization Abdalla Ahmad via Tech-talk
Prev: Re: Streams Support for Varian Dual Heinz Junkes via Tech-talk
Next: quadEM R9-3 now available Mark Rivers via Tech-talk
